Author Topic: circular saw blade storage???  (Read 10013 times)
Offline waynelang2001
« on: July 05, 2011, 12:12 PM »
Hi guys, long time no post.
Ive been thinking of making a nice storage space for my blades, I have a few designs in my head but just thought I would check in and see how you guys store your blades. Maybe you might also have some unique ideas for storage to.
My work shop has a very low ceiling so I was thing of making some kind of drop down system for the blades and push sticks.
So, Any ideas ???
Latest Festool purchase?? The CXS.....Next Festool purchase???? The Domino.....
http://www.facebook.com/pages/Langley-Woodworks/147551115290424
Offline Deansocial
Re: circular saw blade storage???
« Reply #1 on: July 05, 2011, 12:20 PM »
if you search there was a thread about this the other day
« Reply #2 on: July 05, 2011, 04:56 PM »
Ok did the search but there is only storage solutions there for systainers. I should have posted im talking about my sliding table saw.
Offline Deansocial
« Reply #3 on: July 05, 2011, 05:01 PM »
oh right ok, something like this maybe?
http://www.sawhorseworkshop.com/sawcaddieplans.html
Offline Alan m
« Reply #4 on: July 05, 2011, 05:53 PM »
i dont like storeing blades and such out in the open like that. there is too much chance of hitting them or knocking them. i have a cabinet under the wing of my saw that the blades go in along with tools and accesories for the saw. they sit on shelfs in there.
you say you have a low ceiling. are the joists exposed . if so you could make a ply box the width of the joists and long enough to come down to 4 feet. you could have dividers set in at an angle so the balde has a little slot to slide into . by storeing them at a slight angle you will have full acess to all the blades. 39978-0
« Reply #5 on: July 06, 2011, 04:21 AM »
The ceiling in the workshop is concrete so i would have to build a storage unit and use some bolts to tie it in. Im liking the slotted designs and i came across this click this PDF. I like the idea of droping the blades in a cartridge and then sliding it into the slots. I could then just label the fronts to see what blade I need.
Offline Steve Rowe
  • Teach them safety when they are young.
« Reply #6 on: July 06, 2011, 02:54 PM »
This is my version that provides storage for more than just blades.
Maximum blade diameter is 400mm.  I used a 1-5/16" hole saw for the button to go through the bore which was just perfect for a 30mm hole.
Offline Sal LiVecchi
« Reply #7 on: July 06, 2011, 04:03 PM »
Steve   Again awesome job, I like the drawer setup alot, might have to copy your thoughts for sure
Sal
Life is too short and the road is too long to drive anything less than a Festool
Offline woodguy7
« Reply #8 on: July 06, 2011, 04:24 PM »
Nice work Steve, i like that style of storage.
Shirt size medium
« Reply #9 on: July 06, 2011, 04:48 PM »
Steve that is what im talking about, perfect. Think I will do something similar but just have it above the table saw. Floor space is something I have very little of.
Offline Steve Rowe
« Reply #10 on: July 06, 2011, 05:16 PM »
Thanks guys,
Wayne - I made the height of the cabinet so that it will slide under the saw extension table.  This way, I didn't consume anymore floor space than was already used.
Steve
Offline justinmcf
  • Queensland Builder
« Reply #11 on: July 06, 2011, 08:45 PM »
thats a beautiful job steve!
thanks for sharing the photos.
i will be making something similar based on your photo's.
regards, justin.
Offline jimbo16
« Reply #12 on: January 19, 2020, 08:25 PM »
I find Ikea Kalas plates (set of 6 for AU$2.00) an idea size for 160mm blades. Both for storing a stack of blades together, and also for soaking in blade cleaner.
Offline rmhinden
« Reply #13 on: January 19, 2020, 08:47 PM »
I recently made a blade storage box for my SawStop table saw.  It mounts under the extension wing.
While most of the blades are 10" for the table saw, I have put my rip blade for my TS75 in it as well :-)
« Reply #14 on: January 19, 2020, 08:55 PM »
They’re $2 for six in the US too! One is of us getting a better deal?
Offline ChuckM
« Reply #15 on: January 19, 2020, 09:55 PM »
« Reply #16 on: January 20, 2020, 09:32 AM »
I like it...how does it mount to the SawStop?
Offline rmhinden
« Reply #17 on: January 20, 2020, 11:47 AM »
Thanks.   The extension table (w/ black top) has a wooden grid support structure.   I screwed two layers of 3/4" birch plywood to that .  Then screwed the saw blade box to that.   This allowed the box to be below the front rails and inset enough to not be in the way, but still accessible.
This picture shows it a little better.
Bob
Offline WarrenT
« Reply #18 on: January 20, 2020, 04:44 PM »
Bob, that is a great idea and a nice execution.  If you don’t mind, I am going to build one just like it !
Thank you for posting the pictures....
Offline rmhinden
« Reply #19 on: January 20, 2020, 08:10 PM »
I don't mind at all, glad you found it useful.  It is loosely based on a few designs I found on the internet.
If you, or anyone else, is interested in some additional pictures, PM me with an email address.
Bob
Offline JimD
« Reply #20 on: February 06, 2020, 10:13 AM »
I have a cabinet under the extension wing of my SawStop.  The second drawer is for blades which are stored on a dowel with a scrap plywood separator between blades.  It takes longer to go through the blades this way but it takes up less space than the other designs I've seen.  I will store a dado blade in the same drawer, once I finally buy a 8 inch dado and the cartridge.  310403-0
Offline Mario Turcot
« Reply #21 on: February 11, 2020, 09:45 PM »
I have a cabinet under the extension wing of my SawStop.  The second drawer is for blades which are stored on a dowel with a scrap plywood separator between blades.  It takes longer to go through the blades this way but it takes up less space than the other designs I've seen.  I will store a dado blade in the same drawer, once I finally buy a 8 inch dado and the cartridge.  (Attachment Link)
The dowel is a clever idea :D
Mario
Offline Bob D.
« Reply #22 on: February 11, 2020, 10:56 PM »
Here's how I store mine.
