Author Topic: How to remove vinyl floor adhesive  (Read 1862 times)
Offline rjwz28
« on: February 25, 2013, 01:16 PM »
I'm removing the vinyl floor and want to know what you guys use to remove the adhesive and paper backing? The the vinyl comes off okay. I've read that some use heat guns and other use an adhesive remover solution. Any suggestions?
Thanks,
Rob
Re: How to remove vinyl floor adhesive
« Reply #1 on: February 25, 2013, 04:38 PM »
Rob,
 If you are removing a sheet vinyl floor, typically we remove the underlayment with the vinyl, and install new suitable for the new floor.  This saves removing the adhesive, and we know the new floor will bond to a factory recommended underlayment, and not void the warranty.
Mike
"The only lessons I've learned worth remembering, were when things weren't going well"
"Who is John Galt?"
