Well,
this sure escalated.
After changing out the supply lines, replacing the stems and washers in the shutoff valves, and replacing the p-trap pipes --
everything was crusty and drippy -- I decided to go with a new faucet as the valves were dripping underneath and I didn't want to go through the chore of tracking down parts for an off-brand faucet.
This has opened up another potential problem. After removing the old drain, I can't get the new bottom drain gasket to seat propertly in the sink hole. I suspect the chip circled below is the culprit. The old gasket has a bulge in it where it was seated into the chip, but the new gasket isn't conforming.
Short of replacing the sink, any thoughts on how I can get a good seal on this? Should I pack a little bit of plumber's putty in there? Any other suggestions?
Sink drain hole:
Gasket Bulge:
I tried using the old gasket but keeping the bulge in the exact location while snugging it up is proving to be difficult. The old drain was brass and the nut holding it was extremely tight. Much tighter than I can get the plastic nut on the new drain.
