Author Topic: Domino Connector System Question  (Read 1252 times)
Offline gold5237
« on: December 13, 2020, 06:25 PM »
I am making a knock down closet system and have what I think is a simple question. Set up: I want to fasten a vertical outside support to a horizontal bottom (all material is 3/4" Birch Ply laminated with Wilsonart laminate) with the DF 500 panel connectors. Question-Do I need to mortise exactly in the middle of the boards? and if so how do I find the middle? My concern is having the horizontal bottom sit proud or shy of the bottom of the vertical support or carcass member.
Thanks in Advance
Offline ChuckM
Re: Domino Connector System Question
« Reply #1 on: December 13, 2020, 06:49 PM »
No need to cut the mortises dead centered whether using the connectors or regular beech dominoes, as long as you set the machine on the reference face properly (e.g. the outside faces of the bottom board and the vertical boards).
« Last Edit: December 13, 2020, 06:52 PM by ChuckM »
Offline afish
« Reply #2 on: December 13, 2020, 08:08 PM »
Agreed, they do not have to be centered. Plus with plywood you have more strength than a cheap product like melamine.  However if you do want to center them its a pretty simple process with a caliper.  Also if its a mortise that will be bearing a load such as a shelf I would try and keep the thicker portion of the offset to the top just for a little extra insurance.  This is probably less of an issue with a closet but things like garage cabinets where considerable weight might be stacked on a shelf I think its good practice if they are offset.
« Reply #3 on: December 13, 2020, 09:27 PM »
I'm building 4 of these, one's installed and the 3 other ones are in various stages of completition. Here's the frame and the stretchers temporarily assembled before the Dominos were machined in.
Here are the stretchers with the Festool 8/50 connectors installed.
Here the first cabinet is temporarily installed in the knee-wall while the face frames are attached to the cabinet sides and the stretchers with Domino 8/50 connectors.
The only thing remotely critical is the centerline distances between the Dominos, as I wanted all of the joints between the face frame pieces to be absolutely flush and without any spaces.
I took these standard Festool items and turned them down to a sharp point. Assembled them in the stretchers, squared them up with a small machinist square and then used them to mark the placement of the centers in the face frames...it worked well. There is a small amount of lateral adjustment with fasteners, maybe +/- .5 mm.
Offline gold5237
« Reply #4 on: December 14, 2020, 12:05 AM »
On a sample piece I had to flip the bottom around to flush up the vertical member and the bottom. I probably referenced side of the vertical piece.
Offline gold5237
« Reply #5 on: December 14, 2020, 12:09 AM »
Good tips, I'll break out the calipers if I decide to center. My thought is with lots of pieces if its centered I don't have to worry about referencing the correct sides.
Offline gold5237
« Reply #6 on: December 14, 2020, 12:22 AM »
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
Slick idea to locate face frame mortises. I don't get the rabbit for the LED strips?
« Reply #7 on: December 14, 2020, 10:43 AM »
The LED’s are mounted on their own individual heat sink, that significantly increases bulb life and it’s also the easiest way to mount them and replace them if any go out.
The rabbit holds the LED assembly and the frosted plastic lens flush with the bottom of the stretcher so as not to catch on clothing.
Offline afish
« Reply #8 on: December 14, 2020, 04:42 PM »
I am one of the few around here that routinely centers his mortises.  I have a post on here about my process if you do a search of my posts but basically The cutter C/L is 10mm from the base. So I use a 6" caliper and get an accurate measurement of my stock which is usually slightly less or more than the stated size.  Just as an example I will use a odd dimension of 17.27mm. Divide that by 2 = 8.635 then add back the 10mm for the height from the base. Now zero out the depth bar on the caliper. Then set it to 18.635mm (half the stock thickness plus the 10mm).  Butt the tail end of the calipers body to the bottom of the dominos base and then adjust the fence so it just touches the depth bar on the caliper.  Its quick and easy and has always got mt to within a couple thousands.  I know most here dont center but I usually do unless there is a need not to.
Offline gold5237
« Reply #9 on: December 20, 2020, 06:17 AM »
Interesting, I need to decide whether to try your method or leave the factory setting as is and flip the tops and bottoms around. For some reason when I flip the reference sides outside the unit instead of inside the unit I am perfectly flush. I like your method so there is one less thing to worry about since the reference sides are interchangeable.
