@luvmytoolz yes those are Kreg pockets, but that is just part of the glued sections. Those will not come apart again.
I thought you were referring to something that I had missed out on somehow?
@squall_line I am a bit mixed on the castle pockets. They work, don't get me wrong, the company has had one for years. I find that there are some problems with them though. Since the cutters for the pocket and drilling are separate, there can be alignment issues. The main problem though is that they are effectively exclusive to 3/4" material. You
can insert thicker material, but you can't move the pocket to center it. (at least on the older, floor standing model we have) "Thicker" is also limited to about 1", because of the clamping mechanism. There is also the lack of portability. Order of operations comes in there. If you need to add a pocket somewhere in an assembly, you're out of luck.
The advantages of the drill-bit style (Kreg or others) are exactly the opposite of that. You can go thinner and quite a bit thicker (centered). The alignment is never a thing, as the holes are simultaneous. Plus, there are many ways to use the same drill bit to get the same results. We have a full-sized floor model that is 100% air-driven, no electricity required, except to run the compressor of course. Then there are a lot of different hand-held or bench mounted alternatives.
For me though, the biggest advantage of the drill-bit style, is the plugs. Often this doesn't matter, because the pockets are inner structure fasteners (never seen). Once in a while, like in this case, the pockets are on the surface somewhere. They will not be seen, because they are veneered or laminated over, but I prefer to fill the holes to keep them from being punctured or dented later. It's not hugely important on vertical surfaces or under the thicker laminates. On horizontal surfaces with veneer or the thin (vertical grade) laminates, it's just a safer bet to fill them.
You
can fill Castle pockets, but it takes much more fiddling.
