Author Topic: Veritas flush cutting Chisels  (Read 6562 times)
Offline ear3
« on: August 15, 2019, 12:05 PM »
Wondering what ppl think of these:
http://www.leevalley.com/us/wood/page.aspx?p=76966&cat=1,41504
Trying to imagine some of the other uses I could get out of them given that I don't do inlay.  The set price is a pretty sweet deal.
Re: Veritas flush cutting Chisels
« Reply #1 on: August 15, 2019, 12:43 PM »
I have one crank neck chisel and sometimes it’s the only tool that will work, but it’s not completely flat and and crank neck adds a little unwanted spring. I’m probably going to buy this set.
Also think the ability to remove the handle and substitute a bolt etc. will someday...
« Last Edit: August 15, 2019, 12:54 PM by Michael Kellough »
Offline ChuckM
« Reply #2 on: August 15, 2019, 03:13 PM »
Snip.
I use this kind of tool to remove glue squeeze-out (in its rubbery state).
Online RKA
« Reply #3 on: August 15, 2019, 03:39 PM »
I'm not sure, it does seem very specialized.  I'd probably resort to routers and sanders to do the type of flushing operation they depict.  A router plane could also do some flushing operations if you have clearance for the base.  But if something was obstructing the base of the router or router plane, I guess these would come in handy.  Not sure I'd get the entire set though.  A 1" might suffice.
-Raj
Offline hdv
« Reply #4 on: August 15, 2019, 04:37 PM »
I already have a crank neck chisel that I use for things like getting to the bottom of (shallow) mortises. For flush cutting I use a Kugihiki and Veritas' cabinetmaker's trimming plane (see this webpage). To be honest I don't see the added value of these.
Offline tomp
« Reply #5 on: August 15, 2019, 04:47 PM »
This Veritas Flush Plane works very well for flush-trimming dowels, screw plugs and so forth, just use a side-to-side sweeping motion.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #6 on: August 15, 2019, 05:01 PM »
That's a good idea if you need a swan neck chisel.
Other offerings:
https://www.fine-tools.com/stemmm.html
I use a magnetic block with a sharp plane iron.
303116-0
« Reply #7 on: August 16, 2019, 12:15 PM »
They're nice, that's for sure. I've never needed a set though. Over all these years I've only used this one. It comes in handy but then so does a LN chisel plane.  [smile]
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #8 on: August 16, 2019, 12:56 PM »
I'm a little wary of the two smaller chisels.  Looks like the handle is wider than the blade, which makes them useless for getting into tight corners.
WaHoo6o9's  magnetic block on a plane iron is a piece of genius though.  Gonna make one of those next shot I get at some shop time.
Offline ear3
« Reply #9 on: August 16, 2019, 04:18 PM »
I ended up getting the set  [embarassed]
Offline HarveyWildes
« Reply #10 on: August 16, 2019, 06:45 PM »
I'd be interested in this set if the "thinner" blades are stiff - in your opinion, how much do they flex.  Also, how tight and sturdy the threaded connection between the handle and the blade?  Please give us a review when you get the chance!
I have a couple of Japanese chisels with handles that are angled up just enough so that it doesn't interfere with the plane of the blade, but the resulting clearance between the chisel handle and the work surface is pretty slim.  I also dislike the hard right angles on most crank neck chisels. My chisel plane is good for some stuff, but sometimes it seems a little over-sized for the job, and it depends on a good-sized reference surface.  This set looks like it could fill a nitch.
Offline Svar
« Reply #11 on: August 16, 2019, 09:05 PM »
The advantage of flush chisel over flush plane or block is that often trimming requires lifting the heel of the blade just a little bit, 1-2 degree. With chiesel it is easier to do in a controlled manner.
Offline Birdhunter
« Reply #12 on: August 18, 2019, 05:40 PM »
I have a crank neck chisel, but I’ve had plugs tear or chip when using the chisel. It is very sharp!
I’m currently using a flush cutting Japanese saw I bought from Bridge City. If I’m careful, I get a totally flush cut. If I leave a little, a sanding block removes the excess.
Birdhunter
« Reply #13 on: August 18, 2019, 05:55 PM »
WRT to my interest in how tight the threaded connection is, I can imagine a scenario where you are using one hand on the blade to guide the cut and the other hand to push hard on the handle.  One of the hands torques a bit. and the thread connection loosens up just enough that the corner of the blade catches the work.  The threaded connection seems like it could be a weak point the design, depending on how well it's implemented.  Aside from that, I really like the design - it seems overall that the direction of force on the blades is superior to a crank neck chisel.  @ear3, that's why I'm interested in your review.
« Reply #14 on: August 19, 2019, 12:37 AM »
I’ve had to replace a few too many plugs when the chisel tore a bit off one side. This flush cut saw from Lee Valley is what I use now.
Offline derekcohen
    • In The Woodshop
« Reply #15 on: August 19, 2019, 08:44 AM »
I have been using this prototype set since 2016 ...
The handle is printed but very functional. The blades are the same as those that went into production. They came flat ... flat ... flat. Which is important since that is how they are used.
Harvey, the screw connection is tight and does not loosen.
Are they useful? Very, in the right circumstance.
Are they necessary? No, one can use a chisel bevel down, or every a thick plane blade.
Should you get them? I don't know about getting a whole lot of cranked chisels. I have always had a couple of flat ones and a few cranked gouges. They get used, but they are specialist chisels, so not used very often. I think that the whole point of the Veritas offering is that you get one handle and a couple of blades. It is more cost-effective as well as a space saving.
One of the additions I made to this set was to add a long handle ... ala a Japanese slick (very easy to do as all you need is to recess a thread, which is a standard size). I found that I liked the extra length for control, plus it gave a little more clearance when pushing.
Here is a comparison with a Japanese cranked neck chisel ...
Offline usernumber1
« Reply #16 on: August 19, 2019, 11:05 AM »
very cool, thanks for sharing!
what size do you find most useful?
« Reply #17 on: August 19, 2019, 11:11 AM »
@derekcohen, thanks for the post - great hands-on info.
I will probably go ahead with these - I've never bought a crank neck chisel because of the torque vector around the top of the edge which tends toward lifting the chisel and the edge digging in.  I'm sure that the problem can be managed when the chisel is used properly, but  I've always found a different way to manage a task where a crank neck might be useful.  These chisels look like the vector is below the edge, which means that the tendency would be for the edge to lift - a much better issue to manage in my book, especially with the flat of the chisel working for you.
Can you provide a little more info on the hardware that you used for the slick handle?  Was it just a bit of threaded rod that you epoxied into a hole in the end of the handle, or something more sophisticated?  Now that you can get extra handles for relatively little (US$20, I think), would you consider buying an extra handle, extracting the hardware, and fitting a slick to that?
Also, looks like you have a smaller size than LV is selling, maybe 1/4"?  I can see that LV might not think that the 1/4" size is useful if they think that the flat is a key part of using the chisel successfully, but it seems like the 1/4" or even 1/8" size might be useful.
Thanks again for sharing :)
« Reply #18 on: August 19, 2019, 11:24 AM »
I've had the same problem when trying to cut off a plug that sticks out over about 1/8", but I've had issues with marring work if I get too close with a flush cut saw - even the ones with no set on the teeth.  Generally what I do now is lay down a piece of card stock paper on the work and use the flush cut saw on top of that.  There is still a bit of the plug sticking up, but now I can use a (very sharp) chisel, or chisel plane if the location is right, to pare rather than chop.  I generally use a skew angle on the paring cut.  I've had good results with that.  I don't use a lot of traditional plugs, but I do use Miller Dowels for light structural work when I want to avoid screws, and for decoration.  I use the same technique for getting flush through tenons and such.
« Last Edit: August 19, 2019, 11:26 AM by HarveyWildes »
« Reply #19 on: August 19, 2019, 11:43 AM »
You can save a minute by using Post-It notes instead of card stock. Then you’re within sanding range.
« Reply #20 on: August 19, 2019, 11:57 AM »
Yep - That's good if I'm sanding at a coarse enough grit, which is a lot of the time.  I have managed to mar work using regular paper, but that's just me being careless.  So I switched to card stock to make it idiot-proof.  The Post-It note idea is great - holding paper in place under a flush-cut saw is a pain.
Offline rst
« Reply #21 on: August 19, 2019, 12:05 PM »
I use rigid vinyl packaging material as it's thin and resists cutting through.  I keep a piece in my oscillating saw case also for protecting surfaces where I need the blade to be against another surface.
Offline ChuckM
« Reply #22 on: August 19, 2019, 12:29 PM »
When the surface to be flushed is large, I prefer the apron plane from Lee Valley. If the surface isn't dead flat, the small apron plane will also work better than a larger block plane or a long bent chisel. If nothing works (for low spots), the card scraper is the tool that will come to your rescue.
« Last Edit: August 19, 2019, 05:10 PM by ChuckM »
Offline ear3
« Reply #23 on: August 19, 2019, 06:42 PM »
Thanks as always for the info @derekcohen -- of course you have a prototype set [big grin]
I like the addition of the longer handle -- sounds like a good lathe project.  Is that that Jarrah wood you've used elsewhere in your shop?
Offline derekcohen
    • In The Woodshop
« Reply #24 on: August 20, 2019, 09:59 AM »
Yes, Jarrah.
That is a very plain piece. It can be much prettier. Here is a saw I made ...
Offline ear3
« Reply #25 on: August 20, 2019, 02:36 PM »
 [thumbs up]
Yes, Jarrah.
Offline ear3
« Reply #26 on: August 22, 2019, 11:13 AM »
They helpfully include a screw and fender washer that makes it easy to hang the blades, so I guess I don't have need now for the roll that was included with the set, in case anyone wants it.
« Last Edit: August 22, 2019, 11:15 AM by ear3 »
Offline ChuckM
« Reply #27 on: August 22, 2019, 02:22 PM »
I prefer your storage solution, as I don't like rolls. If I had this set, I'd get an extra hardware piece, and make a second handle so I could have two chisels to use at any time.
« Last Edit: August 22, 2019, 02:24 PM by ChuckM »
Offline thudchkr
« Reply #28 on: August 22, 2019, 08:55 PM »
Ordered the set as well, but decided to get three extra handles so each chisel has their own handle.
I’d been considering get some paring chisels but these may work out well for the functions of the paring chisels.
« Last Edit: August 23, 2019, 07:17 AM by thudchkr »
Clint
TSC 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, RAS 115, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
« Reply #29 on: August 27, 2019, 10:06 AM »
@ear3, Nice storage!
Have you gotten the chance to try them out yet?  Did they meet your expectations in use?  Any unexpected pluses or minuses?
Offline ear3
« Reply #30 on: August 28, 2019, 08:07 AM »
Haven't used them yet at all -- right now I'm building the interior casework for the Japanese tansu, and so haven't faced any issues that these chisels would solve.  But hopefully will get to use them soon.  I do still have to sharpen them though.
I was a bit surprised though that they weren't prepped in the way that LV blades usually come.  The edges aren't dull, but they are nowhere near as sharp as, say, the plane blades you get from LV, which usually only require a slight honing to create a keen edge.  I'm going to have to work these chisels on a stone first to get the right edge.
Offline derekcohen
    • In The Woodshop
« Reply #31 on: August 28, 2019, 12:32 PM »
Quote
I find comments like this rather strange. No chisel or plane blade comes from a manufacturer honed to a level that any serious woodworker would consider "sharp". You are expected to sharpen them ... and when they become dull, sharpen them again. [blink]
« Reply #32 on: August 28, 2019, 12:39 PM »
There are various degrees of “ready to sharpen”.
A cutting tool that is delivered “nearly sharp” is surely more valuable (all else being the same) than one that requires even more work before it’s usable.
I find information about the condition of the delivered edge to be useful rather than strange.
« Reply #33 on: August 28, 2019, 06:23 PM »
Well said.  I wish that Lee Valley in particular would be more specific about exactly what is need to hone a blade from the factory to a keen edge.
Lie Nielsen is specific.  Their sharpening instructions brochure specifies starting to prep a factory chisel or plane blade with a 1000 grit stone on the back and the bevel, and finish up around 6000-8000 grit.  That tells me exactly what to expect.  For instance, if I could tell that the back was not flat at 1000 grit, I'd send it back - I've never had to do that with a Lie Nielsen plane blade or chisel.  And with the steel that Lie Nielsen uses, 1000 grit is not "slight", but at least I know what to expect.
I can't find similar info on the Lee Valley site.  However, when Lee Valley sends out a chisel or plane blade and says that the back just needs "at most a light polishing" before use, I'm not sure what that means.  Light polishing to me means 6000-8000 grit.  Any time I have to polish the back, that is more than just honing, so I tend to think that Lee valley is telling me that they have polished the back to 6000-8000 grit already, and all I need to do a little polishing if I want better than that, and a little honing of the edge on the bevel, perhaps to take out a burr or just spruce it up a bit before using it.  Veritas PMV-11 blades come with a dull look, but for that, they do look like they have been polished to better than 1000 grit to begin with.  I just can't shake the feeling that I'm being too optimistic, though, so I tend to treat a new PMV-11 blade like a new Lie Nielsen chisel and start at 1000 grit.  Is that overkill?  Am I making my life too hard with new PMV-11 tools by basically redoing the polishing that Lee Valley has already done?  I can't tell.
So given that bit of angst, the comments from @ear3 make sense to me.  It tells me that I might have to work a little harder on the flush cutting chisels to get them to the level of a PMV-11 bench chisel out of the box.  In my mind, Lee Valley could clear things up by just clearly stating what their expectations are for first use prep of their PMV-11 blades.  Do I start "slight honing before first use" at 1000, 4000, or 8000 grit (or whatever...).  Then we could just follow the instructions and judge whether they worked well on specific tools or not.
« Last Edit: August 28, 2019, 06:45 PM by HarveyWildes »
Offline Birdhunter
« Reply #34 on: August 28, 2019, 08:54 PM »
If I were selling an expensive product like a plane or chisel, I’d send it to the customer as sharp as it could possibly be with the back optically flat. Yes, the buyer must resharpen, but it ought to come out of the box perfectly sharp. If the product cost 10 percent more, that’s fine. Just my opinion.
Birdhunter
Offline ChuckM
« Reply #35 on: August 28, 2019, 09:17 PM »
The flushing chisels, like other PM-V11 bench chisels, are dead flat at within 0.0005".
The Lee Valley PM-V11 plane blades arrived with a warning label about their sharpness. Seasoned users all have their own definition of what sharp is. I am happy with the final honing with 8,000x (water stone) to 10,000x (diamond lapping film). Blades do not come sharp out of the box like that, but the work required to take a new PM-V11 to that level of sharpness can take very little time, depending on the userès skill and equipmentéset-up.
« Reply #36 on: August 29, 2019, 12:20 AM »
Yep - I've never had a problem with either Lie Nielsen or Lee Valley when it comes to flatness.
I did a little math.  0.0005" is about 12.8 microns, which is about what a 1200 grit waterstone provides.  That means that the roughest possible polish on the back of a factory PMV-11 blade or chisel is what I could get from a 1200 grit waterstone.  It could be much better than that since I assume that the polish must be at least as good as the flatness spec.  It would be nice to know.
Polishing a chisel back takes a long time, and it doesn't do much good to hone the edge to 8000 grit if the back hasn't also been polished to 8000 grit.  If the Veritas chisel backs are polished to 1200 grit at the factory, I want to take the time and effort to polish the backs before using them.  On the other hand, if they are already polished to 8000 grit, then I shouldn't have to do anything except a light hone on the edge.  This is not just a theoretical exercise - I have a set of the Lee Valley bench chisels and I've only done the prep work on the ones that I've needed to use because I don't know where to start.  The ones that I have prepped, I've started at around 1000, so it sounds like at least I can skip that and go right to something reasonable between 1200 and 8000 - maybe 4000.  And if Lee Valley said, nope, they are already polished to 4000 or 8000, I'd be even happier.
I suppose that the effort to polish the backs really only applies to chisels if you are comfortable using the ruler trick with plane blades.  Since I just learned about the ruler trick a few months ago (on this forum - thanks folks :) ), I don't have much experience with it.  I've already polished the backs of the plane blades that I use frequently.
Interestingly, Lie Nielsen says to start with a 1000 grit waterstone for their chisels and blades, so Lee Valley may have something of an advantage here if they are truly already polished to 1200 grit.
Does anyone know what some of the other higher end chisel manufacturers recommend - Blue Spruce, for example.  I've use Record (now Irwin), Stanley Sweetheart, and Sorby chisels (both rosewood and octagonal boxwood handles), and I would have to say that they are all second tier compared to Lee Valley or Lie Nielsen for flat (and in general).  They were all a pain to flatten.
« Last Edit: August 29, 2019, 12:33 AM by HarveyWildes »
Offline ChuckM
« Reply #37 on: August 29, 2019, 01:02 AM »
Extracted from the product instructions:
As noted above, the faces of the bench chisels are factory lapped to be flat within 0.0005". As such, no lapping is required by the user. At most, a fine polishing is all that should be done to this surface. Note that the flatness of these chisels is well within the tolerance of most commercially available straightedges.
Breaking the Side Edges
The  lapped  face  of  the  chisel  blade  is  perfectly  smooth  and,  as  a  result,  the side edges of the chisel blade will be fairly sharp.
http://www.leevalley.com/en/wood/page.aspx?p=69847&cat=1,41504
I have flattened the backs of the Narex chisels after I bought them. I have however done nothing to the back of over a dozen of A2 or PM-V11 plane blades or chisels from Lee Valley. They are honed only on the bevels (back bevel blades not counted), and they are very sharp for all woodworking intents and purposes. I have tried the ruler trick on blades, but in general, I do not use it.
Image shows a high angle blade from LV (sharpened freehand with diamond lapping films, micro-bevel but no ruler trick) being used with a tight mouth on a mixed grain top. Its back has been as is from the factory.
« Last Edit: August 29, 2019, 01:34 AM by ChuckM »
Offline Rob Lee
  • Festool Dealer
    • Lee Valley/Veritas
« Reply #38 on: August 29, 2019, 08:23 AM »
Hi -
Our lapping process conditions surfaces to a flatness far higher than we quote (an order of magnitude). However, we hedge as there can be some amount of springback as the blades are lapped with pressure applied.
For all intents and purposes - they are stupidly flat for woodworking.....you can only make them worse by working on them.
If you are going to polish the back (and you should) - I would start with a 4000X or more- they will require very little time to polish.
The back of our blades have a flat gray appearance. This is a result of a random scratch pattern that disperses (scatters?) light at high angles of incidence (like when you're looking at it!). If you sight down the blade at a lower angle (say 10-15 degrees) - it will have a mirror surface. Polishing will dull the scratch pattern - and you will have a "mirror" finish at higher angles of incidence.
Cheers -
Rob
« Last Edit: August 29, 2019, 01:38 PM by Rob Lee »
Offline derekcohen
    • In The Woodshop
« Reply #39 on: August 29, 2019, 10:05 AM »
Rob, you beat me to it. I shall still post this photo from my Veritas O1 chisel review ...
On the left is an untouched chisel back. The other two received under 30" lapping on a Shapton 12000 - which only polishes steel - and they turned into mirrors.
This is the case with ALL the Veritas blades that have passed through my hands.
And here is another reason why one needs to hone new chisels: the backs and the faces should both be honed and polished to the same grit, and other makes are very unlikely to be better than the 4000 grit at which Veritas arrive.
« Reply #40 on: August 29, 2019, 11:50 AM »
Hi -
The back of our blades have a flat gray appearance. This is a result of a random scratch pattern that disperses (scatters?) light at high angles of incidence (like when you're looking at it!). If you sight down the blade at a lower angle (say 10-15 degrees) - it will have a mirror surface. Polishing will dull the scratch pattern - and you will a "mirror" finish at higher angles of incidence.
Cheers -
Rob
Thanks @Rob Lee - Just the info I wanted.  I just hope I haven't screwed up my existing chisels by starting at a grit that is too coarse.  Thanks also to @derekcohen for verifying from your experience.
Offline Rob Lee
  • Festool Dealer
« Reply #41 on: August 29, 2019, 01:41 PM »
And.....
Another good reason to have a mirror finish is that a reflective surface helps align a chisel visually (you can tell when a mirror is perpendicular to a surface, or edge).
Cheers -
Rob
Offline Rob Lee
  • Festool Dealer
« Reply #42 on: August 29, 2019, 01:47 PM »
Hi -
Cheers -
Rob
Hi -
No worries on you existing chisels....I said you "can only" make them worse.... not that "you will" make then worse !  [big grin]
If you feel you've messed 'em up - give me a shout at rlee@leevalley.com , and we'll get then put right....
Cheers -
Rob
Offline ear3
« Reply #43 on: August 31, 2019, 07:38 PM »
Out of the box sharpness should be a minimal factor in deciding whether to invest in a tool that the user must regularly resharpen and maintain, and while i wouldn't otherwise follow up what was just meant as an offhand observation, there's still a question hanging out there,  so I'll simply post a pic of one of the chisels blades out of the box:
Like I said, the plane blades I have previously gotten from LV have always been cleanly sharpened and ready to use with just a quick hone. These uncharacteristically needed a bit more work.  Not a big deal.
« Last Edit: August 31, 2019, 07:50 PM by ear3 »
« Reply #44 on: September 05, 2019, 06:33 PM »
Just got mine today - I'll give a report after I've had the chance to sharpen them.
« Reply #45 on: September 06, 2019, 03:54 PM »
I sharpened my new flushing chisels today.
I used new, out-of-the-box Shapton stones which I assumed were flat enough to match the chisels.  I started with 4000 grit, moved to 8000 grit, and then tried 16000 on the 1/2" chisel.  I took 1-2 minutes for each of the 4000 and 8000 grit stones per chisel (more for the 1 1/2" - see below), and under a minute with the 16000 grit stone  Prepping all four chisels took about 25-30 minutes with cleanup.  I then honed each chisel using the highest grit that I used when polishing the back.  With the exception of the extra time on the 1 1/2" chisel, it was a very streamlined process compared to other chisels that I've had to prep.
The 1/2", 3/4", and 1" chisels were dead flat.  The 1 1/2" chisel was close, with a slight low spot on the back along one side of the edge.  In the picture you can see it as a dull gray triangle on the left hand side of the edge.  I couldn't see any light under a straight edge, so it is still flat enough for things that require flat, but I would like to have polished the back along the whole edge for sharpness after honing.  I don't have an immediate need for the 1 1/2" chisel, so I'll bring this to the attention of Lee Valley and see what they recommend.  The other chisels ended up looking like the pictures that @derekcohen posted, at least on the last 1-2 inches that I polished.  Looks like I don't need to start with a 1000 grit stone for Lee Valley :).
I tested the chisels on (1) birch dowels sticking up from a planed board, and (2) elm end grain.  None of the pieces were longer than the chisel blades, so I could have made the test cuts with regular bench chisels.  I used a somewhat skewed cutting action, which meant that I wasn't pushing directly forward on the handle.  Instead, I tended to hold the handle on the bolster, with my other hand pushing down on the blade.  (In other words, I haven't really given the chisel handle design a good test yet.)  With that approach, I didn't have any trouble with the handle coming loose.
The test cuts all looked great.  I noticed a slight difference between the 1/2" chisel which I polished and honed to 16000 grit, and the others.
Offline derekcohen
    • In The Woodshop
« Reply #46 on: September 06, 2019, 08:52 PM »
Quote
Harvey, about Shaptons (and other waterstones) ...
I would never assume that a waterstone is flat just because it is new. There is no tool I know of, especially consumables like waterstones, that should be assumed to be “right” from the outset. Everything needs some work.
Shaptons tend to move a little. I ended up glueing mine to glass to keep them flat, but would still flatten them (especially the 1000) before use.
The reason you needed three grits to work the backs of these blades is more likely to be that your stones were not as flat as the chisels! They only need to be polished, not flattened. You are more likely to undo the work by Veritas by using something coarser than 8000 grit.
« Reply #47 on: September 07, 2019, 10:49 AM »
Quote
Point well taken - never assume...  I have a Shapton lapping plate and should have used it.
I was using Shapton Glass stones, but I love the idea of gluing a regular stone to a glass base.  Do you have to prep the glass at all, for example by etching it?  What kind of glue works for that?
I started at 8000 with the 3/4" chisel, and wasn't satisfied with the results, so I dropped back to 4000 based on Rob Lee's advice above.  Compared to any previous experience I've had with chisel backs, including Lie Nielsen, I was very pleased with the results.  Even starting at 4000, it was way easier than previous experiences.
WRT the 1 1/2" chisel,  my thinking, based on the results with the other chisels (basically perfect) and the way part of the edge didn't polish as expected, that the stones are not at fault.  I could flatten it out using 1000 or 2000 grit, but since it seems to be out of the Veritas metric for flat, I'll see what they recommend first.
Offline derekcohen
    • In The Woodshop
« Reply #48 on: September 07, 2019, 12:33 PM »
Hi Harvey
I am sure that you did no harm ... just that it should not have been necessary to go below 8000.
The Shaptons I was referring to are the Pro version. I had the local glass merchant size and cut up a few glass rectangles, each about 1/4" thick. I used epoxy. No etching required. Make sure that you secure the combination with tape as the epoxy is slippery at the start, and parts may move  ... and then you are literally stuck with the result! DAMHIK.
« Reply #49 on: October 08, 2019, 03:27 PM »
So I've just given the chisels a bit of a workout.  I used them to trim up some box joints.  The pins extended past the corner of the box between 1/64" and 1/32".
The bottom line is that these chisels enabled me to trim the joints fast and with virtually no tear out.  They were much more flexible than a chisel plane in terms of angling into the cuts, and the ability to lay the chisel flat along the length of the box made it better than a regular chisel for the job.  It gave me much finer control than trying to sand.
One thing that surprised me was the fact that it was very useful to have multiple sizes of chisel.  A narrower chisel allowed me to attack one pin at a time, and work to within about 1/8" of the corner from the box side, while a wider chisel allowed me to work the rest of the cut from the side and still have a solid reference on the side of the box.
So overall, I'm not disappointed that I bought them, and would do it again.
Minor issues:
1.  The 1 1/2" chisel was not within the published spec for flat (enough off that flattening with a 4000 grit stone was not practical), but it was close.  I notified Lee Valley, thinking that they might want me to return it for QA, and they just said that they would send me a replacement if I wanted one, and didn't request that I mail the old one back.  Since they didn't seem too concerned about the QA aspect, I'm going to try to flatten in on a 1000 grit stone and if that works, I'll just keep it.  Otherwise I'll request the replacement.
2.  On the 3/4" chisel, the screws that attach the chisel blade to the bolster came loose.  I've tried to put them back with blue thread lock, so we'll see how that works.  If they come loose again, I'll try red thread lock, and if that fails, I'll notify Lee Valley on that as well.
