Hi everyone,
So today you get to have a laugh at my expense, or "stupid"-temper-tantrum-throwing-Oliver at work ...
I found this:
https://www.mixcard.de/p/holz-hygienehaken-werbemittel/ Not the worst idea these days. (I once used a disinfectant wipe on an ATM keypad - believe me, you don't want to see the result.) (I used this picture as template:
https://www.mixcard.de/wp-content/uploads/2020/05/Hygiene-Alltagshelfer-Holz.jpg )
Anyway, I thought without the chip function to relase shopping carts at the grocery store, I could use a scrap of 4mm ply. (4mm is too thick for the shopping cart chip)
I scaled down the image (Used a shopping cart chip to check how far I was off, not bad ...) and got the tools out. (It's about 20 years since I had used a coping saw.) Luckily I had a few saw blades for it left. ...
Used spray adhesive to get the template on the ply. (Bad idea, since I only had "extra strong" at hand ...)
While eating some homemade pizza I led the adhesive dry. Then it was time to start. What can I say, there is a reason I haven't touched a coping saw for the better part of 20 years, I'm still not calm and focussed enough for stuff like this. What worked like a charm, was using the Rali press to hold the saw table.
Drilled a hole, and used the coping saw on the inner circle. Then I removed the template, interesting enough that was easier than I thought it would be, after using the "extra strong" spray adhesive.
Then some filing and sanding.
Then both of the "hygienic helpers" were ready. Absolutely no prize to be won with these, but they will work as intended. As I said, I'm neither calm nor focussed enough with stuff like this. I threw a temper/cursing tantrum after the first few cuts ... Glad you couldn't hear me.
Honestly, I didn't want to show them. But I had started taking pictures anyway, so I though "to heck" - why not show a classic fail.
Kind regards,
Oliver
