Author Topic: What - non Festool - tool / workshop related gizmo/stuff did you buy today?  (Read 139847 times)
Offline doug H
These recently arrived from Wiha.
Offline CeeJay
Got this for my little Makita router:
Offline online421
Comatic DC40
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55-300
SCM 5 RCS1100
SCM TI145EP
Comatic DC40
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, LEX3, OF1010, OF2200, CT36, VAC SYS
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
Offline FestitaMakool
This is nothing I really needed, but brand new for $100 I couldn’t let it go..
Will be handy with it’s very small compact size, dampened handle and all. (It’s Makita’s CXT 10,8/12V)
Offline six-point socket II
Hi!
First, a gift from a friend, after mine hit the ground in a rather unlucky manner. Means really a lot to me, because I really love these. And props to Festool for also looking for one for me, but sadly they are gone.
A second package came from Germanys oldest, still manufacturing/producing file factory - by their own account. ( http://www.feilen-leist.de )
I ordered 6 quality workshop files (150mm) fitted with quality handles (110mm). And a set of 6 quality warding/key files in a tin box.
Set of quality warding/key files in tin box.
Quality workshop files.
Flat cut 2 and cut 3 150mm/110mm
Triangular cut 2 und cut 3 150mm/110mm
Half-round cut 3 150mm/110mm half-round side
Half-round cut 3 150mm/110mm flat side
Round file cut 3 150mm/110mm
The first impression I have of them is really good. Quality product, great communication/service and fast delivery. I absolutely love the fact that I can combine any file length with any handle length.
Now I have to use them to say more about them. ;)
Third package was a really necessary flat suction pump. (Kärcher SP2 Flat) It can start pumping and will pump water levels as low as 6mm and will pump until theres only 1mm left. This is necessary "liability insurance" for a project that is coming closer every day with large steps.
Kind regards,,
Oliver
Kind regards,
Oliver
Those were nice Oliver!
Would you please share where you ordered them? I followed the link, but couldn’t find that they had a web shop?
The fact that you can order the length you need, and top it with a wooden handle is just great. I definitely would like the small set and a few larger ones.
Regards,
Stig
Hi Stig,
just E-Mail them, they get back to you with a price list and TOS. They sell directly to end users, but they don't have a designated online shop.
Kind regards,
Oliver
Kind regards,
Oliver
Well, that’s kind of nice. I’ll certainly do as there’s only very very long files with even more horribly large plastic handles available. One very seldom hold a file just by the handle.
It certainly looks good with those wooden handles as well!
Thanks!  [smile]
Offline JD2720
A Woodpecker Slab Flattening Mill arrived today. I ordered it before everything shut down & with all that has gone on I had forgotten about it. It arrived before they had stated it would. I believe when I ordered it, they said it would be delivered the 1st part of June. Woodpecker took a lot of care in packaging it. It arrived in great shape. Assembly was easy. I am very pleased with how well it slides. Now I need to get a planer bit ordered.
Online Cheese
I just received 4 Anza Elite Felt rollers that have been highly recommended for yielding smooth finishes. We'll see how they work.  [big grin]
On the other hand, I've used these Purdy Parrot Mohair rollers before and every time I've had dismal results.  [sad]  [mad]
« Last Edit: May 31, 2020, 02:56 PM by Cheese »
Offline Rob Z
I think this is the first time I have seen this WP item set up, other than on their website .  That looks really well-made and a good design. I'm also a bit envious of what appears to be a large shop.  [big grin]
(Attachment Link)
On the other hand, I've used these Purdy Parrot Mohair rollers before and every time I've have had dismal results.  [sad]  [mad]
(Attachment Link)
From my experience, Anza’s look just right, Purdy’s not so much - if near spray finish is the goal.
The right paint/lacquer and technique should yield near spray paint finish with Anza.
Offline jobsworth
  • Festool Baby.....
Took a trip back to Ca. Stopped by Anderson ply to see Allen K and have him take a look at my TS55. Its old , dropped a few times and I wanted him to check it out makes sure everything is running right with it.
So He checked it out said all I needed was a new blade which I bought (I recently adjusted the toe in on it).
Picked up a couple of things, Bessey spring clamps, T handled edge band cutter, and one of Dons MFT squares. Allen double checked to make sure its square, it is. So today Im going to use it to check my MFT, I already used a WP 450CM triangle square to set it. But I like the Anderson one as its made from 3/4 material
Offline rst
Ordered a Dewalt DW744org mobile table saw stand to put my Metabo 36/18 table saw on from the HD.  Received the saw and two batteries last week.  Charger and another couple batteries should arrive tomorrow.  Can't wait to give it a spin.  Free plugin transformer is free as a Metabo incentive, but 8-10 week lead.
Offline GoingMyWay
I got a Striking Knife from Lee Valley.
Inquiring Minds Want to Know
Online Cheese
Series 221 (100x 221-412), (110x 221-413) and (25x 221-415) + 4 adaptor plates/mounting plates/carriers to use the series 221splicing connectors inside distribution panels
Geez Oliver, @six-point socket II  I just redid some landscape lighting using the new Wago 221 connectors. They are so much nicer than the original push-on versions. If you ever think you'll need to redo the connection, I'd just put in the 221 connector straight-away.
Wago 221 vs Wago push-on.
Oh, yeah!  [big grin] And, you can finally mix solid and stranded wire/ respectively simply use one connector for both types.
Kind regards,
Oliver
Kind regards,
Oliver
Online Cheese
Ya I forgot that part...that can be a huge plus for some projects.  [big grin]
Offline Alex
I added the Makita JR3070CT recipro saw this weekend. Been aching for a long time to get one, nothing's gonna get in my way now because this 1500W powerhouse cuts through anything.
Ofcourse it came in this dumb molded case, I can't even get the cord in there, nor do the blades fit in the bottom left corner that was designed to hold them. I have to find me a nice systainer for it asap.
« Last Edit: June 09, 2020, 04:04 PM by Alex »
Offline Gregor
I finally got around to dig out some pictures and a short video clip of the ratcheting action on that adjustable wrench.
'Hornbach only' when searching for the product number... or can you point me to another source?
Hi Gregor,
Here are some other sources. :)
Hersteller-Link: https://www.wgb-werkzeuge.de/produkte.detail.html?id=9351&Rollgabelschlüssel+mit+Ratschenfunktion
Amazon -> https://www.amazon.de/Rollgabelschlüssel-Ratschenfunktion-WGB-Das-Werkzeug/dp/B077ZZ7KS8/
Independent -> https://www.grube.de/wgb-rollgabelschluessel-mit-ratschenfunktion-17-244-01/
Kind regards,
Oliver
Kind regards,
Oliver
Offline RKA
I only use the Wago 221's, even if I don't think I'll have to revisit it.  I love how easy they are to work with and how compact they are!  And you know, every time you do something and say to yourself, I won't be doing that again, something will come up and you WILL be doing that again!
-Raj
Offline Frank-Jan
I got myself a pair of scissors yesterday:
I need to cut leadax lead replacement soon, and when I was at the roofing supplies store I asked if they had a good pair of shears to cut it; because my previous experience with the stuff wasn't "fun" and they didn' have the width I need.
Their regular shears were out of stock, but they did have an expensive version; after testing them I got them anyway (these were € 55 +vat)
Offline RKA
Those Kai scissors are really really good!  Good choice!
Today the FedEx person dropped this off.  All I can say is where has this been all my life?!   It’s a right angle M12 cordless impact wrench advertised at 220 ft lbs.  Next to it is my 1/2” torque wrench for scale.  They may be stretch the truth a little with that spec, but I quickly put it on some lug bolts torqued to 90 ft lbs and it spun them off with barely a rattle.  So it’s got some ooomph!  This will come in handy in all the places an impact wrench (even Milwaukee’s stubby) won’t fit.  Later this year it will be new rear brakes, shocks all around and 8 new control arms up front, end links and tie rods, most of which have 170k miles on them and a timing belt job.  This thing probably won’t get used anywhere else other than the car, but that’s fine with me!
-Raj
 [thumbs up] [drooling] [thumbs up]
Kind regards,
Oliver
Kind regards,
Oliver
Offline rst
Increased my Milwaukee M18 collection, drywall router and straight 1/4" grinder.  Bought the offset grinder a while ago but sometimes access is limited with that one.  Also bought a drill powered rivet nut setter, 8/32 - 1/4.
Online Cheese
Purchased a Mafell F 160 rail...sweet...somethings are better than the Festool offering, while others are not.
Offline Vondawg
@Cheese are you as happy with the Mafell55cc as their jigsaw ? I’m looking at the impressive features
Online Cheese
Yes I am @Vondawg  I just got a chance to try it out yesterday. I was ripping some 5/4 mahogany and the first thing I noticed was the power. No rattling or fuss, just push it down the track. I have some 2x cedar to rip today along with some 5/4 birds eye maple, it'll be interesting to see how that goes.
You're right about all of the features...blade changing is actually enjoyable.  [big grin]  Also when changing the blade angle it's done with a single knob however it's locked in at 2 points. The scoring feature is really neat and so easy, just the flip of a lever that sits next to your thumb. The adjustment for sloppiness on the track is slick also, they're detented so they can be adjusted in very small increments.  I've never liked the adjusters on Festool track saws as they were not linear, the saw was either too loose or too tight.
Offline Vondawg
yes the blade change feature leaves no reason to not switch one out when needed And the scoring looks very interesting...I’m “in”
Thanks....nice review in the other post very helpful
« Last Edit: July 01, 2020, 02:38 PM by Vondawg »
