Thank you
@Cheese I will post a picture with the VAC-SYS bases on. I still have to install the teflon cutting board to the second base and I'm in business with some ways to clamp boards finally
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
I still have a lot to do on the table.
- Install the VAC-SYS pump on a drawer for easy access,
- Manage the tubes in a way that it's going to be easy to remove and put back the bases without having to deal with the tubes all over the table,
- More drawers on each side to store the DF500 and eventually the DF700
-Shelves for the mini-systainers,
-Vertical drawers for the cubes to goes all the way on each side. I will Probably store my table saw blades and accessories in those drawers,
-10 thin drawers for hardware,
-Install some power outlets,
-Finally, rounding corners, sanding and put a few coats of hard wax.
Did I missed anything? Oh yeah a kraft paper roll holder
![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
The next project will be a easy to remove/light MFT top to sit on it
I didn't put dog holes on the actual top because it's a torsion box and I would have to make holes on both sides.
![Sad [sad]](https://www.festoolownersgroup.com/Smileys/default/sadsmiley.gif)
More to come soon..
