Author Topic: Removing nailed roof trim (so you can reuse the wood)?  (Read 2115 times)
Offline threesixright
« on: March 19, 2019, 06:06 AM »
I have ~ 40 meters (~ 20 cm high) wood trim around the roof. The roof will be removed (new floor on top). So I need to remove the wood.
My guess is 80% of the wood is not bad and I could use it for other things. Everything is nailed.
I'm hoping someone has some smart tips how to remove the wood/nails without damaging it too much ? Mission impossible?
Thanks!
Offline Alanbach
Re: Removing nailed roof trim (so you can reuse the wood)?
« Reply #1 on: March 19, 2019, 09:18 AM »
I would use a razor knife to cut the paint seals then pry the wood out carefully. I would not try to drive the nails in the trim back out. I would clip them off on the back side.
Offline pixelated
« Reply #2 on: March 19, 2019, 09:41 AM »
I have both sizes of this "Restorer's Cat's Paw" which work pretty well for getting things like trim off with minimal damage. It works better than the typical flat bar pry bar.
Cat's Paw
Lee Valley also has this trim puller, which might have a little more finesse, Trim puller
This is assuming your trim is fastened with finish nails, these pull the wood off the nail, leaving the nail in place in the substrate. Then you use the "paw" end of the cat's paw or similar tool to remove the nail.
I've had mixed results in re-using trim, on my house the original builder also used glue in a lot of places, so the trim can't be removed intact.
« Last Edit: March 19, 2019, 09:50 AM by pixelated »
« Reply #3 on: March 19, 2019, 10:31 AM »
Cat's Paw
Thanks! Looks like a great tool the job.
Anybody, Lee Valley dealer in Europe?
Sent from my X using Tapatalk
Offline mwildt
« Reply #4 on: March 19, 2019, 10:40 AM »
Axminster in the U.K. appears to have Japanese restorers cats paw which looks like the one on the previous posters pictures
« Reply #5 on: March 19, 2019, 10:56 AM »
I'd vote for the Lee Valley item, that looks quite useful. The 2 best features is that it's thin and it's wide.
I've pulled a lot of trim and most of the pullers out there are relatively narrow and have a thick, sharp bevel to the blade. Unfortunately that combination leaves small indents in the top edge of the trim strips. I've resorted to scoring the trim first and then sliding in a couple of wide drywall knives behind the trim and try to leverage the trim from the wall a little bit at a time.
As others have said, don't try to force the nails back through the surface of the trim, pull them through the back or cut them off.
When cutting the nails, I prefer a RA grinder with a .040" thick abrasive disc because you can trim the nail flush with the wood surface. Using nippers will always leave a little nub left hanging out the back.
« Reply #6 on: March 19, 2019, 11:00 AM »
Thanks!
Offline Bob D.
« Reply #7 on: April 03, 2019, 04:33 AM »
Estwing makes that same or a very similar tool.
https://www.estwing.com/collections/pry-bars
Once you remove the trim if the nails are finish nails with no head you can pull them out the back side of the trim and do no damage to the face side. Then just fill the nail hole before you paint.
« Reply #8 on: April 03, 2019, 06:59 AM »
Thanks. I found some, apparently this 'design' is well copied! 😎
Offline Jaybolishes
« Reply #9 on: April 03, 2019, 07:50 AM »
If the trim is installed correctly, the nails will be in solid framing and a total pita to remove. If light prying doesn’t work, rather than risk denting or splintering the wood, I use a good size nail punch and drive the nails through. Then you can fill the holes with epoxy or another good wood filler and avoid catastrophic damage which often happens if you pry on top of or under the wood. If using a pry bar I like to slip a putty knife under where the pry bar makes contact with the wood, then you won’t hurt the woods surface.
« Last Edit: April 03, 2019, 12:29 PM by Jaybolishes »
Offline Peter Halle
  • Magnum - My new little boy
« Reply #10 on: April 03, 2019, 10:29 AM »
My standbys for the last 18 years have been these:
https://www.sharkcorp.com/shark-grip-1/
You can order thru Amazon.
Offline Bob D.
« Reply #11 on: April 03, 2019, 08:42 PM »
"If using a pry bar I like to slip a putty knife under where the pry bar makes contact with the wood, then you won’t hurt the woods surface"
Yes, that's a trick I use too that works very well, forgot to mention it.
