@Cheese nice! Gorgeous boards. Some are 14+" wide and super clear. I usually request 7ft maximum when I order boards because any longer than that is hard to maneuver in my garage.
@tallgrass yes! I am! They are kiln dried, and they were in my shop about 4 weeks before I milled them.
@Thompmd thanks! I'll clean it up, promise.
@RustE thanks man. haven't even gotten that far yet to be honest. I think a rabbet with clips is a good idea. Or - maybe just do a dado as if it were a sheet of MDF on a raised panel door, but have the dado go all the way out the bottom with some sort of retaining screw. That way I can replace them If needed, but the inside of the doors will still look good.
@shanegrilah I think you're totally right. I was talking about your comment with my wife and we were thinking to address it, we'd make the front legs curve out towards the front somehow - they'd still be under the doors when the doors are closed, but would provide more stability when the doors are open. Good call. thank you for your comment.
@derekcohen I've built lots of drawers! On a few of my projects. For the drawers on this one, I'm going to use box joints - curly maple for the fronts and sides, and either maple veneer plywood for the bottom, or re-sawed maple, floating with some room to spare (not glued in). In terms of the thickness, I'm going to go 5/8" since that's the maximum allowed by the Blum undercount slides. Both my wife and I really like those Blum undermount slides. I just ordered 7 of them from Rockler, 12".
@neilc Thanks so much! I know, the doors are what I've been worried about the most to be honest. I really worry about not only sagging, but the fact that they're only connected at the sides which are only 4/4. Maple is strong, but the doors are going to be heavy. One note is that liquor bottles won't go in the doors - the glassware will. But I do think it'll still be really heavy. I just ordered 8 of the SOSS 204 hinges ... I'm thinking 4 per door... anyone worked with those before and think it'll be strong enough?
Cheers everyone thank you for the comments.
I took Friday off work yesterday, and made a ton of progress in the shop. I laid and milled a ton of boards (emptied my 35 gallon dust bin twice already this weekend!) and have the following pieces milled, joined (used domino for the longer ones to help with flatness and alignment) and scraped (after the glue dried).
Today, it's all about trimming to final size and then drum sanding!
2x sides
6x shelves
2x vertical dividers
2x horizontal dividers
Bottom
Thanks so much everyone!
Matt
