Would it be suitable to use Dominos for fence construction? I'd like to use Dominos to fasten the horizontal boards to the posts, and also the fasten on center on width the vertical boards to the top and bottom horizontal boards. Would give a nice clean look imo with no nails or bracket hardware, and with minimal spacing between the verticals, would give a lot of privacy, and not have one ugly side and the other pretty. Both sides would be the same/symetrical that way. I don't like the staggered board fence look where you create a semi privacy, where you can't see thru looking straight on, but is viewable in ones yard at an angle.
Or am I missing something in the suitability of using Dominos for this purpose, maybe not so much for fastening the verticals, but I'm unsure about the horizontals being the right method fastening them to the posts? I would be using 6X6 posts, 2X4 horizontals, and 1X6 for the verticals. Any thoughts appreciated.
I realize that SIPO Dominos would be needed here, and hopefully the XL will be out by the time I'm ready for this work, along with a slew of other outdoor projects that I need to do this summer.
