So the toilet is installed for a month now and it has proven capable and reliable.
I was very limited as to which toilet I could get on short notice because it backs up against a baseboard hot water heater, and I needed the clearance. Most of the toilets have a flat flange that goes all the way back and would have interfered with the baseboard heater.
I ended up with Lowe's own brand (Project Source) toilet. I was a bit leary as it was very cheap (about half the price of the Kohler unit I installed last year) at $99.00 + tax.
It uses Fluidmaster components, so at least replacements will be easy to find.
By all appearances (except the quality of the plastic seat) this is the equal of the Kohler unit.
When I opened the box the hinge on the toilet seat was broken. Lowes replaced the seat with one stolen from another in stock toilet. It is flimsy and moves side to side and does not feel stable. I got a Kohler soft close seat with the capability to be instantly removed if cleaning is required (put the toilet seat in the dishwasher?
![Eek! [eek]](https://www.festoolownersgroup.com/Smileys/default/eek.gif)
). In any case I had the same type of seat on my old toilet and it was very good. I will install it this weekend.
So this becomes "recommended". It works well, and I was two-bolts-not-tightened-enough away from a successful install. And it is a really excellent value at $99.00.
https://www.lowes.com/pd/Project-Source-Project-Source-Pro-Flush-2-Piece-Single-Flush-Elongated-Chair-Height-White-1-28-GPF/1003066162
