Advertisement because of visible Klein Tools.
Here I had an interesting problem.
I already exchanged radiators in the past and since the overall situation is very similar, I ordered all the parts I had already used in the past. Installing the radiator was a breeze, but then I had a rude awakening when I tried to connect the radiator.
Flow was a couple of millimeters short, return about 20 millimeters. The problem here is not length itself, that is easily adjusted. But "depth" is. I called it a day and started to search for a solution.
During my research I found a flexible connector made by Hummel AG from Denzlingen hummel.com .
Could that be the remedy I had hoped for? These connectors, or problem solvers as Hummel AG calls their product, run 30,00 Euro including VAT/TAX (street price) a piece. This rises your expectations on one hand, and on the other it’s a reassurance you’re not buying some junk but a high quality, professional product that will last.
These problem solvers arrived a couple of days ago, I bought them at alternative-haustechnik.de - and today I used them to finally install my radiator.
I’m actually super happy/ they work like a charm.
The way these flexible connectors are constructed/built lets you bend them, I’d like to say almost kinda three dimensional for the most exact fit to your unique situation.
There is no „forcing“ them into place necessary, they fit without putting any stress on pipes, radiator or other connectors/materials.
Bending and fitting them is a breeze, the euro cone connection fits perfectly - thus seals tight. Personally I’d recommend this product for all type of renovation, when old pipes of the heating system are to be re-used/ left in place.
Everything OK, except for the connection.
The new flexible connectors from Hummel AG.
Removing some of the no longer needed connectors.
Close up of new connectors.
Still all leveled.
Kind regards,
Oliver
