Author Topic: Drywall sander  (Read 2161 times)
Offline jpmeunier
Drywall sander
« on: May 21, 2020, 10:20 AM »
So I just moved into a house (1850sqft) that I will need to replace or refinish 1/2 the drywall in the house. What are people's thoughts on drywall sanders? On the low end you can get a WEN for under 200, Makita cordeless for 700 (get 2 batteries), Planex easy for 750. Not sure if the Mirka Leros is available in the US. I typically tend towards wanting high quality tools, and I could sell the higher end units pretty simply if I don't see much value in keeping them. Let me know your thoughts/experience.
Offline Holzhacker
    • www.aic-chicago.com
Re: Drywall sander
« Reply #1 on: May 21, 2020, 12:13 PM »
I guess it all depends on how good of a taper you are. I use an ets125 for drywall. However, I don't do 100-200+ sheet drywall jobs anymore either. Then I'd probably want a Planex.
Offline Alex
Re: Drywall sander
« Reply #2 on: May 21, 2020, 01:32 PM »
An investment in any of the sanders you mention is a waste for a single house.
The high quality tools are always preferable because they are built do to actual work, and with a powerful motor and strong bearings they are meant to last for years for a professional user. But they cost a lot. A professional will see his investment back because he will use it on dosens of houses each year, for a couple of years. A home owner will not.
A cordless Makita? You will need to stop and change and charge batteries all the time. I could never live with that. There are so many better corded options available. Doesn't need to be the most expensive there is, like the Planex, other manufacturers also make them. Flex, Milwaukee, and apparently the Porter Cable 7800 is great value for the money.
- Stay away from the WEN. It's a sham. A penny spend on that WEN is a penny thrown in the bin. That particular sander is available all over the world from dosens of cheap no-name brands. It is just a cheap generic Chinese product that is only made to look like a drywall sander but isn't really functional. I know somebody who had one. For instance, the round head DOES NOT SPIN like a drywall sander is supposed to. It just vibrates like an orbital sander. And at a very low RPM for that. Also, it overheats after 15 minutes of use. And last but not least, it uses a proprietary type of paper that is nowhere to be found. The guy I know who had it threw it away after using it 2 times.
But want to work on your house and get a sander that works and doesn't cost a ton? Get an ETS 150, EC or not, and you can use that sander for your drywall and tons of other jobs.
Online Cheese
Re: Drywall sander
« Reply #3 on: May 21, 2020, 02:21 PM »
I use an ETS EC 125 with a 150 pad mounted on it. Nice and light for vertical surfaces. Also pick up some sanding sponges.
Offline jpmeunier
Re: Drywall sander
« Reply #4 on: May 21, 2020, 02:47 PM »
I have an ETS EC 125 that I've used before. What about ceiling work with that? Take a decent amount of terrible to be $750 terrible.
« Last Edit: May 21, 2020, 03:21 PM by jpmeunier »
Offline Alex
Re: Drywall sander
« Reply #5 on: May 21, 2020, 02:54 PM »
I have an ETS EC 125 that I'e used before. What about ceiling work with that.
It's a breeze. Perfectly suitable.
Offline ColossusX
Re: Drywall sander
« Reply #6 on: May 21, 2020, 03:30 PM »
I use my Pro5/ETS 125 for drywall work currently. Am considering a planex as I'm picking up more drywall work than I had intended
Offline Svar
Re: Drywall sander
« Reply #7 on: May 21, 2020, 03:59 PM »
Offline Peter_C
Re: Drywall sander
« Reply #8 on: May 21, 2020, 10:54 PM »
Buy a Planex Easy if your ceilings are not very tall. Finish the drywall inside the house and resell it for 20% less than you paid. Consider it a rental. Crazy what used Festool stuff sells for.
Offline RussellS
Re: Drywall sander
« Reply #9 on: May 22, 2020, 12:01 AM »
Most, all, of my recent drywall work smoothing has been done by rubbing a wet rag over the mud.  Fresh, one day old, drywall mud/tape is very easy to smooth with a wet rag.
Offline JimD
Re: Drywall sander
« Reply #10 on: May 24, 2020, 02:01 PM »
I do not do a lot of drywall work but I put an office in an attic area and recently built a few walls to create a bedroom in another attic space.  I also took down popcorn ceiling in the entire house and had to patch up that drywall work.  I also fixed a ceiling joint in a cathedral ceiling the professionals messed up.  The only sander I used other than sanding blocks was also not powered, it is the festool hand sander that hooks to a vacuum.  I am not that good a taper but drywall compound sands VERY easily.  All the professionals I've seen used hand sanders (i.e. non powered).
If you do this a room at a time, I don't think you need a sander.  If you tape the entire house, then sand, you may.  It definitely gets old quickly.
Offline afish
Re: Drywall sander
« Reply #11 on: October 08, 2020, 08:29 PM »
I did metal studs and drywall for years and mud and tape a lot still for myself.  I would be careful buying a planex right now unless you get a good deal on a used one.  The new planex 2 that is getting released is going to hurt the sales of the Gen 1.  The Mirka Leros is a very good sander and I was about to buy one until the festool released the news of the Planex 2.  Im not in a hurry so now Im waiting to see what happens with the Planex 2 for the US.
As far as any cordless sander such as the Dewalt or Makita its completely useless and frankly a stupid Idea to make one "cordless"  The second if not the main benefit of these power sanders is the dust collection so what is the benefit of having it be cordless if its still hooked to a DC with a hose?  Until they magically figure out a way to have a cordless DC it makes no sense to have a cordless drywall sander. All it does it put more weight from the battery being on the sander and makes it more fatiguing for the persons arms and shoulders doing the sanding. Cordless tools are great and I own a ton of them but there are some that just dont make sense and drywall sander is one.  If the job is big enough to justify breaking out a power sander then you need the dust collection.  If its a small one room job they have already had a cordless version for years its called a pole sander.  If you cant knock out a room with just a pole sander then the problem is with the taper.
Offline Bob D.
Re: Drywall sander
« Reply #12 on: October 08, 2020, 09:45 PM »
For a one off job why not just rent what you need? Since in the case of the OP this is a DIY you're still ahead of the game IF you plan your work and don't keep the tool for any longer than you need to.
Get all your areas ready for sanding, then get the tool and go to work. Evaluate beforehand what is more cost effective if you will have some down time between uses of the sander. Is it cheaper to return and rent again two or three days later or rent for a week (which can sometimes be only slightly more than a two day rental). Remember to factor in transportation time and expenses if there is any significant distance involved. Don't short yourself on consumables. Many rental places will let you take a bit more than you need and return unused consumables for credit when you return the tool. At least that is what my local rental place will does for me when I rent  floor sanders.
Offline mkasdin
Re: Drywall sander
« Reply #13 on: October 09, 2020, 12:08 AM »
I have a Wen Drywall sander. The interface pad is cheap, but it accepts the Festool sandpaper. It will get a bit warm after sometime, so you need to give it a break and turn it on when it cools off. I’m planning on running this thing to the legs fall off. 🦵
Offline Bugsysiegals
Re: Drywall sander
« Reply #14 on: October 09, 2020, 07:32 AM »
I bought a porter cable to finish some sheets in my living room without getting dust everywhere. While it did capture most of the dust, it did not work well for me.
Even though I kept it moving and in different directions, I found it made the walls uneven.  I’d mud, sand, realize it took to much off in some areas, not enough in others, mud again, sand again, etc.  This was my first time using this sander so maybe it’s lack of finesse but I wasn’t impressed and ended up using a sponge sanding block with shop vac held underneath. It certainly didn’t capture all the dust but allowed me to finish it smooth.
That said, I’m remodeling 2 bathrooms next and will have to sand overhead ... I will definitely be using the sander for these parts and perhaps I’ll have better luck this time ...
Offline afish
Re: Drywall sander
« Reply #15 on: October 09, 2020, 04:18 PM »
The rotary sanders like the PC are much harder to control and uneven sanding and gouging is almost a given or at least very common.  They require some practice.  The mirka and the new festool coming use a RO motion which gives a much more controllable action and makes the process much easier even for the novice.  I have always wondered why they didnt make one sooner but atleast its finally a reality.
Offline mkasdin
Re: Drywall sander
« Reply #16 on: October 11, 2020, 05:10 AM »
The planex 2 shows a 4mm stroke on the orbiting. Was the previous version not otbital? I’m thinking the orbital will allow you to decrease the speed and will keep the pad from digging along the edges?
Offline afish
Re: Drywall sander
« Reply #17 on: October 11, 2020, 10:44 AM »
the new planex and Mirka leros are the only ones that use an orbital motion which is much more user friendly and leave a better finish. That I know of.  The gen 1 planex is rotary only.  Heavily painted popcorn or texture is one area the orbital sanders might not accel at compared to the rotary sanders but I dont scrape popcorn.  I find it better to just rip it down and re-drywall if there is heavy texture that has been painted multiple times.  This is partly do to my location here in S. florida there are alot of low slope roofs and the attics are almost impossible to navigate.  So drywall removal kills 2 birds so to speak. 1. popcorn removal and 2. I can  address any insulation shortfalls while I have easy access.
Offline leakyroof
Re: Drywall sander
« Reply #18 on: October 27, 2020, 11:44 PM »
. The incoming Planex is Random Orbit, and has LED lights for work illumination.
 While I’m used to the Rotary sanding of my first gen Planex, the sanding action of the new model is smooth and you don’t have to think about the rotation of your abrasive disc as much like you do with the Rotary( I got to try out a preproduction Planex last year, I was jealous within minutes of running it..... [tongue] [tongue] [tongue])
  Can’t even justify selling and switching for the new version, but for softer surfaces where gouging is a worry , it should be even easier to work with.
 I do agree that for rougher sanding , the rotary version might have the edge, but would need to try them side by side to see. After all, the EC sanders are powerful and small.... [cool] [cool]
Offline afish
Re: Drywall sander
« Reply #19 on: October 28, 2020, 02:56 AM »
Beaver Industrial supply sells the Leros here in the U.S. I think they are in Missouri or near there, it's about 1,100 bucks.
Offline mkasdin
Re: Drywall sander
« Reply #20 on: October 28, 2020, 01:47 PM »
If I’m not mistaken the local Woodcraft sells the Mirka abranet sandpaper and I. Think he can order the Leros. I mentioned it to the owner and it would be a special order, not sure what the difference is between getting it from him or an internet tool company?
Offline mkasdin
Re: Drywall sander
« Reply #21 on: October 28, 2020, 02:11 PM »
I recently used the Wen and I was disappointed, not using it anymore. I can say what ever you decide, “plan of attack” do one room first start to finish? Then you can fine tune your workflow process. I’m assuming you’re not a drywall taper as your day job. I would either get the Mirka or the Planex. The planex is better for the rough work, the Mirka for a level 4 or level 5 finish. I would at the very least knock down the big chunks, but perfection wins over and then your stripping the wall down to the joint seams. Trust me on this - lol. The Planex easy with some 40 grit or 60 grit might be a good start. You will need to jump from one grit to the next. If you start with to fine a grit then it tends to melt the paint without removal, too rough and your ripping everything.
I would do a closet first, that way you can figure out if it’s worth your time or hiring out the job or paying someone to help you. If you start with the closet you could use the small sander ets-ec 125/150 with some granat paper. the mesh papers are good for tape joints and even flattening a skim coat out. If you want to get aggressive removal then use a rotex, but it’s easy to get ahead of yourself and create additional-problems. The small sanders are good for tight spaces so you can judge how effective the grits are in you “refinishing task”.
After you’ve done the closet you’ll have a better idea, I use better with reservation, on how long a room will take? My vote would be to get the Planex easy and if you need to go higher use a small portable scaffolding or a small step ladder. You don’t have to worry about refinishing yet? This is a multi step process. When your done with the job you should be able to get most 60-80% of your purchase back within a year, if you sell the Planex easy.
If you want to make life easy do a knock down finish. If you want to get artistic try a skip trowel method, or Santa Fe, or sun valley finish. If you have a lot of time and are proficient with a taping knife, hawk and trowel do a level 4 finish... look at American Clay or some other company if you want to get a plastered look on a wall. Venenetian plaster, French plaster etc. like woodworking there’s some technique involved, shooting an orange peel on the wall and doing a knock down is the quickest method. It’s also my least favorite, unless I really didn’t care and wanted to get in and out for a house that I was selling....
« Last Edit: October 28, 2020, 02:16 PM by mkasdin »
