Author Topic: A dominoed zigzag end table  (Read 4475 times)
Offline Rocker
  • Furniture maker, Queensland, Australia
    • Build your own rocking chair
« on: May 13, 2007, 05:42 AM »
Here is a jarrah zigzag end table that I built with domino joinery to match my zigzag chairs. The leg miter joints are each aligned with a 6 x 40 mm domino, and locked by a single shop-made 6 x 40 mm through locking tenon, whose mortise was milled after the miter joint had been glued up with epoxy. Since the Domino's maximum milling depth is 28 mm, the bottom of the mortise had to be drilled out and cleaned up with a file. The feet, legs, and top rails of the table are made from 25 x 35 mm stock. The end-rail's miter joints are reinforced by 5 x 30 mm dominoes in horizontal mortises. The table's frame was easily able to bear my weight.
Rocker
Free downloadable plans and articles on jigs and furniture on my blog:
http://rockerswoodwork.blogspot.com/
Offline Matthew Schenker
Re: A dominoed zigzag end table
« Reply #1 on: May 13, 2007, 07:01 AM »
Rocker,
Excellent work, again!  Thanks for sharing this latest design with us.  You are definitely opening my eyes to even more potential Domino joinery.
Just one question -- what did your neighbors think of you standing out there on a zigzag platform?  Or are they used to seeing this sort of thing?
Matthew
FOG Designer and Creator
Offline Rocker
« Reply #2 on: May 14, 2007, 12:56 AM »
Matthew,
Minor eccentricities are well tolerated in Oz, and anyway most of my neighbors are horses, who have better things to think about.
In making the frame for a second table, I found that it was easier to rout the mortise for the locking tenon on my mortising jig (see my blog below for free plans of the jig) with a 3/8" spiral bit with a 2" cutting length; in this way I could rout the full depth of the through mortise.
David
« Last Edit: May 14, 2007, 12:59 AM by Rocker »
Offline Barryduck
« Reply #3 on: May 14, 2007, 04:56 AM »
HI Rocker,
It's great to have other Aussies contributing to this site and I have added your website to my favourites for a more in depth review when I get time. On first impression your work looks very impressive and its very generous of you to provide plans etc for others to enjoy.
cheers
Barry
Offline Dave Rudy
  • Coloroda Front Range, in the lee of Pikes Peak
« Reply #4 on: May 14, 2007, 09:29 AM »
Rocker
Rocker,
I'm still waiting for the pic of you SITTING on the table with the other three guys in your lap.
LOL
Dave
Great table, BTW.  I'm adding it to the list of projects right after the zigzag chair.
Dave
« Last Edit: May 14, 2007, 09:31 AM by Dave Rudy »
