Author Topic: Level 5 cut gloves  (Read 2236 times)
Offline Packard
Level 5 cut gloves
« on: August 17, 2021, 09:22 AM »
I received a free sample of a Level 5 cut gloves.  This is the highest rating for an ASTM or ISO cut-resistant glove.  You are supposed to be able to press down on a razor blade with 7.7 pounds of force without cutting through the fabric.
It is surprisingly flexible and light.  About as thick as cotton gardening gloves, but with a much tighter fit.
I have not worn them long enough to determine how warm they are going to feel using them indoors in the shop.
But for short periods of time, it certainly will be wearable.
Where would you use these?  It will not protect against a table saw blade or a router bit spinning at 20,000 rpms.
When I was a picture framer, this would have been handy when cutting glass.  I always deburred the edges with a glass deburring tool (sort of like a knife sharpener with the carbide set at 45 degrees instead of at a knife edge.  So handling the glass after cutting was not an issue.  It was only during the cutting and deburring operation was it required.
The gloves seem to be useful, but where?  And how?
Offline Bob D.
Re: Level 5 cut gloves
« Reply #1 on: August 17, 2021, 10:24 AM »
"Where would you use these?"
Probably not that often in a wood shop, but I can think of a few instances.
Working with sheet metal
Opening your machines/removing covers for maintenance since they often have sharp edges
Changing bandsaw blades, especially folding/unfolding them
Working with glass or acrylics
Outside the wood shop there will be many instances where their use would be appropriate.
Offline Packard
« Reply #2 on: August 17, 2021, 10:33 AM »
The last time I tried on cut-resistant gloves they were bulky and didn't conform to my hands well.  You really could not do much with them.
These gloves are much improved.
I do recall having an appointment at a poultry processing plant.  All the workers wore cut-resistant gloves and threw them away at the end of each shift (they could not be made sterile once used).
An amusing side-bar to that visit was that I could not find the facility on a map, so I asked a state trooper for directions.
He said, "Follow me.  I'm going there to investigate a cutting."
I said, "A cutting?"
The trooper said, "Two guys got in an argument and one of them ended up getting cut open from his shoulder to his hip.  Took 173 stitches."
I asked, "Is he going to make it?"
The trooper said, "Oh, he wasn't seriously injured.  Those guys are so good with knives that he was cut just through the skin.  A lot of blood, but not much damage.  He wasn't trying to kill him or anything.  It was just an argument."
I don't know about you, but 173 stitches sounds like a lot of damage.  It sounds like more than an argument to me.
Offline SRSemenza
« Reply #3 on: August 17, 2021, 04:37 PM »
Not on a map ? Was the plant called Los Pollos Hermanos? Did it have a hidden lab?  [blink]  [big grin]
Offline Packard
« Reply #4 on: August 17, 2021, 04:45 PM »
The street address was an invention of the company as it was a "street" on private property.  So in the modern GPS world it would be called an "unnamed road".
The most horrific thing that I took away from that trip was that they had a "beheading" line on the conveyor.
The turkeys were suspended by their legs on a conveyor.  As they continued on the line they came to a pair of stainless steel rods that were about 2-1/2" apart at one end and grew progressively closer and progressively downward.  As the bird continued it literally pulled the head off of the dead bird.
The head would then fall on a large stainless steel pan with a loud "thud".
I looked at the process briefly, and then looked away.  For the rest of the show and tell all I remember is the constant "thud, thud, thud, thud, thud...".  In fact, I can still hear it in my head and that is some 30+ years ago.
Do yourself a favor--never visit a poultry processing plant.
Offline jeffinsgf
« Reply #5 on: August 17, 2021, 06:49 PM »
I know a few carvers who wear this kind of glove.
Offline Packard
« Reply #6 on: August 17, 2021, 07:42 PM »
It showed up from an Amazon reseller when I ordered a new spacer, nut and wrench for my Dewalt 4-1/2” angle grinder.  I thought there must be some tie-in there, but I don’t see it.  They are $7.00 per pair when you buy two pair.
I will hold on to them. I probably will find a use somewhere.
Offline Rob Z
« Reply #7 on: August 17, 2021, 09:11 PM »
We used those while handling and installing expanded metal lath for tile and stone installations.  I didn't know about the level 5 rating at the time, just that they made that metal lath easier to handle.
Offline Eorlingur
« Reply #8 on: August 20, 2021, 07:23 AM »
I like those gloves a lot and use them as often as I can in the shop. If I am using a chisel I try to keep a glove on at least my left hand and I definitely use them when sharpening tools.  They are very snug and comfortable and second nature to me now.
It has reduced the number of splinters and small cuts I get on my hands significantly as well as the number of blood stains I leave on my work. I always keep one or two pairs available on the workbench so that I can put them on whenever I need to. It is always when I do ”just one quick thing” that I end up cutting myself and I try to avoid that now.  My hands haven’t been in this good shape since I started woodworking so it seems to be working.
My pillar drill is the only rotating tool in my shop and I make sure not to wear gloves around that one.
Offline rst
« Reply #9 on: August 20, 2021, 09:15 AM »
As a result of working in the glass and storefront industry for 41 years, I'm very familiar with these type gloves.  The only drawback is that the rubber gripping surfaces wear fairly rapidly with constant use and are expensive.  Currently those Milwaukees are around $15.00 a pair in singles.  The level Is are around $7-8.  I use my worn ones for yard work and they last forever as such.
Offline Packard
« Reply #10 on: August 20, 2021, 10:11 AM »
My machine shop teacher in high school was in the navy in WWII.  He told the story about a fellow machinist who was about 6'5" and enormously strong.  That guy made a bet that he could grab the chuck of the drill press and stop the rotation.  But he did not want to cut up his hands so he put on a pair of heavy leather gloves.  He got a good two-hand grip on the chuck and said, "OK".  And one of the other machinists turned on the drill press.
He did not cut his hands, but he did break both his arms.  This was probably a bad bet. [eek]
Offline Crazyraceguy
« Reply #11 on: September 13, 2021, 06:48 PM »
Agreed. Way back in the day, my dad worked for a food machinery manufacturing company. He sold  really odd harvesting machines, not the typical corn or soybean combine type stuff, and conveyor systems for other types of processing plants. That allowed me to go with him into a KalKan dogfood plant one time, when they were looking to modify some part of the line. So, whenever you see the words "by-products" included as part of the ingredients....that's what it means. They use all of the animal, every bit of it. Gross, especially for a kid that was about 10 at the time.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
Offline Yardbird
« Reply #12 on: September 13, 2021, 10:40 PM »
When I was a kid in the early 1960's my dad took me to a poultry processing plant.  We had laying hens, and when they reach a certain age, they go to the processing plant and probably end up in soup.  Anyway, I remember the hens hanging from a conveyor, and a guy pulling the head down so the neck would go through a V shaped blade.  If anyone has killed chickens on the farm, you know what that conveyor scene looked liked.
Later, I took an accounting job at a hog processing plant.  (Kahn's in Cincinnati, OH-now closed).  I bailed as quick as I could but not quick enough.  If I remember right, they would slaughter 5000 hogs on one day, send them to the cooler, then cut them the next day.  I remember the guy cutting throats spent all day standing in ankle deep blood. A guy could gut a carcass with about two cuts.   Very repetitive motions, lots of carpal tunnel.  And yes, those guys were good with knives.  I always thought Kahn's were harder on their employees than the hogs and went to a manufacturing plant to build trucks.  Kahn's would hire ten people and by the end of the week have two left.  When I got aggravated at the truck plant, I would just remember Kahn's and decided my present problem was not so bad.   Anyway, people handling aluminum sheets to make the fuel tanks had special gloves.  I found a pair and they are RIVAL cut level 3 with part # 3712GM.  They also used gloves one day then threw them away, where I retrieved mine.  Again, only level 3 but they are very flexible.  I can put a 10mm nut on a bolt with these gloves.
The guys at the hog slaughter plant had special gloves that were metal-like a Knight's glove.  And yes, I do not eat much processed meat.  Don't ask me about turkey hotdogs.
