@jarbroen makes sense! I'm sure I"ll end up plugging them.
@tjbnwi thanks man I'll check those places out, appreciate it!
@Mike G yes undercounts so that won't work, I think I'll end up plugging it. And thanks for your kind words!
@mrFinpgh thanks man! I appreciate all the kind words. Yeah I think I'll plug them after the box is glued up, or during the glue up. It should be easy enough to fix. Yep I am brushing ARS with foam brushes. Sanding w/ 500 in between coats and then brown paper bag at the end.
@ScotF haha thanks man! Appreciate it! I vacuum a lot. Having a roomba helps
@Michael K good idea! Will do that!
@Don T thanks man!!
@jarbroen I'll definitely have to check them out! A lot of times I'm also ordering other stuff from Rockler so it makes it easy but if the prices are that much cheaper it's worth a second order.
Thanks so much everyone for all of your comments so far I really appreciate it.
OH and the glass came in last night! for the doors.
I am hoping to wrap up the drawers completely this weekend and then I can start on the final piece - the two front doors!
Matt
