Author Topic: Breakfast nook bench(Advice needed)  (Read 3467 times)
Offline juststartingout
    • https://www.instagram.com/aq_designworks/
« on: April 30, 2015, 12:20 AM »
Hi all,
I'm putting together a breakfast nook bench for my kitchen.  The bench will open on the top for storage under the seating area. The project will be made from mostly 3/4" A1 Maple plywood, the top will be bread boarded with poplar and the whole project painted(likely white).
My question is about joinery.  I'm debating on whether I need rabbets on the end pieces to set the carcass into with glue or should I just use butt joints with festool dominoes?  I can use pocket screws too, but I'd like to use something a bit stronger as I'm imagining this piece taking lots of abuse from kids and folks climbing in and out of the seat.
I know I'm likely over thinking this but I want to make sure it comes out nice and any experience out
Thanks,
Oscar
MFT3, TS55, CT 26, OF1400, RO90, RO150, Carvex PS 420 EBQ, Domino 500, and dreaming of a Kapex.
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Breakfast nook bench(Advice needed)
« Reply #1 on: April 30, 2015, 08:32 AM »
Dominos, glue and pocket screws. The pocket screws are more a clamp in this situation.
« Reply #2 on: April 30, 2015, 01:16 PM »
Thanks TJBNL.  I dind't think of using both.  Dunno why not.  Great suggestion.
Offline johnesher
« Reply #3 on: May 18, 2015, 06:23 AM »
I just finished mine, except for the drawers, electric outlet and toe kick trim. I used 3/4" MDF for the top since I knew we were going to paint. Put a round over on the exposed edges and I think it'll be durable enough.
« Last Edit: May 18, 2015, 08:08 AM by johnesher »
Offline TheTrooper
« Reply #4 on: May 18, 2015, 07:20 AM »
Looks great John. What angle is the seat back?
RO90, RO150, DTS 400, LS 130, CXS, TS 55 EQ, CT 36AC, OF 1400,  Parallel Guides, Kapex Miter saw,  3 MFT Kapex tables, C18
Offline johnesher
« Reply #5 on: May 18, 2015, 08:08 AM »
Thanks. 5 degrees on the back as well as the seat.
Offline Hud
« Reply #6 on: May 19, 2015, 11:23 PM »
I made a large bench for a bay window in two parts that had display area on the ends and storage under the seating area.  I used 18mm Baltic birch edged with poplar for all visible parts and high density particle board for all that were not visible.   It was supposed to be painted but when customer saw it she decided to varnish.  I tis fastened with a combination of screws, pocket holes with screws, dowels and biscuits to minimize drift while setting the screws.  I did this before my introduction to Festool, the track saw would have saved me a lot of time.
