"Trim" to me includes simple profiles for joining the boxes and making transitions to the walls or the next box. Anything beyond the basic boxes is what I consider to be trim.
Thanks,
RMW
Don't think I mis-understood you at all. I simply think you're not fully onboard the Euro train. There are NO PROFILES for joining boxes, simple or otherwise. The carcasses get screwed together and they're done. The face / plane of the door or drawer front(s) simple continue in one plane - that's the transition. when you get to a corner or a end wall you use a profile filler (to match your door and continue the plane) that is scribed to the wall just like you would a framed stile.
So, "trim" for you will be a profile filler and toekick that usually clips onto leveling legs - though practically no one installing euro will call that stuff "trim" Tom's two pics show how ends are handled by 99% of Euro cabinet makers.
here's one we did a few years back with , smoked glass uppers 3/4" end panels on the left with profiled fillers on the right scribed approx 1" wide. Notice the wine cooler doors are flush / in plane with the cabinet door fronts. pretty much the same as Tom's except it's lacquer and glass instead of veneer.
2nd pic is an inside corner treatment.
Then I must have misstated my question, read "trim" as the act of finishing and making transitions.
Thanks to everyone for the input and ideas. Rather than screwing the carcasses together in an unbroken line I'm leaning towards adding a filler similar to the base cabinets in the Keith Johnson video. Something to break up the continuous plane of doors/drawer fronts.
I do have one tricky transition to drywall where the boss wants to continue the material we are using for end panels/doors/drawers across a short section of wall (like paneling) to an outside corner, and her idea is to end the panel in line with the drywall corner and blend it in. I'll post a sketch later to make this more understandable, but to me this looks like a problem waiting for me to make it happen.
To be clear, this is a closet install, so there won't be any dead corners for lazy susan type solutions. It's a pretty simple "J" layout starting and ending in a finished panel, + a short section starting from a wall (inside corner) to the outside corner drywall mentioned above. The flat panel area would have a wall mirror, and perhaps hooks for belts, etc.
Again, thanks for all the input. I need to go back and digest everything, which will probably lead to some more questions.
RMW
