Author Topic: Tool Cabinet  (Read 5699 times)
Offline Jon3
Tool Cabinet
« on: March 05, 2007, 12:19 PM »
We start with a nice new TS55/CT22 Combo Purchase.
Then we get some nice Baltic Birch and cut out the top, bottom, and sides with our new TS55.  (You can see the FWW special edition I'm using for the plans in the photo.)
TS55, CT22, ES125EQ, Domino, C12, RO125, OF1010, OF1400
Offline Jon3
Re: Tool Cabinet
« Reply #1 on: March 05, 2007, 12:21 PM »
Day 2
I cut some of the ugliest finger joints known to mankind.  Next time I'm cutting finger joints I can't do on the tablesaw I'm going to use one of those locking router bits instead.
Then I dry fit.
Offline Jon3
Re: Tool Cabinet
« Reply #2 on: March 05, 2007, 12:24 PM »
Day 3
Glue Up!
Rabbiting the Panels
Glue/Staple the Panels.  (Yup, I screwed up the directions here!  I was supposed to just temporarily screw them so the panels could be removed to route the dadoes for the shelves. I'll just put a liner inside and live with my mistake!)
Offline Jon3
Re: Tool Cabinet
« Reply #3 on: March 05, 2007, 12:25 PM »
And now I festool open the box open with the TS55.  Nice Clean Corners.
Offline Daniel Platt
Re: Tool Cabinet
« Reply #4 on: April 19, 2007, 03:22 PM »
Hello Jon,
I was curious how the cabinet came out/is coming along? I have this same issue and was planning to make some wall space and build something similar.
Thanks,
Daniel
Offline charlie b
Re: Tool Cabinet
« Reply #5 on: June 13, 2007, 03:17 AM »
Not sure why you went with finger/box joints instead of half blind or through dovetails - but to each his own.
Since you used ply - a backer board AND a "fronter" board would probably eliminated all the tear out/blow out you got.
When it comes time to fill your cabinets - think "modules" rather than permanent "built ins".  You WILL want to change the interior set up at some point.  So - go modular.
http://web.hypersurf.com/~charlie2/WallToolCabinet/RightToolCabinet.html
charlie b
