Author Topic: Replacing a rotten section of my cedar garage door  (Read 3278 times)
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« on: June 11, 2011, 07:21 PM »
I painted all four of our exterior doors this week and, while preparing to do so, encountered a big patch or rot in our cedar garage door:
39122-0  39124-1
I cut a large rectangle out of the door using a cut-off jig saw blade in order to avoid the metal frame that backs parts of the door:
39126-2
And, in a couple of places, I used a chisel:
39128-3
The rest of the door was then lightly sanded:
39130-4
From my considerable supply of rough sawn and mostly knot-free cedar, I fashioned the insert shown below:
39132-5
The top of the insert has a grove to hold the panels above.  The bottom and sides of the insert and well as the top and sides of the cut-out were coated with several coats of green preservative.
The insert had to be cut into three segments in order to fit it into the door:
39134-6
The inserts were attached to the door and to each other with several screws:
39136-7
Auto body filler was applied liberally over the joints and over the screw holes:
39138-8
Then the area was sanded using these two sanders:
39140-9
The patch could now be painted:
39142-10
Finally, a second coat was painted on the entire door:
39144-11
It’s difficult to spot the patch.  [smile]
« Last Edit: June 11, 2011, 07:28 PM by Frank Pellow »
Cheers,
               Frank (Festool connoisseur)
