Author Topic: Tree stump root removal, biological means  (Read 2935 times)
« on: November 17, 2017, 11:18 AM »
I want to speed up the decay of a freshly cut tree stump. Any suggestions?
This is between two walls and the mechanical means of removing the wood have been exhausted.
Offline PaulH99
Re: Tree stump root removal, biological means
« Reply #1 on: November 17, 2017, 12:28 PM »
Drill a bunch of large holes in the stump, pour in rock salt, then some water. Keep adding salt and water and it will eventually rot out.
-Paul
CT 26 • DF 500 • ETS 125 • KS 120 • OF 1400 • PS 420 • RO 125 • TS 55 R
Offline Svar
« Reply #2 on: November 17, 2017, 12:50 PM »
Drilling holes should help, but wouldn't high salinity suppress bio activity?
I was going to suggest bringing in termites, but you might not like the side effects.  [big grin]
Look up compost additives/accelerators, typically nitrogen and microorganisms. Keep it moist. Are there wooden structures nearby that can be affected?
« Last Edit: November 17, 2017, 01:08 PM by Svar »
Offline Dogberryjr
« Reply #3 on: November 17, 2017, 01:15 PM »
Cover with nitrogen fertilizer (or manure), then heavy black plastic, then mulch.
Offline PaulH99
« Reply #4 on: November 17, 2017, 04:43 PM »
Here's one explanation of why salt works: http://www.mrtreeservices.com/blog/how-does-epsom-salt-work-on-tree-stumps/
-Paul
