Author Topic: Laminate floor question  (Read 5057 times)
Offline Wooden Skye
« on: December 05, 2014, 02:34 PM »
I am going to be installing laminate floor in my attic, I have the flooring and it has the pad already attached.  So here is my question, when cutting, what tooth blade should I use in both my miter saw and table saw?  Do I need any special blade for my multi tool, cause I may need to make some notched cuts to go around things?
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino ETS 150/3, RO 90, CT 26, OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline Steve Rowe
  • Teach them safety when they are young.
Re: Laminate floor question
« Reply #1 on: December 05, 2014, 03:33 PM »
Use a fine tooth triple chip grind blade for the best quality cut on either.  For a multi-tool, I just use a standard blade and end up throwing it away at the end of such a project.  A bi-metal blade would probably last longer but comes at a higher cost.
Must be a fancy attic [big grin]
Offline tjbnwi
« Reply #2 on: December 05, 2014, 05:00 PM »
Try and avoid using the multi tool. Laminate flooring eats blades. Cheep jig saw blades are your best beat. Any miter/circular saw blade will need to be sharpened after about 2 cuts.
See if you can rent a laminate flooring guillotine.
Offline galwaydude18
« Reply #3 on: December 05, 2014, 05:29 PM »
Just use a jig saw. That's what I always use to cut laminate flooring
Offline Wooden Skye
« Reply #4 on: December 05, 2014, 05:30 PM »
Thanks for the response. Not that fancy.  It is more like a third floor, basically we are setting it up for my son to play and I have my home office up there.
Bryan
Offline Wooden Skye
« Reply #5 on: December 05, 2014, 05:32 PM »
Thanks Tom.
I will skip the multi tool and stick with the jig saw.  For jig saw blades, what tpi would be best?  I am going to buy some cheap blades instead of using my Festool ones.
« Last Edit: December 05, 2014, 05:39 PM by Wooden Skye »
Bryan
Offline Walk On Wood
    • Walk On Wood
« Reply #6 on: December 05, 2014, 05:37 PM »
I used to install a tremendous amount of laminate for the company I started out with.  I use a table saw with a cheap 7 1/4" framing blade for all cuts, then throw the blade away after.  A jigsaw w a cheap blade works well too if you're not comfortable cross cutting on a table saw
The Green Kool-Aid is good!
Offline Alan m
« Reply #7 on: December 05, 2014, 06:10 PM »
for the first few jobs I did  I used my chop saw and table saw.
after about 3 or 4  average floors both blades were knackered and needed replacing .
from then on I only use my jig saw
you can cut any angle with the jig saw and do your rip cuts. using the chop saw would be a lot slower.
Offline Wooden Skye
« Reply #8 on: December 05, 2014, 06:34 PM »
After reading some advise, I am going to you my jig saw for all my cross cuts.  If I need to rip, I will use my table saw and buy some 7 1/4" blades that I won't care if they are ruined by the end of this project.  I am assuming that a higher tooth blade is best for both jig and table saw, and if I need to will tape the cut line with masking tape.
Bryan
Offline pjcoop
« Reply #9 on: December 05, 2014, 06:53 PM »
Bosch make some jig saw blades made for laminate flooring. I use them all the time now. You can use your jig saw for the whole floor including rip cuts, saves on blades. All your cuts are hidden by baseboard or threshold moulding so the do not have to be perfect and I have not come across a square room yet, walls are always out.
Offline tjbnwi
« Reply #10 on: December 05, 2014, 08:48 PM »
I use metal cutting blades, low to mid speed.
The Home Depot near me rents this (I'd own one if I did a lot of laminate floor);
http://www.homedepot.com/p/Roberts-13-in-Wide-Pro-Laminate-Engineered-Wood-and-Vinyl-Flooring-Cutter-10-64/203526690
Thanks Tom.
Offline Floorman70
« Reply #11 on: January 03, 2015, 04:00 PM »
I lay a lot of laminate,i use a magnum shear(i`ve got a 13" one,which is great but quite expensive and heavy to carry around,so i now use the 9" which is really light and only cost about £130),i use a jigsaw for long cuts and a hacksaw for notching round pipes,as it has a thin blade,doesn`t chip the laminate and can easily cut at an angle so your cut out piece can sit on top
ts55,ro150,ro90,of1400,ps400,various guide rails,ct mini,ct33,2 cleaning sets,ehl65,kapex 120ug set,mft3,cs50 precisio,various clamps,toolboxes,sysroll cart,sysmft,mfs700 and a watch somebody bought me#Soon to have:
Everything else :-)
Offline MGB
« Reply #12 on: January 04, 2015, 09:15 PM »
I'm not sure why you're concerned with cut quality?
Laminate requires room to move, so door jambs/baseboard/transitions all have to sit on top of the floor. Your cut will always be hidden, except for perhaps a flush stair nosing.
Maybe I'm just missing something being that its going in an attic.
