Looks like it has the color of iron oxide in it. Which may come from exposed steel parts in the damp environment of the pump reservoir. I've seen similar slime develop in past condensate pumps.
Last time one of mine died I bought this because it was the only one I could get on short notice. Found it on Amazon with delivery the next day, I did not find a pump locally but I'll admit I didn't search every plumbing supply house in the area.
This pump automatically self-cleans (which you can initiate manually if you want) among it's many other features. It will sense when it has not been run in a while and perform a clean cycle. There is no float switch to beak or jam. It has an audible alarm for malfunctions. And many other features.
I normally keep a spare on the shelf so if one craps out I have a spare on hand and I'm ready to deal with it 24/7. When I bought this I was looking for one to replace my spare that I was going to put in service then when I found this I said leave that Utilitech pump on the shelf, I'm going with the Diversitech pump now. The form factor is identical to the Utiltech pump. The hanger lugs, connections, etc are all the same so an easy swap out.
I am happy with my choice as it has been performing flawlessly for almost a year now. I will buy another soon as it is time to replace the other condensate pump which is getting noisy and on its last legs.
https://www.diversitech.com/en-US/item/condensate-management/condensate-pumps/clearvue%E2%84%A2-pump--IQP-120
