Author Topic: Veritas flush cutting Chisels  (Read 6748 times)
Offline ear3
« on: August 15, 2019, 12:05 PM »
Wondering what ppl think of these:
http://www.leevalley.com/us/wood/page.aspx?p=76966&cat=1,41504
Trying to imagine some of the other uses I could get out of them given that I don't do inlay.  The set price is a pretty sweet deal.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Re: Veritas flush cutting Chisels
« Reply #1 on: August 15, 2019, 12:43 PM »
I have one crank neck chisel and sometimes it’s the only tool that will work, but it’s not completely flat and and crank neck adds a little unwanted spring. I’m probably going to buy this set.
Also think the ability to remove the handle and substitute a bolt etc. will someday...
« Last Edit: August 15, 2019, 12:54 PM by Michael Kellough »
Offline ChuckM
« Reply #2 on: August 15, 2019, 03:13 PM »
Snip.
I use this kind of tool to remove glue squeeze-out (in its rubbery state).
Offline RKA
« Reply #3 on: August 15, 2019, 03:39 PM »
I'm not sure, it does seem very specialized.  I'd probably resort to routers and sanders to do the type of flushing operation they depict.  A router plane could also do some flushing operations if you have clearance for the base.  But if something was obstructing the base of the router or router plane, I guess these would come in handy.  Not sure I'd get the entire set though.  A 1" might suffice.
-Raj
Offline hdv
« Reply #4 on: August 15, 2019, 04:37 PM »
I already have a crank neck chisel that I use for things like getting to the bottom of (shallow) mortises. For flush cutting I use a Kugihiki and Veritas' cabinetmaker's trimming plane (see this webpage). To be honest I don't see the added value of these.
Offline tomp
« Reply #5 on: August 15, 2019, 04:47 PM »
This Veritas Flush Plane works very well for flush-trimming dowels, screw plugs and so forth, just use a side-to-side sweeping motion.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #6 on: August 15, 2019, 05:01 PM »
That's a good idea if you need a swan neck chisel.
Other offerings:
https://www.fine-tools.com/stemmm.html
I use a magnetic block with a sharp plane iron.
303116-0
Online Cheese
« Reply #7 on: August 16, 2019, 12:15 PM »
They're nice, that's for sure. I've never needed a set though. Over all these years I've only used this one. It comes in handy but then so does a LN chisel plane.  [smile]
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #8 on: August 16, 2019, 12:56 PM »
I'm a little wary of the two smaller chisels.  Looks like the handle is wider than the blade, which makes them useless for getting into tight corners.
WaHoo6o9's  magnetic block on a plane iron is a piece of genius though.  Gonna make one of those next shot I get at some shop time.
Offline ear3
« Reply #9 on: August 16, 2019, 04:18 PM »
I ended up getting the set  [embarassed]
Offline HarveyWildes
« Reply #10 on: August 16, 2019, 06:45 PM »
I'd be interested in this set if the "thinner" blades are stiff - in your opinion, how much do they flex.  Also, how tight and sturdy the threaded connection between the handle and the blade?  Please give us a review when you get the chance!
I have a couple of Japanese chisels with handles that are angled up just enough so that it doesn't interfere with the plane of the blade, but the resulting clearance between the chisel handle and the work surface is pretty slim.  I also dislike the hard right angles on most crank neck chisels. My chisel plane is good for some stuff, but sometimes it seems a little over-sized for the job, and it depends on a good-sized reference surface.  This set looks like it could fill a nitch.
Offline Svar
« Reply #11 on: August 16, 2019, 09:05 PM »
The advantage of flush chisel over flush plane or block is that often trimming requires lifting the heel of the blade just a little bit, 1-2 degree. With chiesel it is easier to do in a controlled manner.
Offline Birdhunter
« Reply #12 on: August 18, 2019, 05:40 PM »
I have a crank neck chisel, but I’ve had plugs tear or chip when using the chisel. It is very sharp!
I’m currently using a flush cutting Japanese saw I bought from Bridge City. If I’m careful, I get a totally flush cut. If I leave a little, a sanding block removes the excess.
Birdhunter
« Reply #13 on: August 18, 2019, 05:55 PM »
WRT to my interest in how tight the threaded connection is, I can imagine a scenario where you are using one hand on the blade to guide the cut and the other hand to push hard on the handle.  One of the hands torques a bit. and the thread connection loosens up just enough that the corner of the blade catches the work.  The threaded connection seems like it could be a weak point the design, depending on how well it's implemented.  Aside from that, I really like the design - it seems overall that the direction of force on the blades is superior to a crank neck chisel.  @ear3, that's why I'm interested in your review.
« Reply #14 on: August 19, 2019, 12:37 AM »
I’ve had to replace a few too many plugs when the chisel tore a bit off one side. This flush cut saw from Lee Valley is what I use now.
Offline derekcohen
    • In The Woodshop
« Reply #15 on: August 19, 2019, 08:44 AM »
I have been using this prototype set since 2016 ...
The handle is printed but very functional. The blades are the same as those that went into production. They came flat ... flat ... flat. Which is important since that is how they are used.
Harvey, the screw connection is tight and does not loosen.
Are they useful? Very, in the right circumstance.
Are they necessary? No, one can use a chisel bevel down, or every a thick plane blade.
Should you get them? I don't know about getting a whole lot of cranked chisels. I have always had a couple of flat ones and a few cranked gouges. They get used, but they are specialist chisels, so not used very often. I think that the whole point of the Veritas offering is that you get one handle and a couple of blades. It is more cost-effective as well as a space saving.
One of the additions I made to this set was to add a long handle ... ala a Japanese slick (very easy to do as all you need is to recess a thread, which is a standard size). I found that I liked the extra length for control, plus it gave a little more clearance when pushing.
Here is a comparison with a Japanese cranked neck chisel ...
Offline usernumber1
« Reply #16 on: August 19, 2019, 11:05 AM »
very cool, thanks for sharing!
what size do you find most useful?
« Reply #17 on: August 19, 2019, 11:11 AM »
@derekcohen, thanks for the post - great hands-on info.
I will probably go ahead with these - I've never bought a crank neck chisel because of the torque vector around the top of the edge which tends toward lifting the chisel and the edge digging in.  I'm sure that the problem can be managed when the chisel is used properly, but  I've always found a different way to manage a task where a crank neck might be useful.  These chisels look like the vector is below the edge, which means that the tendency would be for the edge to lift - a much better issue to manage in my book, especially with the flat of the chisel working for you.
Can you provide a little more info on the hardware that you used for the slick handle?  Was it just a bit of threaded rod that you epoxied into a hole in the end of the handle, or something more sophisticated?  Now that you can get extra handles for relatively little (US$20, I think), would you consider buying an extra handle, extracting the hardware, and fitting a slick to that?
Also, looks like you have a smaller size than LV is selling, maybe 1/4"?  I can see that LV might not think that the 1/4" size is useful if they think that the flat is a key part of using the chisel successfully, but it seems like the 1/4" or even 1/8" size might be useful.
Thanks again for sharing :)
« Reply #18 on: August 19, 2019, 11:24 AM »
I've had the same problem when trying to cut off a plug that sticks out over about 1/8", but I've had issues with marring work if I get too close with a flush cut saw - even the ones with no set on the teeth.  Generally what I do now is lay down a piece of card stock paper on the work and use the flush cut saw on top of that.  There is still a bit of the plug sticking up, but now I can use a (very sharp) chisel, or chisel plane if the location is right, to pare rather than chop.  I generally use a skew angle on the paring cut.  I've had good results with that.  I don't use a lot of traditional plugs, but I do use Miller Dowels for light structural work when I want to avoid screws, and for decoration.  I use the same technique for getting flush through tenons and such.
« Last Edit: August 19, 2019, 11:26 AM by HarveyWildes »
« Reply #19 on: August 19, 2019, 11:43 AM »
You can save a minute by using Post-It notes instead of card stock. Then you’re within sanding range.
« Reply #20 on: August 19, 2019, 11:57 AM »
Yep - That's good if I'm sanding at a coarse enough grit, which is a lot of the time.  I have managed to mar work using regular paper, but that's just me being careless.  So I switched to card stock to make it idiot-proof.  The Post-It note idea is great - holding paper in place under a flush-cut saw is a pain.
Offline rst
« Reply #21 on: August 19, 2019, 12:05 PM »
I use rigid vinyl packaging material as it's thin and resists cutting through.  I keep a piece in my oscillating saw case also for protecting surfaces where I need the blade to be against another surface.
Offline ChuckM
« Reply #22 on: August 19, 2019, 12:29 PM »
When the surface to be flushed is large, I prefer the apron plane from Lee Valley. If the surface isn't dead flat, the small apron plane will also work better than a larger block plane or a long bent chisel. If nothing works (for low spots), the card scraper is the tool that will come to your rescue.
« Last Edit: August 19, 2019, 05:10 PM by ChuckM »
Offline ear3
« Reply #23 on: August 19, 2019, 06:42 PM »
Thanks as always for the info @derekcohen -- of course you have a prototype set [big grin]
I like the addition of the longer handle -- sounds like a good lathe project.  Is that that Jarrah wood you've used elsewhere in your shop?
Offline derekcohen
    • In The Woodshop
« Reply #24 on: August 20, 2019, 09:59 AM »
Yes, Jarrah.
That is a very plain piece. It can be much prettier. Here is a saw I made ...
Offline ear3
« Reply #25 on: August 20, 2019, 02:36 PM »
 [thumbs up]
Yes, Jarrah.
Offline ear3
« Reply #26 on: August 22, 2019, 11:13 AM »
They helpfully include a screw and fender washer that makes it easy to hang the blades, so I guess I don't have need now for the roll that was included with the set, in case anyone wants it.
« Last Edit: August 22, 2019, 11:15 AM by ear3 »
Offline ChuckM
« Reply #27 on: August 22, 2019, 02:22 PM »
I prefer your storage solution, as I don't like rolls. If I had this set, I'd get an extra hardware piece, and make a second handle so I could have two chisels to use at any time.
« Last Edit: August 22, 2019, 02:24 PM by ChuckM »
Offline thudchkr
« Reply #28 on: August 22, 2019, 08:55 PM »
Ordered the set as well, but decided to get three extra handles so each chisel has their own handle.
I’d been considering get some paring chisels but these may work out well for the functions of the paring chisels.
« Last Edit: August 23, 2019, 07:17 AM by thudchkr »
Clint
TSC 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, RAS 115, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
« Reply #29 on: August 27, 2019, 10:06 AM »
@ear3, Nice storage!
Have you gotten the chance to try them out yet?  Did they meet your expectations in use?  Any unexpected pluses or minuses?
