Author Topic: Laundry Room Cabinets  (Read 1526 times)
Offline jobsworth
  • Festool Baby.....
« on: September 12, 2020, 08:45 PM »
So as a lot of you know we moved to Az and bought a new home. So the wife wanted some cabinets for the laundry room. It took a while to build and finish as I was working in my uninsulated uncooled garage. We had a record heat this summer with over 50 straight days of temps above 110. I managed to spray them in the morning with the temps about 90' or more. Came out ok considering the temps.
Anyway here they are before and after. Oh yes I installed the trim moulding the next day. The large broom cabinet is one piece about 6' high
« Last Edit: September 12, 2020, 08:51 PM by jobsworth »
Offline tjbnwi
Re: Laundry Room Cabinets
« Reply #1 on: September 12, 2020, 09:22 PM »
Looks good.
Offline DynaGlide
« Reply #2 on: September 12, 2020, 10:01 PM »
You sprayed them in place?
Instagram @matts.garage
Offline jobsworth
  • Festool Baby.....
« Reply #3 on: September 12, 2020, 11:08 PM »
No. I fitted the doors first then removed them and sprayed them In the shop/garage.
Offline jobsworth
  • Festool Baby.....
« Reply #4 on: September 12, 2020, 11:11 PM »
Offline Thompmd
« Reply #5 on: September 13, 2020, 06:57 AM »
Nice job! Definitely something else I want to learn more about and do. Are the center panels floating inside the frame?
Btw, I’m from Indiana so we don’t have such extreme temps but we have humidity , ugg. I always smile a little when people would tell us “well, that’s dry heat” and we would say then stick your head in the oven, it’s dry heat lol
Thanks for sharing
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline RJNeal
« Reply #6 on: September 13, 2020, 08:10 AM »
Very nice. Now you have a laundry room.
Offline tjbnwi
« Reply #7 on: September 13, 2020, 09:33 AM »
Thanks for sharing
@Thompmd
Use either one of these panel spacers;
https://www.cshardware.com/hardware/hardware-supplies/panel-spacers.html
I was born and raised in Chicago, moved to NWI 30 years ago, in the process of moving to Colorado Springs. Humdity is definitely lower in CS.
Offline mike_aa
« Reply #8 on: September 13, 2020, 05:42 PM »
@jobsworth  Nice looking job!  What paint/primer did you use?
Thanks for sharing.
Mike A.
Offline six-point socket II
« Reply #9 on: September 13, 2020, 05:59 PM »
Looking good!
Kind regards,
Oliver
Kind regards,
Oliver
Offline jobsworth
  • Festool Baby.....
« Reply #10 on: September 13, 2020, 06:15 PM »
@Thompmd
Yes they are floating in grooves. I used Infinity tools Shaker style rail and style bits.  They matched my kitchen and bath from the builder the closest.
@ RJNeal
No my wife has a laundry room she asked for it the day we moved in  [big grin]
@ mike_aa
I usually use GF white poly. But I found this new stuff called Renner. Its Italian the directions are in italian to. Its thicker then the GF poly. I use a Apollo HVLP and had to use their High Solid spray cap with a 2.0 N/N. For spraying in the high temp it actually flowed pretty good didnt use and thinner.
They also make a brush on that says can be used on verticle surfaces.
Its cheaper than GF white poly per gallon to.
https://www.rennerwoodcoatings.com
This was the first time I used it. I was happy with it. Ill use it on a couple more projects before Im totally sold on it. I used Enduro coat for a very long time long before they were bought out by GF. So the jurys still out. But yea Ill use it again
@six-point socket II
Thanks Oliver. I had to post something all the great work you do made me feel guilty :>D
« Last Edit: September 13, 2020, 06:18 PM by jobsworth »
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #11 on: September 14, 2020, 09:32 AM »
Looks good.
Renner is good stuff. Spraying it with a turbine HVLP must have been fun...
Tim
Offline jobsworth
  • Festool Baby.....
« Reply #12 on: September 14, 2020, 12:09 PM »
@Tim Raleigh
 It was fun, flowed nice , came out good considering the heat. Now its cooling off so Im going to give it another go on my next project see how it works at normal temps.
So is Renner popular in Canada?
Offline Tim Raleigh
« Reply #13 on: September 15, 2020, 09:47 AM »
Hard to get here. But Eric Reason and others in the US like it a lot.
Tim
Offline JimD
« Reply #14 on: September 15, 2020, 07:15 PM »
Looks Great!  For similar projects I use white tinted Resisthane.  It sprays easily and well with my mini mite 3 stage with the stock tip. I also use Hood's primer which helps reduce the number of coats of Resisthane required.  It is a durable finish but it doesn't cover that great.  But over a white primer it is no issue.
Offline JeremyH.
« Reply #15 on: September 28, 2020, 07:14 PM »
Noice. There's no good reason not to have cabinets in the laundry room  [smile]
CXS;RO150;ETS EC 125/3 EQ;CT26e  KSS400;MT55cc;DDF 40
