My order for the double honeycomb blinds arrived a couple of days ago. This morning was the first time we had bright sun since then.
The honeycombs are made from some sort of textured resin that allows light through. The honeycomb is supposed to add insulation; the double honeycomb is supposed to add more.
The single honeycomb filters the light through two layers of plastic film; the double filters it through 3 layers. I opted for the double honeycomb on the theory that greater light dispersion would make the direct sun more tolerable.
For some reason I cannot get the images to appear in the post. The links work though. I’ll have to figure this out.
https://i.imgur.com/tOqmWXn.jpghttps://i.imgur.com/6osMteL.jpgThe camera is not able to record the full range of lighting. I have edited it to most accurately show the amount of light in the room, so the shade looked blown out.
The room remains bright and sun-filled. I will check later and see how much it actually darkens the room with no direct sun.
The shades are easier to hang than roller shades. Like roller shades the brackets need to be mounted with both clips identical for up/down and fore/aft, but unlike roller shades the distance between brackets is variable. This greatly simplifies installation.
The brackets can clip on to the channel that is part of the top of the shade and runs the full width. I placed mine about 5 - 6 inches from each end. The shade installs with a satisfying click, so there is no ambiguity on whether it is attached or not.
The shades were surprisingly expensive. I thought they would be $50.00 to $70.00 each. But closer to $125.00 each from Blinds.com.
They operate smoothly and appear to be of good quality.
