Author Topic: Frame-less Cabinet Joinery - Blind Dado's, Domino, or Pocket Screws??  (Read 4691 times)
Offline Bugsysiegals
I'm building cabinets for my basement wood shop, laundry room, pantry, kitchen, bathroom, etc., and am confused which joinery method to use.  Cabinets will be made of 19mm (3/4") Maple veneer plywood which is prefinished on one side.
My main struggle is that these are all going to be frame-less cabinets and to me it looks incorrect to have the front edge banding with a visible Dado joint where end panels meet the top and bottom panels.  They will have full overlay drawers but that's no excuse to do it incorrectly ... do you agree this is not a visually appealing joinery for frame-less cabinets?  In my mind, the edge banding on frame-less cabinets should be like the Roman numeral II with horizontal edge banding extending flush to the sides and vertical edge banding running flush between them ... am I wrong?
FWIW - I've ripped Maple hardwood down to 3mm thick strips and plan to glue it to the exposed panel edges so I can hand plane it flush before cabinet assembly.  I suppose I could get away with Full Dado's if I glued it on afterwards but I don't think I could get 3mm edge banding flush after the fact and I'm fairly certain most people apply edge banding prior to assembly?  I want to use a joinery method which not only lasts many years but is easily repeatable so by the time I get to the kitchen, everything is aligning nicely, and I'm able to create something I can be proud of for years to come....
As far as related tools are concerned for these joinery methods, I have a lot of tools and I've included the ones I think would be most useful for this project .... Festool Domino XL with Seneca adapter for smaller wood, OF1400 router/guide rails, LR32, MFT/3, SawStop with Incra fence system and extended router table wing with 3HP router and Incra lift, Craig Jig, digital calipers, etc., etc.
FYI - With regards to the base cabinet model I've attached, the top/bottom is flush with the sides rather than the sides being flush with the top/bottom like kitchen cabinets because this is for my shop cabinets which will sit on top of 4 swivel casters.  I'm not sure how heavy the items in the drawers may be and I may even use these them as outfeed tables / saw horses, if they can support the weight, so I'm trying to minimize any sagging.
Offline lwoirhaye
Re: Frame-less Cabinet Joinery - Blind Dado's, Domino, or Pocket Screws??
« Reply #1 on: December 27, 2018, 11:49 PM »
Dowels, biscuits and/or screws work too.  I prefer to avoid the arithmetic  involved with dados, personally.   Commercial shops are using a tossup of dowels (w/case clamp), CNC dados, and Confirmat screws for a lot of frameless cabinets these days.  They all work.
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: December 28, 2018, 11:35 AM »
I use 2 dominos per joint and 3ea  2 1/2 screws with the nibs on the heads which will self counter sink in between the dominos.
Quick and easy. Only if the sides are not going to be seen/ covered up or its paint grade
« Reply #3 on: December 28, 2018, 12:04 PM »
It seems the blind dados would take a lot of setup/effort and probably have a higher probability to not be perfect every time versus the dominoes / screws?
Some of the cabinets will get Oak applied ends so I could screw between domino’s from the outside but some will not.  For the cabinets without doors, I suspect nobody would ever see Craig jigged screws from the inside ... is there a reason not to use Craig jig screws between domino’s from the inside versus using Confirmat screws from the outside?
« Last Edit: December 28, 2018, 04:09 PM by Bugsysiegals »
Offline RKA
« Reply #4 on: December 28, 2018, 01:08 PM »
That should work fine.  Just keep the Kreg screws in relative close proximity to the dominos. The Kreg screws may cause a slight misalignment of the joint, having a domino within a few inches of the screw preserves the panel alignment.
-Raj
Offline escan
« Reply #5 on: December 28, 2018, 01:52 PM »
I would pass on the blind dado but would suggest a rabbet/dado for the 1/2" back panel. If you're making your own drawer boxes with undermount slides you can dado your side panels and drawer boxes together without changing set-up.
Glue and screws for the carcass assembly are fine.
If you edge band after the unit is built you can sand off any inconsistencies picked up during processing and assembly.
« Reply #6 on: December 28, 2018, 04:16 PM »
I just used the Kreg jig for the first time ... besides having to use clamps to align the edges close enough that I could sand any differences, it was easy!!  And I have 36” clamps so I have just enough length to clamp the sides where they need to be for alignment.
That said, I haven’t used the Domino yet ... I’ll give that a try and see if I no longer need to align edges and clamp them in place which would save a lot of time and anxiety ... if I’m not mistaken it will align edges perfectly, if done correctly, and only have side to side movement if put on the wider settings, correct?
« Last Edit: December 28, 2018, 04:31 PM by Bugsysiegals »
« Reply #7 on: December 28, 2018, 04:25 PM »
Since the insides are prefinished, I don’t think glue will add any strength unless I dado  the joints so the raw wood fibers are joining together, correct?
I agree rabbits and dados could be repeatable but how would I glue on 3mm thick Maple edge banding after cabinet assembly and trim it perfectly so it’s flush and not all rounded over from sanding ... seems it would be very difficult to produce good results?
Offline escan
« Reply #8 on: December 28, 2018, 06:39 PM »
Yes, titebond will not bond to pre-finish. There are construction adhesives that will do the trick but if you have a domino or biscuit cutter you’ll have a much stronger joint.
I love building frameless cabs, for a number of reasons, but it does require more precision than traditional face frame. I would suggest using metric and repeatable set-ups that referenced off fixed dimensions/jigs for processing.
If your cabinet box parts are coming out within less than 1/2 mm of each other that would be outstanding and you could look at banding before assembly. If I had to apply banding after assembly, I would hold the banding tight to the pre-finished face and flush up the outside with the MFK. As for the round-over, if you radius before assembly you’ll have a butt joint going into a round over. If you radius after assembly, you’ll have 4 inside corners that will not have a radius. You’ll need a narrow bearing and a radius of 1mm or less to minimize this issue. A small file can clean up the remaining wood on the inside corners.
« Reply #9 on: December 28, 2018, 09:39 PM »
Thanks for the tips!  BTW, my entire shop is metric as I thought the math would be easier and I’d make less mistakes ... the math is definitely easier but for some reason I’ve cut several pieces either 5mm off or 10mm off ... I need to measure twice I guess!!
With regards to the Domino, this is my first time using it since I bought it 2-3 years ago, and all 6 joints I’ve made are canted!!  Is this normal??
« Last Edit: December 28, 2018, 09:54 PM by Bugsysiegals »
« Reply #10 on: December 28, 2018, 09:52 PM »
I have to say for the money I paid for the DF700 I’m a bit disappointed.
I made these initial plunges to get a feel for the machine and align the plastic fence. With regards to the fence, it’s offset to the right of the mark and even after moving it as far to the left as it could go, it still needed another millimeter resulting in my having to take the guard out and file the leftmost edge so it could slide further left.
With the guard finally adjusted and marks in alignment, I can’t even make a parallel hole and I have better alignment with a Kreg jig. ;(
When I measure the bottom of the fence, in 90 degree position, there’s a difference of about .75mm from one end to the other. I assume I can adjust this by loosening the 2 torq screws at the top of the fence assembly which position the 2 poles it slides up and down on?
« Reply #11 on: December 28, 2018, 10:06 PM »
I had the ruler to far out on one side and missed a little tab, they’re the same on both sides ... the only thing I can figure is the motor is not quite tight enough or to tight on one side??
I’m going to check on the warranty before I go messing with that ... ;(
Offline SRSemenza
« Reply #12 on: December 29, 2018, 01:42 AM »
I do Dominos with Kreg pocket holes for cabinet boxes. If you put the pocket holes on the outside of the cabinet box they are automatically hidden by the next box or an end panel. Or the top or they end up underneath depending on side , top, or bottom, screw location. That way they don't show on the inside either. Plus if it is a narrow cabinet you don't have to work inside the cabinet.
« Last Edit: December 29, 2018, 01:44 AM by SRSemenza »
« Reply #13 on: December 29, 2018, 10:21 AM »
Thanks Seth!!
Since I’m doing frameless full overlay cabinets, they require double partitions for single cabinets with multiple bays which would leave one partition with holes exposed; however, this could be avoided by building individual boxes per bay and screwing them together to form a longer cabinet run.
That said, does this complicate or make it more difficult to align cabinets during install?
Offline escan
« Reply #14 on: December 29, 2018, 11:17 AM »
I've had alignment issues with the domino as well. Most people attribute misalignment to technique and the initial learning curve which requires rear hand position, concentration and a smooth plunge to achieve good results. I agree with holding off on tinkering too much and check your warranty. There are some experts on the domino on the forum so hopefully one of them will chime in and shed some light on the possible issues/solutions.
Offline SRSemenza
« Reply #15 on: December 29, 2018, 11:37 AM »
Thanks Seth!!
Aah, yes, there are quite a few ways to put cabinet runs together. Sometimes I forget that when answering a question  [smile]
 I  generally  build separate boxes for everything I build and "stack" them together upon install. I almost always go with a separate ladder frame base that gets leveled and then the boxes go onto that. Unless something is just wrong or off I don't have any additional alignment problems. I like this method because no matter the floor /wall / square /  level/ etc issues you at least get to start with a solid level platform to work off.  I also find it much easier to level a ladder frame than separate cabinets. It is easy to get to the back and you aren't dealing with trying to shift boxes around and get them all to play nice with each other.
Some of the construction method depends on the situation and the way you work.
« Last Edit: December 29, 2018, 11:41 AM by SRSemenza »
Offline jobsworth
  • Festool Baby.....
« Reply #16 on: December 29, 2018, 11:47 AM »
@Bugsysiegals
>>When I measure the bottom of the fence, in 90 degree position, there’s a difference of about .75mm from one end to the other. I assume I can adjust this by loosening the 2 torq screws at the top of the fence assembly which position the 2 poles it slides up and down on?<<
Could be the difference in the thickness of the material(ply). PLy thickness isnt dead nuts on.
That could be why.
 I dont have a 700.
So i cant really comment.
The Kreg PH will work nicely.
They are what I used before I got my 500.
« Reply #17 on: December 29, 2018, 01:20 PM »
Based on another thread of similar issue, I’ve done some further testing...
I’ve set the fence at 0 degrees and lifted it to maximum height. I then clamped wood to my MFT/3 in the second row from the front. This allowed me to set the DF700 bottom directly on the MFT/3 table to eliminate any opportunity for deflection caused my operator error. I plunged the board nice and slow ensuring the bottom of the DF700 remained flat against the MFT/3 table. I repeated this for the second board and assembled.
As you can see, I have the same issue ... this board is half the length of the ones before but you can easily see the front boards left end lifted up in the air and back board raising up on the right.  Obviously on cabinet panels this would be worse and be an unacceptable way of aligning panels.
I’ve taken the fence completely out of the equation here and am left to conclude the bit isn’t moving in parallel with the DF700 base.  I’m going to try another bit to make sure it’s not a bent bit.
« Reply #18 on: December 29, 2018, 01:57 PM »
Well, same result with a new bit  ;(
I wasn’t aware I needed to go online to do any registration as I’m only now beginning to use the tools ... am I to late to go online and register so I’m not stuck with shipping on this brand new tool which clearly has some misalignment?
Offline duburban
« Reply #19 on: December 29, 2018, 04:25 PM »
Certainly didn’t think your domino was out of whAck but you did a good job researching and illustrating the issue.
Festool used to get right in touch with you if you had a major defect here but now days less so. Better call them and get the process going.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline duburban
« Reply #20 on: January 18, 2019, 10:06 PM »
Is there a resolution here?
Offline Kodi Crescent
« Reply #21 on: January 19, 2019, 10:01 AM »
I think it may have to do with the rotation of the bit as it grabs the material will torque the machine ever so slightly.  At least that's been my experience.  Or else the pieces aren't the same thickness, or there's a slight deformation in the table or material.
When I built my cabinets I used dados on the gables, with the dado depth the same as the material.  The boxes squared up much more easily.  I then glued and screwed from the tops/bottoms and sides where necessary.  There are videos on YouTube from a guy named Woodman.  It's a 64(?) part series.  Long, but I learned a lot.
Offline cpw
« Reply #22 on: January 19, 2019, 01:56 PM »
Before I got the domino, I would use dados or rabbets and screws to build cabinet boxes.  After the domino, I built them using butt joints with dominos for alignment and extra glue surface.  When using prefinished maple ply, I use the Titebond melamine glue instead of the regular wood glue which isn't suitable for a non-porous surface.
http://www.titebond.com/product/glues/c9121dfd-2a9d-46d0-bd6d-c183e64bd0cd
When I was looking into it, another thing that came up in searches was Roo glue.
Offline Job and Knock
« Reply #23 on: January 19, 2019, 09:45 PM »
In Europe it tends to be dowels, Dominos or screws (NO pocket holes, though) for pre-builts. A few smaller shops use biscuits, but not many. Nobody here ever uses rebates ("dados") or pocket holes - far too time consuming and confer no advantages - but then we tend to use MFC for carcasses and that doesn't work well with either of those techniques
« Last Edit: January 19, 2019, 09:48 PM by Job and Knock »
Simplicity is the embodiment of purity and unity
- Shaker maxim
TS 55 - TS75 - Kapex KS120 - OF1010 - OF2200 - Rotex RO150e - Domino DF500Q -  Domino DF700XL
