Does the Origin provide a recommendation for the number of pins based on either mechanics and/or aesthetics, or does the user have to come up with that based on previous experience?
No, it doesn't tell you anything. It has menu choices on the screen wanting information from you.
1)It wants to know how thick the material is.
This determines the amount of travel in and out. (toward you and away)
2)It wants to know how wide the material is.
This is used later in it's "thinking"
3)You tell it how many pins you want in total. (both halves of the joint)
4)It already knows the bit diameter, which you previously entered.
5)There is also a space to account for a "glue gap", this is what determines how tight the fit will be.
Then it "does the math" and shows you an "A" board and the opposing "B" board, so you can alternate between them, depending on which side you are working with.
If you tell it that you want more pins than will fit with your bit diameter, it will tell you it can't do that.
You can either change bits, or reduce the number of pins.
I like the looks of the almost square fingers. Most people (myself included) lean toward narrower fingers, but when I see joints like this, I always tell myself to try it next time.
This was the result of 5 pins on a board that is 2" wide. The pins are just over 3/8" wide, right at .400"
"Theoretically" you could do an even number of pins and each board would be the same. You would just have to be more aware of inside and outside when you load them in. It would be faster, if that was the only requirement.
Have you tried stacking parts and cutting two sides at a time?
I tried it with 1/4" ply as a test, and wasn't thrilled with the results because the parts wouldn't stay still when clamped. I was going try it with solid wood soon, but if you've tried it and it doesn't work, it doesn't work.
I haven't tried it yet, but there really isn't any reason that it wouldn't work, other than movement. (Like you experienced)
In this particular case, the parts were so small that I had to do some "adapting." I did these on the Shaper Workstation. The pins on the vertical plate are too far apart for the shortest pieces, since they are only 5" long. So, I first clamped an auxiliary fence in there to support them better. It was only 1/4" thick, so stacking wouldn't have worked. Then I did a "new grid" from that position.
The first time I used it for box joints was just a test pair. I had a few minutes to spare one day and tried it for later reference. That first pair was a little loose, but I was just trying to see what it would do.
Pairs of parts should be fine, it's just a fixturing thing. Try it with some solid wood, end grain cuts really easily like this. That Ash just peeled off in nice little confetti pieces, really smooth.
