Author Topic: Alex's Major Home Improvement Thread  (Read 15167 times)
Offline DeformedTree
Re: Alex's Major Home Improvement Thread
« Reply #150 on: February 10, 2021, 07:28 PM »
looks nice.
So, is there a stair case into there? or is that just an attic access hatch and you use a ladder?  The previous series with the crack, I was trying to figure out the stairs or what looked like stairs.
Offline Yardbird
« Reply #151 on: February 10, 2021, 07:35 PM »
If the bottom portion of the chimney has been removed, what is holding up the upper portion?  I guess you do not have to worry about earthquakes or tornadoes, but that is still a few hundred pounds (sorry-few hundred kilos) just wedged in there.  Apparently it has held so far.
« Reply #152 on: February 10, 2021, 07:41 PM »
It's the Netherlands, their houses are below sea level, their chimneys above air.  [wink]
Offline Alex
« Reply #153 on: February 10, 2021, 07:42 PM »
Oh yes, our Dutch houses are renowned for having stairs, they are the best stairs ever, and you will not find better stairs anywhere!
Offline Alex
« Reply #154 on: February 10, 2021, 07:44 PM »
Indeed, no earthquakes or tornadoes here. The stones of the chimney are interweaved with the outer wall. That's all very sturdy.
« Reply #155 on: February 10, 2021, 07:57 PM »
  (Attachment Link)
Oh my!
Did someone ask if they wanted a winder staircase or a spiral staircase and got a response of "yes"?
Offline Alex
« Reply #156 on: February 10, 2021, 08:16 PM »
I guess so.
While I am in the attic, I'd also like to point out the great PVC laminate floor I got for the entire first floor.
I got this for free from a couple who paid €4000 for this including installation.
But it did not work in their house, because a floor needs to be completely straight and flush to accept these boards. They are very thin, only 4 mm, and do not have the capacity to overcome small differences like standard wood laminate does. So in their house the boards came loose. Warranty work for them, and I could pick this up for free after it had been used for only 2 weeks.
It is so called fishbone laminate, you have a left and a right type of board, and install them in an alternating criss-cross pattern, like a fishbone. This is very high quality stuff, and I can't wait for installing them.
Online rvieceli
« Reply #157 on: February 10, 2021, 08:31 PM »
Alex over here we’d call that herringbone. Looks good.
You seem to have a knack for finding bargains and free stuff.  [big grin]
Ron
Offline Alex
« Reply #158 on: February 11, 2021, 03:08 AM »
Thanks for the correction Ron, herringbone it is.
Offline Bob D.
« Reply #159 on: February 11, 2021, 05:12 AM »
[smile]
I also put a fresco on the window frame in the back.
I don't have to tell you experienced art critics that this time I took my inspiration from nature.
(Attachment Link)
That's great work Alex. The painting above the radiator looks just like a window
looking out into your yard. I can almost see the snowflakes falling. :-)
Offline Bob D.
« Reply #160 on: February 11, 2021, 05:33 AM »
"I am not yet sure what to do here with this hole for the stairs. Make a lid there, or leave it open? There are some practical concerns. Also still deciding on the fence, leave it like this or paint it?"
Make a swing gate for the opening in the railing. It should open out onto the floor and only swing one way. That way if you bump into it accidently you won't fall through the gate into the stairwell. If you hinged the gate such that it could open 180 degrees it could lay flat against the rail when moving materials in and out so as not be a PITA. The risk is you leave it latched open and the safety feature is lost.
If you stain or paint the railing use a contrasting color so it does not blend in with the wall. This could disguise the opening in the floor. Maybe even replace the nosing at the top of the stair with a contrasting color wood to make the edge of the floor easier to see. Sounds a little too industrial I guess but these ideas could be integrated into a home environment without being obtrusive.
I didn't notice any type of heat in the attic space, maybe a lid or hatch hinged at the wall with a counter weight would help keep the house warmer. Place the weight inside a PVC pipe so it does not bang around or get hung up on anything. The weight could be over in a corner or some other place out of the way, just run a rope or cable from the hatch through a couple pulleys.
Offline Alex
« Reply #161 on: February 12, 2021, 05:44 AM »
Thanks Bob, good ideas. I'd do like to make a hatch there to keep the heat down in the floors where it is needed. The attic is very well insulated so that's not a problem, but I'm only sporadic there.
The problem with a hatch is that the heater is placed slightly over the hole of the stairs, so I can't make it in one piece unfortunately.
« Reply #162 on: February 12, 2021, 09:52 AM »
Just move the heater over...slightly.
Offline hdv
« Reply #163 on: February 12, 2021, 10:15 AM »
When I look at that picture with the fence then I would expect the heater not to be in the way if you have the hinges of the hatch away from the heater. That is, on the right side of the hatch, as oriented in the picture. Or am I interpreting that picture wrong? It would be quite easy to check with a piece of wood of the proper length that you rotate along that right-side edge. I realise that would make hinging up a bit harder due to the longer span length-wise than oriented the other way, but it would also mean that the hatch won't be anyway near your head when you go up to the attic. Anyway, you will probably have realised this yourself.
Offline Alex
« Reply #164 on: February 12, 2021, 10:46 AM »
@hdv, if I make a hatch the hinghes will be along the long side, where the wall is. Hinges on the far, short side don't seem like a good idea to me.
Creating everlasting peace on earth is probably easier.
« Reply #165 on: February 12, 2021, 11:36 AM »
Remember the "dutch door" discussion.  Make a dutch door trap door.  Small half on the heater end.
Opportunity for a fun project, some sort of crazy door/doors.  Maybe a Lamborghini style door with a single pivot that moves up and out.
Offline Bob D.
« Reply #166 on: February 12, 2021, 02:08 PM »
"Hinges on the far, short side don't seem like a good idea to me."
With a counterweight it can be just as easy to open as any other configuration, and as stated might make egress easier. You could even run the rope for the counterweight to the level below so you could open the door/hatch before you ascend the stair.
If you did that the counterweight could be hidden in a pocket in the adjacent wall.
« Reply #167 on: February 12, 2021, 02:37 PM »
https://www.festoolownersgroup.com/index.php?action=dlattach;topic=65274.0;attach=327443;image
Better pictures of the heating interference would help. Until then...
Hollow-core bi-fold doors that fold to store against the wall. Bi-fold keeps folded height below heating equip. Could have a counterweight that keeps them up and use small magnets to keep them closed, after pulling down when going downstairs. Slight push from underneath as you climb would defeat the magnets and doors would fully open.
The existing fence around opening doesn’t look so bad.
Offline Alex
« Reply #168 on: February 12, 2021, 04:09 PM »
Alright, some pictures here.
I placed a piece of wood next to the heater so you can see how far it sticks out, it's about 4 cm.
On the right there's this little water tap with the red handle which also sticks out. I could move this though, not that much work.
This little bend here also sticks out 1,5 cm over the edge.
And a full picture of the stairway. The central column of the stairs also sticks out, this is what makes a hatch in the full length impossible.
I have these two hollow core boards I want to use for the hatch. They are very lightweight. They exist out of a hollow honeycomb core of cardboard, surrounded by a thin piece of poplar wood on all sides, and thin plastic laminate over it. I can adjust them to the exact size needed.
Here's how that looks inside.
As I have two boards, I was thinking of the dutch door, just like DeformedTree said, and make it in two parts, left and right. The right part is straightforward and not a problem, but the left part will hit the heater and that little bend there. I could just make a small strip of wood under the heater to off-set the difference, but I do not find that a very elegant solution.
« Reply #169 on: February 12, 2021, 04:36 PM »
Clearly the answer is to move the starcase over 50mm.  [wink]
That top view gives me vertigo just looking at it.
Offline Bob D.
« Reply #170 on: February 12, 2021, 09:31 PM »
Man that is a sticky wicket.
What about two hatch panels hinged on each side (left/right) that meet in the middle and are notched around the central post of the stair. Single action using counterweight would open/close both at once.
The left side with the heater looks to be the trouble side with the heater interference.
Offline Alex
« Reply #171 on: February 13, 2021, 02:57 AM »
Yup. like I said, there are some practical concerns. I will let it smoulder in the pot for now and see what comes out of it later. Still a lot to do here.
« Reply #172 on: February 13, 2021, 12:53 PM »
I think a "flat door/floor door" what ever one wants to call it will have some issues no matter what. Have to think about how you interact with it coming up those "stairs". You have to open it while coming up them, or near the start, unless you plan to just use your head to push it up.
Something like a roll cover you roll back to the lower floor end might be an option.
Still, why not box it in on the upper floor with a conventional door into the room. Maybe build cabinets in/around the build out.
Heats going to go up thru the house no matter what, putting a door there really won't change anything energy wise unless you insulate the floor. Plus with stuff in that space, i doubt you want it to become uncontrolled.  I don't think you have kids running around up there were you are trying to either suppress their sounds, or have concern about them falling down the stairs (nothing about that setup is safe). So I guess it comes down to whats the reason for the door. Clearly it has made it a long time without. I guess if a burglar broke in, a locked door might slow them down from stealing your bins or flooring.
I would think something like a hand rail would be more of a priority, but I'm guessing you are in the mode of "I've lived here my whole life without...."
Offline Alex
« Reply #173 on: February 13, 2021, 01:08 PM »
It is just to keep the heat from the second floor escaping to the attic. All that requires is a thin hatch that prevents the air from moving.
No, I'm not gonna box it in. I am also not going to make a handrail, totally not needed.
Got no kids running around now, but might not be that long, and then I will make a fence with a gate as somebody suggested above.
Offline Alex
Re: Alex's Major Home Improvement Thread - DS 400 Sucked to the ceiling.
« Reply #174 on: February 13, 2021, 01:10 PM »
By the way, I was sanding in the living room today with 180 grit paper on the DS 400, and an odd effect occured. Made a video of it. Shows why it is important that you can dial the suction of your vac down.
I am just holding the hose to prevent it from wandering off, the sander is stuck to the ceiling all by itself.
Offline six-point socket II
« Reply #175 on: February 13, 2021, 01:14 PM »
Now you've publicly uncovered the secret of how Festool came up with the idea for the CT wings  [big grin] [tongue] [big grin] [wink]
Kind regards,
Oliver
Kind regards,
Oliver
Offline Alex
« Reply #176 on: February 14, 2021, 04:12 PM »
A little bit done again. Now that I'm all done with plaster for a while, it's mostly painting, and a bit of carpentry. I have to adjust parts of the window and doors frames everywhere. Sometimes only a round over with the router, other times fix the miters or make a door fit. Or this:
Looking at the window in the back of the living room, for some reason the windowsill did not align with the jambs. Probably wrongly measured before ordering.
Luckily I had some extra oak from the old closet in the attic.
So I quickly put the 70 outside. Just 2 cuts, but I have to haul that whole thing outside. Most of the time I don't bother putting the legs up for a quick cut.
And the rough shape finished with the 70 and the jigsaw.
I had been working this day for over 10 hours already and it was close to 9 PM. I told myself I should quit and finish next day as this could only lead to mistakes. But I was foolish and wanted to finish this first, just a little thing.
So I promptly put the roundover on the wrong side. Bottom instead of on top.
And made it just 4 mm too short on the other side so you'd still see a ghastly seam in front of it. I really should have quit.
So I had to redo them the next day. At least I had the shapes already, so just a quick copy with a pencil and then cut it with the Metabo jigsaw. Made sure the roundover was at the right side now.
Then I had to sand the entire window and everything around it. A few patches on the wall also, and the radiator beneath. These four always seem to do the brink of the work for me.
And this guys of course. Time for a selfie in my Covid gear.  [tongue] I wear this a lot lately.
All the schuren en plamuren done. Time to paint. First two coats of primer on the blank spots and then high gloss paint to finish it. Have to wait a day between each layer as it's all oil based.
And done.
Offline Yardbird
« Reply #177 on: February 14, 2021, 04:57 PM »
Great recover!  We all make mistakes.  Learning how to blend a mistake away is what separates the "men from the boys" in my book.  And remember next time to "measure twice cut once" and learn from this mistake.
I enjoyed your progress on this project.  I also enjoy your dumpster diving adventures-probably because I have done the same.
Offline Jeff Zanin
« Reply #178 on: February 14, 2021, 05:08 PM »
It is a lot of big things and even more small things, you are taking care of them very effectively and making very good use of the lockdown.
Maybe you need a curfew to stop working after a certain time or after so many hours.  But we all know what it is like to want to finish something that is almost done.
Offline FestitaMakool
« Reply #179 on: February 14, 2021, 05:19 PM »
Great job Alex, fun to see your challenges going through it’s paces to finish. The window looks great!
But, hrm.. your sanders are dusty [scared] [tongue]
