Author Topic: [Project 33] Walnut and Cherry TV stand  (Read 6266 times)
Offline mattbyington
« on: May 11, 2020, 06:48 PM »
Hey team,
My wife came up with the design! It's for friends of ours.
The idea is that it's a little bit "modern" with a design on the doors.
So far I've only milled up the doors, we spent all day yesterday playing with different patterns on the doors to find out what we liked. Should be fun!
Matt
Re: [Project 33] Walnut and Cherry TV stand
« Reply #1 on: May 11, 2020, 06:49 PM »
Offline neilc
« Reply #2 on: May 11, 2020, 07:12 PM »
Cool - are you going to do an inlay in the kerf cuts?
« Reply #3 on: May 11, 2020, 07:29 PM »
@neilc yes sir that's the plan, cherry!
matt
Offline Gone
« Reply #4 on: May 12, 2020, 08:04 AM »
Your idea is interesting Matt, this is just a bit of info on the 2 woods you are using. Black Walnut will lighten and change to a range of dark to light caramel colours with age. Cherry will darken with age to similar tones.  So if a contrast is what you are looking in the project it will be there initially but diminish with age, really noticeable after the first couple of years. If subtle is what you're after use the 2 woods, if bold try a something different than cherry.
« Reply #5 on: May 12, 2020, 12:49 PM »
@kcufstoidi thank you so much for taking the time to write that up! I was looking for a bit more contrast, sounds like I should have used Maple :( or Holly.
oh well ... too late now!! :)
Matt
Offline mike_aa
« Reply #6 on: May 12, 2020, 01:14 PM »
Matt, Nice design and execution!
Mike A.
Offline mrFinpgh
« Reply #7 on: May 12, 2020, 01:22 PM »
It's not entirely too late!  A lot of folks will apply some dye to walnut as part of their finishing schedule.  That would be an option in this case, if you masked the cherry inlay and then applied dye to the walnut that should mitigate some of the aging effects that @kcufstoidi mentions.  Of course, you would need to figure out if that kind of color works for you.
Cool design.
Offline Rich Kline
« Reply #8 on: May 12, 2020, 03:06 PM »
@mrFinpgh and @kcufstoidi do either of you have experience with Festool Surfix Heavy Duty Oil/Wax?  I have made several walnut pieces finished with Surfix and I'm not seeing color change that I'm seeing on a number of my walnut cutting boards.   I think @JoryBrigham told me that the heavy duty had UV protection, but it's not even clear that the walnut needs to be exposed to light to change color.
Thanks for any insight.
Rich
Offline JoryBrigham
« Reply #9 on: May 12, 2020, 07:57 PM »
The Outdoor has UV protection can’t say for sure the heavy duty does Rich.
Offline mrFinpgh
« Reply #10 on: May 12, 2020, 08:21 PM »
I haven't used surfix, but from what I recall it's basically a hardwax oil finish. I don't know what you finish your cutting boards with @richklein but I think basically wood changes colors due to oxidation.  For the same reason, you can age cherry by letting it sit out in the sun or you can wash it with lye. So some finish is going to slow that down more than no finish or mineral oil finish.   I think that the sunlight exposure basically accelerates this process, and would guess that if you left your pieces out in the sun for a couple days they would begin to show some signs of fading.
Offline Gone
« Reply #11 on: May 13, 2020, 09:20 AM »
I use hard wax oils all the time. The only thing that offers any type of UV protection is a pigmented oil that actually blocks the UV. Any clear oil and you're just shouting in the wind no matter BS the manufacturer says. The fact that most don't know walnut lightens with age and cherry is very deceiving being light when first cut is why I mentioned it in the first place. Anyone working with wood should understand the natural ageing process and study by looking at older pieces. Saves long term disappointments and allows you to use the characteristics for long term design, this is unless you're just making firewood. UV protection or not all woods will colour age over time and its a process thats almost impossible to stop.
As far as sunlight exposure, cherry can show darkening in several hours, not so with Black Walnut. It takes time. Also be careful with maple especially with long term storage of planed product. Exposed ends and sections will noticeably darken just sitting in the shop. These dark section are hard to sand out and often take a light planing to restore an even colouration.
« Reply #12 on: May 13, 2020, 01:12 PM »
@mike_aa thanks!
@mrFinpgh good point thanks I will look into that!
Both doors are done now, finally! Here's a pic.
Now to start on the main carcass.
Matt
Offline rmhinden
« Reply #13 on: May 13, 2020, 01:40 PM »
Matt,
Nice work.
I think you are going to need a bigger garage :-)
Bob
Offline tallgrass
« Reply #14 on: May 13, 2020, 02:56 PM »
Did you use the saw or a router?
« Reply #15 on: May 13, 2020, 03:02 PM »
@rmhinden definitely haha and thanks!
@tallgrass for the grooves for the inlays? I used the router! OF1400 with an undersized 1/4" plywood bit from Whiteside!
Matt
Offline tallgrass
« Reply #16 on: May 13, 2020, 03:22 PM »
OOPS, I did not think about that. :) For the groves. I could see using the saw. I have used both on the same grooove in the past. The saw to score and prevent tear out and the router to remove the material. Mounting the router on the rail make that a snap. Great work by the way.
« Reply #17 on: May 13, 2020, 03:36 PM »
@tallgrass makes sense to me! I had the router running on the track while doing these, worked well! They're only 1/4" deep so 1 pass was all it took!
« Reply #18 on: May 21, 2020, 04:08 PM »
The base is done
Offline Svar
« Reply #19 on: May 21, 2020, 04:10 PM »
Is wood grain running perpendicular to the feet length? It sure looks that way.
« Reply #20 on: May 21, 2020, 04:24 PM »
@Svar yes it is, is that bad? I heard from one other person (I posted this picture my Instagram as well which is @matthewbyington in case anyone is on there, too).
And someone gave me the bad news, too, that this wasn't quite as strong as if I had turned the grain 90 degrees.
Whoops! I guess you live and learn.
Do you think it's bad enough that I should re-do it?
Matt
Offline Svar
« Reply #21 on: May 21, 2020, 04:29 PM »
Feet will be brittle. Don't drag the stand over the floor [big grin]. Over long time cracks might develop. It would have been fine for a jewelry box, but not for a TV stand. I would redo it.
« Reply #22 on: May 21, 2020, 04:53 PM »
Got it. Thank you @Svar i really appreciate you taking the time to educate me on that!
Matt
« Reply #23 on: May 21, 2020, 05:09 PM »
With the grain running in that direction, they become cleavage planes when a sudden force is applied as a side load.
I really like the looks of it but as Svar said, better to save that for a jewelry box.
« Last Edit: May 21, 2020, 05:41 PM by Cheese »
« Reply #24 on: May 21, 2020, 05:13 PM »
@Cheese got it that makes perfect sense! Appreciate you chiming in!
Great to learn this for the future.
Right now I am in a bit of a holding pattern as I am out of wood :) I always order from woodworkers source.com and I placed another order for 20 board feet of cherry and 20 board feet of walnut on May 8 but they haven't shipped it yet...
So I hope to make more progress but am waiting on wood...
Matt
Offline Svar
« Reply #25 on: May 21, 2020, 05:29 PM »
You can find horizontal feet grain direction on some traditional furniture as shown below, but those feet are wide and short, made of two pieces connected at right angle.
Offline lshah72414
« Reply #26 on: May 21, 2020, 05:35 PM »
Am I misunderstanding, are  you guys saying the leg grain should be perpendicular to floor and not parallel?
Offline CeeJay
« Reply #27 on: May 21, 2020, 05:49 PM »
The leg grain should be parallel to the long side of the leg.
If you really like the look of the horizontal grain (and it does look nice) you can always consider putting a veneer on but for a curved profile leg that will be hard to achieve a nice look on the outside corner.
Offline lshah72414
« Reply #28 on: May 21, 2020, 06:02 PM »
Got it . Thank you
Offline Vondawg
« Reply #29 on: May 21, 2020, 07:05 PM »
Matt please don’t add any dye to those pieces Of beautiful walnut, with all that purplish color (usually from a more “air” dried process) let the greatness shine thru.
Nice job!
Offline FestitaMakool
« Reply #30 on: May 21, 2020, 07:09 PM »
I think the base look very good!
I do agree that the legs might have a weak point grain going parallel to the floor.
- But it looks good  [wink]
I’m not familiar with working with the same wood as you do over there. Some wood can handle a lot of stress, but usually that means fine grained (or crowded as we say) This looks like it is far in between.
Could drilling in a long and fairly thick round dowel glued like a long tenon almost as long as the feet itself rescue the design?
The dowel wouldn’t be visible either, otherwise you could dadoe in a piece of wood on the rear side as well and glue it in as a part of the (rear) design.
Tried to do a very quick sketch up:
« Reply #31 on: May 21, 2020, 08:12 PM »
@Vondawg I won't, promise!
@FestitaMakool that is a great idea!! I have some of the tapered / stepped wood dowels (can't remember the name right now) but that might work super well! Good idea!!
Matt
Offline rvieceli
« Reply #32 on: May 21, 2020, 08:32 PM »
@mattbyington Same here no dye or stain on that wood. Looks nice.
I'm actually liking the grain on the legs. I vote for wild and crazy  [eek]
Pull the legs. Split them right down the middle top to bottom down the narrow edge on your band saw. Now take a piece of walnut with the grain vertical and laminate the three pieces together. I'd make the walnut thicker than the stretchers. Shape everything back and re-attach. you will wind up with thicker legs but they should be strong enough.
Ron
« Reply #33 on: May 21, 2020, 09:00 PM »
What rvieceli says is a good idea!
I presumed you’d glued the legs to the frame - mortise & tendon or Domino perhaps?
Whatever you do, the legs look great as is!
I’m with the no dye or stain group here - But don’t listen too hard, it’s your project! [wink]
Offline Gone
« Reply #34 on: May 22, 2020, 07:32 AM »
Matt your legs are fine, what others are missing is that the grain in the curly maple usually runs about 90 degrees to the curl. I use a lot of curly maple and never had an issue. Your weakest point in this case is the connection between the walnut horizontal and the vertical curly maple leg.
« Reply #35 on: May 22, 2020, 11:11 AM »
@rvieceli not a bad idea thank you! I'll noodle it....
@FestitaMakool oh yeah those puppies are SUPER glued on :) 8mm domino through....
@kcufstoidi thanks, that's good information. That connection has an 8 mm domino through it,40mm long.
I'll noodle on it team...thanks... I'll hopefully get some more work and pictures this weekend!
Mr. Fedex informed me yesterday the wood has fINALLY shipped and has a miraculous estimated delivery date of this Saturday (tomorrow) so I may just be able to make progress this long weekend!
Matt
Offline JimD
« Reply #36 on: May 22, 2020, 11:31 AM »
Nicely done.  I wouldn't remake the legs.  They look like they are pretty thick and they are not super narrow so that will help despite the non traditional grain orientation.  TVs are also pretty light these days.  My guess is it will be fine.  If somebody light sit on it, then I might remake them.
If you want to get a feel for what it will take to break them you could make one from scrap and hit it with a deadblow.  My guess is you will have difficulty getting it to break.
Offline Gone
« Reply #37 on: May 22, 2020, 11:38 AM »
Matt another warning, don't trust super glue with wood. There is an extreme amount of BS surrounding super glues and wood spread by forums like this along with instagram and Youtube super heros. With normal seasonal changes the joints will fracture. Unfortunately found this out the hard way. The glue becomes too hard and brittle, doesn't take even subtle wood movement well. The only place it works good is filling hairline cracks and as a temporary bond used it conjunction with a PVA.
« Reply #38 on: May 22, 2020, 11:54 AM »
@JimD thanks man! Yes the legs come from 6/4 stock of solid Cherry, so they are definitely thicker than the other pieces in this build (4/4).
@kcufstoidi I never do! This whole build was Titebond 2. Which is my go-to. I rarely make outdoor furniture so TB3 isn't really needed.
Thanks so much for all the advice everyone!
Matt
« Reply #39 on: May 22, 2020, 12:35 PM »
For all of these reasons I also quit using super glue for securing magnets in wood. After some time the bond line fractures and the magnet is sitting somewhere else. This becomes a problem if the magnet is used as a hidden latch or as a hidden door opener.  [eek]
« Reply #40 on: May 22, 2020, 07:22 PM »
Good to hear that some more are a bit sceptical to superglue everything  [wink]
Although, hunting the right glue for the job isn’t always straightforward.
Looking forward to see what kind of solution you came up with!  [smile]
Offline Svar
« Reply #41 on: May 22, 2020, 07:43 PM »
It is not curly maple. It's regular cherry with grain direction perpendicular to the length.
Legs might be fine now, but over time checks on the end grain may develop. It's inconsequential for parts with longitudinal grain direction, yet could result in failure in this case.
When I decide to invest my time to build a custom piece I think beyond now or this purpose or even this climate. Who knows where the piece will end up in 10 - 20 years, what will sit on it, who will lean against it or move it.
« Last Edit: May 22, 2020, 07:59 PM by Svar »
Offline CeeJay
« Reply #42 on: May 22, 2020, 08:07 PM »
This piece is going to be stunning when it’s done Matt. Really nice work.
Offline Gone
« Reply #43 on: May 22, 2020, 09:03 PM »
Well dip me in tar and cover me with feathers Svar you are right and I f---ked up big time with my assumption of curly maple. Should have actually read the whole thread instead of having a senior moment. That does have the potential for failure especially with the stress induced from the dominos.
« Reply #44 on: June 07, 2020, 04:19 PM »
Hey team,
This project is still underway! Long story short ... I've had some serious problems with FedEx.
I ordered 20 b.f. of walnut and 20 b.f. of cherry on May 8 as I was out - it still hasn't come. It's a long story, but FedEx has either lost it or is totally backed up.
Woodworkerssource.com sent me more (they are great) free of charge, but that still hasn't come either and surprised the ETA from FedEx. I think they're backed up on big packages.
Anyways my wife and I drove to the distribution center where it's being held and they were able to find 1 out of the 4 packages (at this point there is 40 b.f. of both walnut and cherry, across 4 packages (20 bf each) in their distribution center).
The other 3 packages are still nowhere to be seen. Anyways - this one was cherry so I made up the back panel and 4 shelves with it. Getting closer ...
Hopefully more pics when I can get more wood -out again.
Matt
Offline jobsworth
  • Festool Baby.....
« Reply #45 on: June 07, 2020, 06:22 PM »
@mattbyington
I had a simular issue with USP. Bought a conturo, never arrived, called the dealer they got a hold of UPS who said they lost it for the dealer to put in a claim. The tracking showed it arrived at their distribution center about 40 mins from my house. So I drove out there and they had it on a trailer marked on Hold. No reason why just on hold stored in a trailer and ready to be shipped back.
 Anyway I got it from them there. Still no explanation as to why they had it on hold.
« Reply #46 on: June 09, 2020, 04:04 PM »
@jobsworth glad to hear that it is not only me!
OK well team as of last night, I have ALL the pieces cut and sanded for the cabinet - except the middle divider (out of wood again).
Tonight I am going to start on the joinery so should have some "more exciting" pictures soon with dry fits and mock ups!
Matt
« Reply #47 on: June 11, 2020, 08:53 PM »
Offline rmhinden
« Reply #48 on: June 11, 2020, 11:44 PM »
Looks great!
Bob
Offline CLRFXR
« Reply #49 on: June 14, 2020, 10:36 AM »
Matt, I have followed most of your projects posted on here.  I really enjoy everything you do along with all the advice given by others during the build.  Seeing that you get most of your wood online I hope you think about a post on how you do your “Panel build up” process. Keep up the good work and looking forward to all your future projects.
« Reply #50 on: June 14, 2020, 01:15 PM »
@rmhinden thank you sir!
@CLRFXR thanks so much! Okay good idea! I'll start a new thread about that, I hope it will be helpful!!
BIG GLUE UP just now guys!!!
« Reply #51 on: June 14, 2020, 01:16 PM »
Offline Rob Z
« Reply #52 on: June 14, 2020, 01:32 PM »
Hey Matt
1.  I like the inlay on the doors
2. Clean, well-organized shop   [smile]
3. I wish I could borrow your shop cat to track down the little critters that sneak into my garage shop  [big grin]
I have also  had a few head scratching moments with UPS/Fedex.   [eek]
Offline Svar
« Reply #53 on: June 14, 2020, 02:35 PM »
Is your back panel solid ~ 20 mm wood? How is it attached? Floating in a groove?
« Last Edit: June 14, 2020, 07:51 PM by Svar »
Offline Roachmill
« Reply #54 on: June 14, 2020, 03:43 PM »
Very clean and tidy cabinet. If that's all solid wood I hope you've allowed for a bit of movement as there's some wide boards in there.
It looks like the feet have the grain running horizontal to the floor... I'd worry about them snapping or splitting when someone shoves the cabinet...
Offline Don T
  • Phoenix, Az
« Reply #55 on: June 14, 2020, 07:17 PM »
It look great Matt!  Can’t wait to see it completely finished.
« Reply #56 on: June 15, 2020, 12:54 PM »
@Rob Z
1) Thanks!
2) Thanks again!
3) hahahah. I had to look again - I didn't know she snuck into the pic!!
@Svar it is solid Cherry, yes. This whole build is solid wood - no plywood and no metal fasteners. It is domino'd in to the top, bottom, and sides with 3 dominos per. I know the traditional comment applies about wood movement - trust me, if I've learned anything from this forum, it is that. I haven't had a problem with pieces inside an air conditioned / heated home (in California, not humid at all) so I didn't account for it. I am building this piece for free for a good friend of mine, so there is no "client" if it does break. It's all just for fun for me.
@Roachmill Thank you! See comment above and please do not shoot or otherwise harm me :)
With regard to the feet -go to page 1, we had a whole discussion on it :)
@Don T thanks!!
Matt
« Reply #57 on: June 15, 2020, 12:55 PM »
Offline RKA
« Reply #58 on: June 15, 2020, 04:40 PM »
It looks great Matt!  I love the legs with the horizontal grain.  You have a nice design sense, very clean and modern with subtle details that really look great.
-Raj
« Reply #59 on: June 15, 2020, 05:36 PM »
Looks great!
Looking forward seeing the front!
Cherry is quite rear here, but we had once cherry flooring - I loved the warmth and the look of it - we did have a lot of positive comments about it too, as the “standard” flooring here is oak, which is nice but the warmth and play in cherry is special.
Offline Rich Kline
« Reply #60 on: June 15, 2020, 05:59 PM »
@mattbyington the piece looks amazing.  I'm actually building the woodwhisperer grandfather clock out of cherry.  What finish did you just apply?
Thanks,
Rich
Offline AnthonyE
« Reply #61 on: June 16, 2020, 10:31 AM »
That's a great looking cabinet.  I like the design a lot.
You've received a ton of great advise here especially about wood movement and grain orientation.  In general you rarely see modern designs like this made of solid wood without a frame and panel construction, especially the back panel and doors.  I worry the doors will eventually cup and not close correctly with such a large panel unsupported by a frame or battens.
With such a well setup shop I wouldn't hesitate using plywood for such builds with solid wood edging.  The case, doors, and back panel would be great choices for plywood panels.
Also one last comment, I wouldn't hesitate in making your shelves thinner.  They might be just a bit chunky for the design and you'd be surprised how strong wood really is.  You can get away with much thinner shelf stock than what you typically see people doing.  Mike Pekovich is a big advocate for making parts much thinner than you think you can get away with which really adds to the overall aesthetic of a piece.
And good god, leave a little dust behind once in a while!!! That Tesla I'm sure would like to know that someone is actually doing some woodworking in that shop.
« Reply #62 on: June 19, 2020, 05:11 PM »
@RKA thank you so very much!!
@FestitaMakool yes I love cherry too! Such a classic!
@Rich Kline thank you so very much! That is awesome! I applied General Finishes Arm-r-seal in Semi-gloss!
@AnthonyE thanks so much! I totally understand the concerns and agree with them. The doors cupping is one worry of mine, absolutely. I didn't want the doors made out of plywood because I wanted that sexy solid walnut and cherry inlay look, but the back panel in hindsight probably should have been plywood instead of solid cherry hahahah it took 6 boards!
The shelves are definitely too thick. Agreed on that one. I lived and learned. I had already finished them when I found out. Oh well. Next time, I'll know!
Here you go team - final pictures, this one is a wrap!!
Matt
Offline CeeJay
« Reply #63 on: June 19, 2020, 09:59 PM »
Beautiful work Matt - well done!
Offline grobkuschelig
« Reply #64 on: June 20, 2020, 01:39 AM »
It really turned out great!
Can’t wait for the next beauty you furnish. :)
Offline tallgrass
« Reply #65 on: June 20, 2020, 03:42 AM »
very nice
Offline Alex
« Reply #66 on: June 20, 2020, 04:26 AM »
Really nice Matt, I hope everything stays in shape as intended.
« Reply #67 on: June 20, 2020, 10:17 AM »
It came out really nice Matt. What a nice present to receive.  [big grin]
Also, next time you could consider some tempered glass shelves if there will be internal LED lighting. For instance, a 1/4" thick tempered glass shelf 18" x 14" will support 28 pounds.
Offline mike_aa
« Reply #68 on: June 20, 2020, 11:51 AM »
Matt,
Super work!  That turned out to be a terrific build!  My compliments to your better half on the design!
Please keep the pictures and progress notes coming.
Thanks, Mike A.
« Reply #69 on: June 23, 2020, 11:21 AM »
@CeeJay thank you!
@grobkuschelig thanks! Appreciate the support!
@tallgrass thank you!
@Alex thank you and me too!
@Cheese thanks man! Good ideas ... I like that. Would look great too.
@mike_aa thanks so much Mike! Yeah she did awesome on the door design!
I think that wraps it up for this one everyone. Thanks so much to those who viewed and commented, I learned a lot during this build.
Still deciding on the next project.... maybe I'll start Project 34 soon..
Matt
Offline six-point socket II
« Reply #70 on: June 23, 2020, 11:29 AM »
Love it, Matt!
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #71 on: June 23, 2020, 04:27 PM »
Offline doug H
« Reply #72 on: June 24, 2020, 02:07 PM »
Beautiful work! Thanks for the inspiration.
« Reply #73 on: June 30, 2020, 03:22 PM »
Thanks Doug!
Offline notenoughcash
« Reply #74 on: January 28, 2021, 05:20 AM »
@mattbyington love the design, especially the inlay in the face [big grin].  i might pinch in for my A-level DT project, and also can i use the pictures in my moodboard?
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
« Reply #75 on: February 03, 2021, 09:37 PM »
@notenoughcash thanks so much! No idea what a mood board is but sure :)
Matt
« Reply #76 on: February 04, 2021, 03:48 AM »
@mattbyington
cheers.
a mood board is basically a big sheet full of pictures of things you'd like to make, and then you draw insparation from them for your final product.
Offline zachjowi
« Reply #77 on: February 12, 2021, 09:39 PM »
Inlay on the face looks awesome
