Author Topic: six-point socket's tidbits of Home Improvement, small projects and other stuff.  (Read 178072 times)
Offline six-point socket II
Hi Bob,
I'm sorry, I thought since I had shown the whole build in this thread, that that was a given. Again, sorry!
Here's a shot from when it was still work in progress:
That's where it is located. Basement (indoor), dry & warm.
And just for reference, this shot from when it was finished.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Bob D.
Oh, yes, you did post those shots. I didn't realize this was in the same space you've been working on. My mistake.
So the radiator is a two pipe hot water system not steam, but did the radiator ever have an automatic air vent on it in the past? I don't see one now which is why I ask.
If yes maybe the source of the high humidity in the area, and especially being directly under the panel.
Offline Bert Vanderveen
In EU-heating systems automatic air vents are rare (at least they are in the Low Countries). And mostly installed on the (combi)boiler. Venting is done thru the device you can see on the upper left corner of the radiator, by hand, with a special key (that is always missing when you need it).
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Hi!
The original radiator had no automatic bleeder valve, it worked just as Bert described. All of the new radiators I put in got an automatic bleeder valve: hygroscopic bleeder valve -> https://www.amazon.co.uk/Caleffi-Hygroscopic-Radiator-Bleeder-Automatic/dp/B01M8IGKO3
But these only let a minimal amount air out - if present - and close within a fraction of a second if there is the slightest bit of moisture in the air.
But I can place a humidity logger there and see what it says over a couple of days maybe weeks. :) Actually that's a good idea!
Kind regards,
Oliver
« Last Edit: February 20, 2021, 08:18 AM by six-point socket II »
Kind regards,
Oliver
