Author Topic: Crown molding meets angled wall  (Read 1081 times)
Offline Max Fracas
« on: July 21, 2020, 10:03 PM »
We did a room addition and the contractor offered two options for a run of crown that meets an angled wall.  See attached pictures.  I don't really like either option.  Is there a better way to end this run of crown?
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Crown molding meets angled wall
« Reply #1 on: July 21, 2020, 11:13 PM »
What is the intersecting angle?
I’d terminate the with 2-22.5 or 3-30’s.
Offline tjbnwi
« Reply #2 on: July 21, 2020, 11:20 PM »
You can see what I mean in this thread. First post, not my work, I don’t have picture of the ones I’ve done.
https://www.contractortalk.com/f13/problem-crown-moulding-return-146698/
Offline RJNeal
« Reply #3 on: July 21, 2020, 11:42 PM »
I would end it with a return matching the angle doorway angle about a1/2” back.
Rick
Offline waho6o9
    • Garage Door Handyman.com
« Reply #4 on: July 21, 2020, 11:45 PM »
What Rick said ^
Offline DeformedTree
« Reply #5 on: July 21, 2020, 11:59 PM »
Yes, what rick said, I'm not sure how there is any other option.
Only are ways are things like terminate into a block of some sort (corble?), something that disrupts the molding entirely.
Offline Alex
« Reply #6 on: July 22, 2020, 02:42 AM »
Why not let it stick out completely, trim it flush with the wall and fill the opening so that it is completely straight with the other wall?
Offline Bob D.
« Reply #7 on: July 22, 2020, 04:09 AM »
I agree with Rick, step it back a half inch and match the angle.
But of your two choices; neither of which I care for; if it had to be one or the other I would go with option 1 and be sorry for making that choice every time I looked at it.
Offline Max Fracas
« Reply #8 on: July 22, 2020, 09:08 AM »
Thanks for the suggestions! Very helpful.  I like the idea of matching the wall angle (it’s 45 degrees) but stepping back a half inch.
Offline FestitaMakool
« Reply #9 on: July 22, 2020, 02:27 PM »
Interesting challenge you’ve got.
I’m with Alex, let the end of the moulding end flush and paint the end with the same paint as the wall it flushes against. It’s an opinion, but as I see it, it will start and end “endlessly” giving a “flow” as if the opening where clean cut.
Offline morts10n
« Reply #10 on: July 22, 2020, 08:05 PM »
 Most people love crown moulding, but fail to realize that there are many instances where it just l looks awful such as on angled ceilings, and where moulding is interupted by ac vents. There is a place for crown, but not every place is suitable.
« Reply #11 on: July 22, 2020, 09:37 PM »
Well, for me "remove the crown modeling" would have been my true answer, but I don't think that applies here  [smile].   But yes, like so many things on houses, you can only do things that work for the situation.  This is a situation where the space wasn't design for it.
The other answer to go on what I said earlier about disrupting it would be to frame the opening down, assuming there is a similar situation on the other end.  Then the crown can wrap that space, but not be seen from the other space.
I think Alex's answer is a solution too, but it might end up looking like someone did a cross section cut thru the house there.
