Author Topic: Lapping Plate  (Read 821 times)
Offline ear3
Lapping Plate
« on: July 20, 2020, 10:19 AM »
I'm wondering what folks do for lapping plates for their stones.  I use the Dia-Sharp up through extra fine, but for the final honing I switch over to the Shapton glass stones, which do require regular lapping.  I currently do it with a coarse Duo-sharp stone that I no longer use for regular sharpening -- the interstitial space on the surface aids in moving the stone back and forth by not allowing the surface to get too clogged with the material being removed.  It has worked fine up until now, but since the Duo-sharp is the same size as the Shapton, I sometimes wonder whether I'm always lapping it perfectly flat across the entire surface, which can be an issue when doing wider blades.
The Shapton Lapping Plate is almost offensively expensive.  I'm sure it works, but it's not clear to me why it is better than other, cheaper options.  There's also the DMT Lapping Plate, but I'm concerned that the even surface would clog up when lapping the ceramic of the Shapton stones.
I previously tried the cheap Norton lapping stone, but it cracked on me after only a few uses.
Any other options?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Offline miclee15
Re: Lapping Plate
« Reply #1 on: July 20, 2020, 11:00 AM »
I use the Shapton Glass for my tools and knives.   I use the DMT plate and when I go to flatten, I do all the stones from finest to course prior to sharpening.   This is done by a sink and I just rinse along the way.  Afterwards, I just towel dry and let it sit vertical and haven't had a rust problem. Clogging has never been a problem.
Offline ear3
Re: Lapping Plate
« Reply #2 on: July 20, 2020, 11:29 AM »
@miclee15 Thanks -- good to know that the DMT works well specifically on the Shapton.  Question, I see that there is a 120 and a 95 micron version of the DMT lapping plate, and I've seen comments that the slightly less aggressive 95 micron leaves a better surface when flattening sharpening stones.  Which version of the lapping plate do you have?
Offline GoingMyWay
Re: Lapping Plate
« Reply #3 on: July 20, 2020, 11:38 AM »
I follow Rob Cosman's advice and use the 300 grit side of the Trend Diamond Stone to flatten the 16,000 grit Shapton Waterstone:
Inquiring Minds Want to Know
Offline miclee15
Re: Lapping Plate
« Reply #4 on: July 20, 2020, 12:10 PM »
I purchased and used the 95, and use pencil grid lines on the stone to ensure i stop right when all the lines are removed.  The stones are expensive and i don't want to remove anymore then I have to. hahah
Offline Birdhunter
Re: Lapping Plate
« Reply #5 on: July 20, 2020, 01:14 PM »
DiaFlat lapping plate from Lie Nielsen. I also put a pencil mark grid on the waterstones and lap until the marks are gone. I usually turn the waterstones 180 degrees midway through the flattening process. I rinse the lapping plate after each waterstone is finished.
Birdhunter
Online Bert Vanderveen
Re: Lapping Plate
« Reply #6 on: July 20, 2020, 01:58 PM »
When you buy the Veritas 'Stone Pond' (correct me if I have the name wrong), a lapping system is included, consisting of a glass plate, a sheet of plastic and some Lapping Grit. Maybe check out this way of lapping?
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS
Offline TwelvebyTwenty
Re: Lapping Plate
« Reply #7 on: July 20, 2020, 05:58 PM »
I think the glass lapping plate and self adhesive lapping abrasives are "where it's at" these days - no time required maintaining a whetstone's flatness - less time sharpening more time woodworking.
Offline ear3
Re: Lapping Plate
« Reply #8 on: July 20, 2020, 08:54 PM »
Thanks for the replies.  Gonna go with the 95 micron DMT Dia-Flat Lapping plate.  Serendipitously, the cheapest price I've found is actually locally at Tools for Working Wood, so I get to support local brick and mortar business as a bonus.  Probably see you tomorrow @sally
Offline grbmds
Re: Lapping Plate
« Reply #9 on: July 21, 2020, 12:07 PM »
Just a little input . . .
Unless you are going to use the Die-Flat additionally for flattening the back of plane blades or chisels, I believe the coarser version works a little better for just flattening your sharpening stones. I use it to flatten my Shapton Glass Stones and it works well; the coarser version flattening faster than finer Dia-Flat. The will be no difference in the surface of the the Glass Stones with either. The coarser flattening plate will just be faster.
If you plan to use the Die-Flat for also flattening the back of blades, be aware that, over time, the plate's capability to cut the Glass Stones will decrease at least slightly from wear. There will likely be almost no wear if you use if just for flattening your stones.
Randy
Offline ear3
Re: Lapping Plate
« Reply #10 on: July 21, 2020, 08:30 PM »
@grbmds Oh well, I picked up the 95 micron version earlier today.  I imagine it will be fine though judging from the comments here and from what I've read elsewhere.  I'm generally working with new chisels and planes, rather than rehabbing old ones, so whatever flattening I need to do on the backs is usually minimal.  The lapping plate will thus be almost exclusively for flattening stones, unless of course I someday drop one of my block planes on the shop floor.
