Author Topic: RV style Drawer Slides? (or locking)  (Read 6727 times)
Offline 3PedalMINI
    • Signature Sound & Video
« on: March 30, 2013, 08:52 PM »
Ive got all my drawers put together for my van systainer rack im building. The next step is figuring out the drawer slides. I have been racking my brain trying to come up with the best solution for drawer slides that will keep closed (kind of like RV slides) but i want to drawers to be smooth and easy to pull out. Preferably undermount because i cannot for the life of me mount side drawer slides properly [embarassed]
Anyone have any options that arent too expensive, it is a workvan afterall  [smile]
my other thought is if I cant come up with a drawer slide that works and wont break the bank i might just use a long stip on a hinge that latches infront of the drawers that runs up/down the vertical sides
Thanks Guys :)
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline SRSemenza
Re: RV style Drawer Slides? (or locking)
« Reply #1 on: March 31, 2013, 12:11 AM »
my other thought is if I cant come up with a drawer slide that works and wont break the bank i might just use a long stip on a hinge that latches infront of the drawers that runs up/down the vertical sidesThanks Guys :)
That seems like a good idea, then you can use any slides you want.
Offline neilc
« Reply #2 on: March 31, 2013, 09:55 AM »
Can you not use a bungee cord top to bottom with two eyelets? Right down the center. Would be simple but inexpensive and easy to try.
Neil
Offline downtheroad
« Reply #3 on: March 31, 2013, 10:39 AM »
Quote
Here's some commercial hardware that would work:
File Locking Bar
Tony
Offline Offshoreman69
« Reply #4 on: April 27, 2013, 12:46 AM »
Are you still looking for slides that lock??
When I designed my home built systainers I went with locking slides that are used in the IT industry for LAN switches and hardware. They lock open and closed so they worked perfectly for my needs moving the systainers around in the shop and garage and should do the trick in a work van as well. However they are side mounts but if I can get them to screw to the side of a cabinet case and open and close I think anyone can.
As for cost... I got mine on ebay from a salvage company so the cost was in the $8 per set range. They work fantastically and I drove the systainers in a trailer facing outwards from Texas to Vancouver with no mishaps and no locking bar required.
http://www.accuride.com/Industrial/Product/Details.asp?ProductID=140&CatID=&ProductName=Industrial-3357
When I get home I can take some pictures to show you how they work... if this is still causing you grief that is
