Author Topic: 19' Sapele plywood countertop.  (Read 9205 times)
Offline Jon Hilgenberg
« on: June 15, 2013, 06:10 PM »
I landed this job a while ago and I was initially supposed to build this in a shop.  The middle section was supposed to bump out, which would make it easier to build, and easier to hide the seams at the front edging.  Long story short, the cabinets weren't quite laying out the way they were supposed to so that plan got nixed.  So I got to set up shop in the garage and show off my festools!
Once again, another job that I would have walked away from in a New York minute I didn't own a TS55.
Edging isn't installed yet, doing that Monday.
88471-0
The more Festools I buy, the more money I earn.  The more money I earn, the more Festools I buy.  The more...
TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
Re: 19' Sapele plywood countertop.
« Reply #1 on: June 15, 2013, 06:14 PM »
More pics, bear with me...first time attaching images in post.
Two pieces cut and set
88473-0
Three pieces cut and set
88475-1
« Reply #2 on: June 15, 2013, 06:18 PM »
More...
88477-0
88479-1
Joints are glued and pocket screwed.  Couldn't figure out how to domino the joints and get the pieces together in a wall to wall application,  especially with a deeper center section.
Jon
« Reply #3 on: June 15, 2013, 06:35 PM »
More.
88481-0
88483-1
Offline farms100
    • please visit our woodworking guild
« Reply #4 on: June 15, 2013, 08:06 PM »
nice work!
<edited to add> I really like the grain matching you did.
« Last Edit: June 15, 2013, 11:57 PM by farms100 »
eastern mass guild of woodworkers. http://www.emgw.org
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: June 15, 2013, 11:14 PM »
pretty slick brotherman….
« Reply #6 on: June 15, 2013, 11:34 PM »
Thanks guys.  Can't wait to have it sprayed so I can take some finished pics.
Jon
Offline builderbob
    • RJP Remodeling
« Reply #7 on: June 16, 2013, 10:39 AM »
That looks great Jon!
Kapex, TS55, CMS GE, Carvex 420, Domino DF500, MFK 700, OF 2200, OF 1400, OF 1010, EHL65, RAS 115, RTS 400, RO150, ETS 150/3, ETS 125, CT 22 (2), CXS (2), C-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Offline Brice Burrell
  • Remodeling Contractor
« Reply #8 on: June 16, 2013, 11:28 AM »
Great work, as usually.  Here's a tip for the pics, next time try resizing the pictures first.
« Reply #9 on: June 16, 2013, 12:06 PM »
Brice,
Are they too big?  I can't tell since I'm doing this from my iPhone.  I can resize them using Everclipper, so it's an extra step but I suppose I can fit more pictures per post that way.
Thanks for the compliment, that means a lot.
Jon
Offline Wuffles
« Reply #10 on: June 16, 2013, 01:38 PM »
Hi.
First post, so apologies if this is a dumb question. I'm looking at getting a pocket hole jig and came across this post. Can you just explain how a pocket hole could be used to connect these together given the depth of the material used? I'm guessing a baton underneath, which surely doesn't need a pocket hole?
Thanks in advance.
Tool list updated to reflect knowledge :: hammer, screwdriver, one pozi bit, and another bigger hammer.
« Reply #11 on: June 16, 2013, 02:00 PM »
The joint was accessible from underneath.  I got lucky...I was originally planning on using these connectors.
88497-0
Offline Wuffles
« Reply #12 on: June 16, 2013, 02:14 PM »
Just as well, on 18mm (sorry, I'm in UK) ply they'd have pinged out with any kind of pressure on them I suspect. I use them regularly on worktops so know the drawbacks if the recess isn't deep enough.
Did you have a photo of how the pocket hole was drilled to make it work in this situation?
« Reply #13 on: June 16, 2013, 02:20 PM »
Wuffles, I didn't take any pictures of the pocket screws underneath.  I can tell you though that once I pocket screwed the joint together I glued and screwed another piece of plywood to bridge the joint for added strength.
I'll take some more pics tomorrow.
Hopefully someone else can chime in or post a picture of a pocket screwed joint.
Jon
Offline Wuffles
« Reply #14 on: June 16, 2013, 02:22 PM »
Cheers Jon.
To clarify. I can imagine a pocket screw being used in a standard 90 degree situation, but not on a 180 degree...hope that makes sense.
Thanks again.
Offline sanangelo
« Reply #15 on: June 17, 2013, 07:33 PM »
It looks nice... What is the counters primary use going to be?
« Reply #16 on: June 17, 2013, 07:56 PM »
Sanangelo, it is going to be used as a desk.
More pics.
I had to lift up the top so I could access the pocket holes in order to secure the nosing.
88569-0
Dominos in, ready to glue up.
88571-1
« Reply #17 on: June 17, 2013, 08:01 PM »
Once the first section of nosing was installed and glue dried, it was time to set the final section.
88575-0
Nice tight fit, that never happens to me!
88577-1
Nosing done, now on to the backsplash.
88579-2
Offline ScotF
« Reply #18 on: June 17, 2013, 08:02 PM »
WOW!!  Beautiful work and detail!!  Awesome!
Scot
« Reply #19 on: June 17, 2013, 08:09 PM »
I decided to not nail the backsplash in the center section, since it was readily accessible from the bottom.  So I screwed it in, predrilling with the offset chuck on my C12.
88581-0
Then propped the splash down and held it agains the wall with some scraps.  Spent quite a bit of time with some scraps figuring out the angles of the walls (no kapex...) so the miters would be tight and it was worth it.
88583-1
Done!
88585-2
Offline neilc
« Reply #20 on: June 17, 2013, 08:11 PM »
That's really awesome work.  Thanks for all the pics...
What finish are you doing?
neil
« Reply #21 on: June 17, 2013, 08:19 PM »
More pics.  Now I just wait for the finisher to come in.
88587-0
This one is for Wuffles:  a clear shot of a pocket screw (the one going horizontally in the picture.. The other pocket hole is for the nosing.  You can also see the block that I glued an screwed in  to bridge the joint.  The joint was incredibly strong after doing this.  I was not shy at all when I had to put the blocking in to raise the top up, and didn't hear any type of popping nor saw any type of stress on the joint.
88589-1
« Reply #22 on: June 17, 2013, 08:23 PM »
Thanks Scot, thanks Neil.
Finish will be clear conversion varnish.
A big shout out to Qwas and his guide rail square.  It made setting up in the clients garage and cutting square parts ridiculously easy (as usual).
Festools used:
TS 55
Domino
RO 125
Ct 22
C12 and CSX
Offline Wuffles
« Reply #23 on: June 18, 2013, 02:14 AM »
Many thanks. I've ordered a jig from a shop here in the UK and look forward to playing with pocket hole screws in the future.
Offline sanangelo
« Reply #24 on: June 18, 2013, 09:49 PM »
Jon that looks great... I cant wait to see what it looks like with a finish on it... How accurate do you think the color in the photos are???
« Reply #25 on: June 19, 2013, 06:30 PM »
It's pretty dead on as far as color on my iPhone.
Finisher bagged out and canceled on me today!  Tying to make a good impression with this builder and stuff like that certainly doesn't help.
Jon
Offline obdoor
« Reply #26 on: July 01, 2013, 09:22 PM »
This work looks fine I wonder if I wouldn't have tried veneering the top to provide a thicker top veneer. Plywood is ideal for carcasses but wear and tear on tops makes me uncomfortable when it comes to every day wear and tear.
