I did some research last year when I replaced my service and electrical panels.
In the USA, there are two different styles readily available.
1-Those that are plug in devices that consume 2 spaces in the electrical panel next to your breakers, and as such it would need to be UL approved for your panel, which I believe limits you to the same brand as the panel.
2-Those that come with attached wires for wiring into a breaker. This allows you to choose any brand you want but they attach to the side or bottom of the panel.
I have one of the plug-on type devices in each of the electrical panels in my system. Which includes 2 inside the house, and one inside the garage. On the outside of my house, at my service disconnect, I installed the largest rated unit I could find, and it mounts to the underside of the box. I also have one mounted at the electrical disconnect for my heat pump/AC Condenser unit.
Why so many? They each serve different purposes. The ones in the panels, are there to stop the spikes that occur inside my house when motors turn on or off (fridge, vacuum, microwave, shop tools, etc) from getting to the Arc Fault and GFCi breakers that are inside my panels. If you look at the fine print from the manufactures, they HIGHLY recommend them anytime you have any breaker that contains electronics. In fact the 2020 NEC code requires that each house has at least one.
The one at the AC is there to suppress the spikes from that specific device since it’s the largest motor in the house, and these devices work best when they are as close as possible to the source of the spike.
The big unit at the combined Service panel is there to keep spikes on the main utility lines from getting into my house.
So first figure out what you want them to do, and then figure out which makes the most sense.
