Advertisement (Because of visible Klein Tools, you guys now the drill by now ...
As promised some Festool/wood content.
I started this project by removing all hardware - I used my CXS with the brand new 50 mm Centrotec bits DB CE 50/12-Set 1 to remove the 10 PZ2 screws. The 3 mm t-handle hex wrench is needed to remove the handles first.
Why is the restoration necessary you might ask? Because I messed up. Back when those doors where installed, I asked the carpenter who put them in for some advice on how to treat this door as it is the door of the master bathroom with quite a bit of humidity after showering/bathing - his answer was to use iron/steel wool first and than use a coating. (I don’t remember what it was exactly) I did that, but I didn’t think of, or even knew, about all those little pieces of iron that would remain stuck in the rather soft wood of this massive door. After wiping the door with a tack cloth, it seemed to be OK. So I applied the coating. Only a year later all those little pieces of iron wool would stain/ turn black from the humidity (i.e. rust …) and I wasn’t exactly happy about it. But like with so many thing, there was always something more important to do … Today I finally took care of it.
No project without a little fun.
![Wink [wink]](https://www.festoolownersgroup.com/Smileys/default/winksmiley.gif)
Sanding with my trusty DTS 400 and GranatNet abrasives, as almost always, my CTL SYS does the vacuuming.
The panels required quite a bit of hand sanding. I really like to use the Festool Granat sponge abrasives to do this. A lot can be done with the simple rectangular ones, but to get almost everywhere the shaped sponges are even better. As I have said in the past, these are highly, highly recommended!
Next came sanding the molding on the frames. I found a product for this I wanted to try, it’s from Bosch Professional (probably SIA) and works really well for odd shapes/ molding as you can see in the pictures. It’s called: S473 Best for Contours sanding pad and comes, color coded, in 3 grits. It made sanding the molding a breeze! Highly recommended!
After sanding I vacuumed the door with the CTL SYS and one of the included nozzles. After that, I wiped the doors down with a slightly damp tack cloth. There’s still a bit of the iron wool left, but its much, much better than before.
Next I applied Clou water based Holzlack (wood lacquer).
After finishing both sides and letting them dry, I re-installed all the hardware. Again I used my CXS with the brand new 50 mm #Centrotec bits DB CE 50/12-Set 1 for the 10 PZ2 screws, and the t-handle hex wrench to install the handles.
Finished door back installed.
Kind regards,
Oliver
