« on: February 16, 2023, 01:44 PM »
Hello,
I am building a large built in. I am using 3/4 ply on the left, right and top. The depth is say 27 inches. The width is 10 feet. I have two 5 foot pieces of 3/4 ply. Do you think say 4 or 5 6mm dominos will hold the two five foot pieces together while I lift and install on the ceiling ? There are two vents cut and I could put a Bessey clamp to hold the pieces. Also, I will have added 1/2 inch edge banding. I think it should be okay.
There is a 3/8 gap all around and I thought about laminating a 3/8 inch piece of hardwood and using 12 mm doMinos into the what would 1 1/8 inch end.
Once it is in place there won’t be any issue.
Thanks.
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
