Author Topic: Wooden (zinc) gutter casing, thoughts?  (Read 519 times)
Online threesixright
« on: September 17, 2019, 12:58 PM »
Hi All,
Bear with me [embarassed], I made a rough sketch  (cross section) of a new to-be-build casing for my gutter. Dimensions are not exact, but good enough to give some idea.  The wall is ~ 14 meters long and roof is sloped (7 degrees). The casing will be hanging just over 2200 mm above ground. The roof beams are space ~ 600mm apart.
Notes:
1. The zinc gutter will me mounted on metal hooks, these will be screws to the structural roof beams.
2. The support boards (~ 21mm thick) I want to screw with 3 screws to the beam, they are there to make the (horizontal boards) a level support to screws to.
My questions:
1. The casing I planned to make, will be 21mm okoume plywood (and treat it for outside). Is okoume plywood a good for this?
2. My concern is the structural construction of the horizontal  and vertical boards. I was thinking to use some (SIPO) domino's (8x50 domino any good?) to connect to vertical board to the horizontal board and glue it (Titebond III). Would this be sufficient?
3. If using the domino's: what would be better to use the domino's in a vertical or horizontal position? I also feel something is sill missing, maybe a square 50x50 (mm) beam that serves as extra support in the corner?
3. Then to the screws, I wanted to use SPAX not sure about the size: 4.5x70 to 5.0x70? Something better (longer, thicker?)?
Would love to hear your thoughts how to do this (the right way  [laughing])!
Thanks a lot!
Offline RKA
Re: Wooden (zinc) gutter casing, thoughts?
« Reply #1 on: September 17, 2019, 02:03 PM »
How are these gutters normally secured and what led you down the path of boxing them in like this?  I'm assuming these are commercially available gutters?
I don't do much structural work, but my first concern is putting a ladder against the top edge of that box.  I wouldn't want to rely on a couple of dominos and 19mm ply to keep the top of the ladder stable.  Even if it works on day 1, think 20 years in the future.
Relating to the plywood, I'm not familiar with the stuff.  Even if it was rated for exterior use I would not be a fan of using it where it would be constantly exposed to moisture, but that's probably my own bias.
-Raj
« Reply #2 on: September 17, 2019, 03:04 PM »
@RKA
The gutters are placed in hooks. That will not change.
It's about the casing (I found  okoume plywood is often used ~ 22 mm FWIW), it's similar of what was there before the rebuild. Unfortunately the demolition crew removed the construction before I could document it.
I agree about he ladder, my concern was also its not strong enough.
I looked around but couldn't find clear construction drawings how this is normally attached.
Here a photo how it would roughly look.
