Author Topic: Built in Question  (Read 657 times)
Offline Brian Livingstone
Built in Question
« on: February 16, 2023, 01:44 PM »
Hello,
I am building a large built in.  I am using 3/4 ply on the left, right and top.  The depth is say 27 inches.  The width is 10 feet.  I have two 5 foot pieces of 3/4 ply.  Do you think say 4 or 5 6mm dominos will hold the two five foot pieces together while I lift and install on the ceiling ?  There are two vents cut and I could put a Bessey clamp to hold the pieces.  Also, I will have added 1/2 inch edge banding.  I think it should be okay.
There is a 3/8 gap all around and I thought about laminating a 3/8 inch piece of hardwood and using 12 mm doMinos into the what would 1 1/8 inch end.
Once it is in place there won’t be any issue.
Thanks.
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
Online Packard
Re: Built in Question
« Reply #1 on: February 16, 2023, 03:36 PM »
It is going to get heavy, so a helper is advised.
I would use a third piece of plywood about 2’ x 8’ and place it under the joined pieces.  Lift using the 2’ x 8’ to support the joint.
Drive in your fasteners and let the 2’ x 8’ piece down.
A couple of 2” x 8” x 8’ framing lumber would work just as well.
Regardless if it is dominoes or dowels, if you try to lift those joined sheets, there is a good chance you will delaminate the plywood at the joint.
On the second thought, you can rent a scissor lift designed for attaching sheetrock to the ceiling.  I am thinking that is a preferred approach.
« Last Edit: February 16, 2023, 03:38 PM by Packard »
Offline afish
« Reply #2 on: February 16, 2023, 03:57 PM »
Is this cabinets or what?  If so its going to be heavy so lots of helpers or lifting devise. Or I would built as 2 pieces or more depending or door layout.  A drawing of what you are building would help.
Offline Crazyraceguy
« Reply #3 on: February 19, 2023, 09:26 AM »
By yourself, without a panel lifter, not a chance. The seam will split. With a couple of people and some care, it should be manageable. As you indicated, once installed, it will be fine.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Online Coen
« Reply #4 on: February 24, 2023, 03:08 PM »
What happened to the vapor barrier film?
Oh, hot climate + AC?
« Last Edit: February 24, 2023, 03:11 PM by Coen »
