(part 2 of 2)The first task was to make a beam between the two front posts. The beam is made by lamenating two 16 foot long 2x10 pressure treated spruce boards. Because I am working by my self, this requires several small careful steps.
Here I have hoisted on of the boards into place and am drilling a pilot hole before spiking it into the post:
Here is the second 2x10 that is going to make up the beam being raised into place in one of several slow careful stages:
Once this was in place, I hammered it together with the first 2x10:
I work differently up here than when doing construction with readily available electricity. For instance, it was faster to cut this 4x4 by hand than to go and get a power saw, connect it to my generator, start the generator, then turn it off when the sawing task was completed:
The photo below shows the frame for the north wall being assembled.
I anticipate that the front panels of the shed
(more on this below) will usually be off, so there will not be much need for windows. But, sometimes the panels will be in place, so I am going to install small windows near the top of the north and south walls. There are two very old windows that Chum Trowsse gave me about 15 years ago that will do the job nicely. The windows are at least 50 years old and have not been treated well but, after sanding off the surface dirt, cracked paint and a bit of rot,
I found the underlying wood to be sound. I will need to re-putty the glass.
It was a beautiful day and, after sanding, I decided that I wanted to enjoy the sound of nature rather than the sound of a generator and power tools, so I cut all the remaining 2x4s for the wall frames using a miter box and a hand saw:
The work on the rafters is more complex than the simple framing of the walls, so I resorted to the use of power tools and the noisy generator. To make things worse the weather turned cold
(high of 15 Celcius) and wet. With the cold and wet, I wasn`t spoiling the tranquility.
Here, I am cutting bird`s mouths in the rafters with my jig saw:
I found it easier to cut a bevel on the edge of a couple of 16 foot long 2x6s by simply following a line with my Festool track saw, rather than setting up and supporting the saw on a rail:
By this time I was having problems with my Festool circular saw stalling frequently. I moved my cutting close to the generator rather than using extension cord thinking that that might be the problem. In the end, that proved not to be the problem (see the thread:
http://festoolownersgroup.com/festool-how-to/questions-about-the-brushes-on-my-ts-75-circular-saw/ ) but, with several interuptions, I was able to gett everything cut with the saw that I needed to
On the front of the shed, I am placing three 4 foot by 8 foot removeable panels. The frames for these panels are left over from the stage props that I made for a play they a number of friends and I put on in Hearst last summer. I made all the props for a stage setting that was supposed to be our old grade 5-6 classroom:
Here one of the frames is being augmented with a 2x4 before nailing a number of 1x6 vertical siding boards to it:
