Author Topic: 1  (Read 1786 times)
Offline roblg3
  • Transforming into a whole new machine
1
« on: October 04, 2014, 12:57 AM »
« Last Edit: October 04, 2014, 07:17 AM by roblg3 »
Rob Gardner
Operator
RL3 Enterprises
Offline alkaline
Re: a lil help??
« Reply #1 on: October 04, 2014, 03:07 AM »
It is only a rough calculation. You can surely do a joke.
 [wink]
I have several boxes Festool, one MTF, four guide rails and big taste to play. )))
Offline wow
  • Inactive Member
Re: a lil help??
« Reply #2 on: October 04, 2014, 05:45 AM »
Those '45's' are CLEARLY not 45's, so your 90's are not 90's. You can even see it in the picture.
Check the angle setting on whatever tool (table saw? Track saw? ) you used to cut the 45 degree cuts with.
Offline Peter Parfitt
  • Magazine/Blog Author
Re: a lil help??
« Reply #3 on: October 04, 2014, 06:04 AM »
Hi Rob
From where I am sitting it looks as though the top and left hand pieces are slightly wider than the others - this could be an optical illusion of course. As for the 45 deg check - only you can do this.
Perhaps you could check both aspects and let us know.
Offline Bohdan
Re: a lil help??
« Reply #4 on: October 04, 2014, 06:47 AM »
Did you cut the angles at 45?
If the legs are tapered then the required angle is slightly less than 45 depending on the amount of taper.
