Author Topic: Regular domino's with PVC trim?  (Read 6978 times)
Offline Ben H
« on: October 17, 2013, 02:26 PM »
Gotta make a some window trim for a basement casement.  Was planning on using the Domino on the the miters, but didn't know they would react with the plastic stuff.  My plan is to glue with Gorilla, and support the miters with small tenons.  Anyone had problems with this type of install?
Offline Peter Halle
  • Magnum - My new little boy
Re: Regular domino's with PVC trim?
« Reply #1 on: October 17, 2013, 04:12 PM »
interior or exterior?
Offline Ben H
« Reply #2 on: October 17, 2013, 07:08 PM »
Oops.  Exterior.  Do folks use the PVC stuff on the inside?
Offline Peter Halle
« Reply #3 on: October 17, 2013, 07:22 PM »
Pvc can be used on the interior by code with a maximum thickness determined by code.  I though with this being a basement and humidity issues...
Exterior-wise, i use dominos, a pvc glue, and even pocket screws on the back to join stuff.  I use the dominos for positioning and reference, glue to mate the joints and thus encapsulate the domino, and the screws as permanent clamps and strength.  I use regular dominoes in this case.
Offline Ben H
« Reply #4 on: October 23, 2013, 07:49 AM »
Thanks Peter.
Offline Jalvis
« Reply #5 on: October 23, 2013, 10:45 AM »
I dont think thats a good idea.
PVC trim with PVC glue bonds molecularly so using floating tenons out of wood would not improve the bond or strength.  I've never known of anyone using your described method and cant imagine it improving your quality.  The srews will be great for clamping pressure but I would eliminate the Domino unless its PVC.
Check out the following articles on PVC Trim:
www.thisiscarpentry.com/2012/08/31/ten-questions-pvc-trim/
www.thisiscarpentry.com/2011/10/21/everything-moves-toolbox/
www.thisiscarpentry.com/2012/10/12/repairing-rotten-door-entry/
Offline Billy_C
  • Festool Dealer
« Reply #6 on: October 25, 2013, 11:02 AM »
The big benefit would be alignment during glueup, which is a huge pain.  I would use christy's red-hot white glue or the Azek brand, it will chemically weld the two pieces together.  Sipo mahogany dominos and your in business-
Offline Peter Halle
« Reply #7 on: October 25, 2013, 08:19 PM »
I only use the Dominos for initial alignment.  Not for strength.  The adhesive and the pocket screws provide the clamping and the strength to hold the joint tight.  For that reason I don't waste the money on Sipo versus the Beech Dominos.  If they rot later down the road so be it.  They will have done their job.
Offline woodie
« Reply #8 on: October 25, 2013, 10:55 PM »
Its pretty easy to make your own dominos out of PVC. You don't have to worry about rounding the edges as the adhesive works well enough without.
Here's a pic of one I made out of Azek.
94855-0
Green - MFT/3, FS 1080/2, FS 1400/2-LR32, FS 1900/2, FS 3000/2, Parallel Guide Set, CT 26E, CT MIDI, OF1400 EQ, LR32 Drilling Set, MFS 400 Set, MFS 700 Set, Domino DF700 Set, Domino DF500Q Set, C12 NiMH Set, T18+3 Set, 2011 Centrotec Set, RO150 FEQ, RTS400 EQ, LS130 EQ, Planex LHS225, and various accessories
Red - KSS80 EC/370, MT55cc, P1cc, F160, F110 and Aerofix Guide Rails.
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #9 on: October 26, 2013, 11:20 AM »
Woodie, that's exactly what I did.  I made 5mm rips from 5/4" Azek and cross cut to length.  I made a couple hundred in a few minutes.
