Author Topic: Taping eyebrow window  (Read 739 times)
Offline mike9
« on: December 17, 2022, 12:45 PM »
I need to sheetrock tape against an eyebrow window and my thought was to use tear away but it doesn't bend to a circular radius, what product should I use to tape again the window, it's a sheetrock so I would rather keep the clean look instead of using trim.
Offline Holzhacker
    • www.aic-chicago.com
Re: Taping eyebrow window
« Reply #1 on: December 17, 2022, 12:57 PM »
No need to make this complicated, just tedious
Use small pieces of paper tape or mesh, 4"-8" will do and go around the window. You can also cut the paper or mesh tape pieces with a drywall knife or scissors to accommodate the curve.
All just takes a bit more time.
I bought some expensive flexible tape years a go on a job, never bought it again.
Offline guybo
« Reply #2 on: December 17, 2022, 01:24 PM »
hi, this works well
Offline mike9
« Reply #3 on: December 17, 2022, 01:56 PM »
Thank you for the recommendations,  I need the trim that goes against the sheetrock and the window not the outside corner. I could use paper tape but I like tear-away trim because you can tape tight to the window then tear the strip to make a clean reveal. I can't seem to find a segmented tear away like that corner bead.
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #4 on: December 17, 2022, 02:14 PM »
Either cut notches in a straight tear away or use this one
⅝" Archway L Bead
AS3299
« Reply #5 on: December 17, 2022, 04:29 PM »
Are you looking for something like this?
