Author Topic: Suggestions for finishing the shop please  (Read 467 times)
Offline landowner
« on: February 07, 2020, 11:45 PM »
I have a 17 X 65 building on the farm that I use for the shop. It is finished in board and batten pine with tin roof outside and a tin ceiling with R40 insulation inside.
Time to do the inside walls to finish the shop off.
I will be getting 1" X 12" pine in 10 - 12' lengths from the neighbours saw mill.
A few questions on approach for the experts if I might.
I have the festool saws and tracks to get straight edges and square ends and a router to do any edge effect if something is recommended.
Any recommendations on installing the boards perpendicular vs horizontal would be appreciated and if any edge effect on the sides like a bevel is suggested.
I will be getting the pine boards fresh cut from the mill and will stack in the barn for a period to dry it. Any guidance on how much drying time would be needed or the target moisture reading in the wood before I cut and install?
The thickness cuts of the pine from the mill is pretty uniform. I was thinking of installing it on the walls once dried and then using my fleet of sanders (including a planex) to get to a smooth surface.
The pine will probably then be left to age naturally.
Thanks for any suggestions on this.
Regards
Doug
Offline blaszcsj
Re: Suggestions for finishing the shop please
« Reply #1 on: February 08, 2020, 07:14 PM »
I did 8” pine tongue and groove in my shop that I’m working on finishing.
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline landowner
« Reply #2 on: February 09, 2020, 09:31 AM »
Thanks for the comments blaszcs, the pic of your shop is much appreciated.
I like the look of the horizontal tongue and groove pine.
Regards
Doug
