I'm wondering what folks do for lapping plates for their stones. I use the Dia-Sharp up through extra fine, but for the final honing I switch over to the Shapton glass stones, which do require regular lapping. I currently do it with a coarse Duo-sharp stone that I no longer use for regular sharpening -- the interstitial space on the surface aids in moving the stone back and forth by not allowing the surface to get too clogged with the material being removed. It has worked fine up until now, but since the Duo-sharp is the same size as the Shapton, I sometimes wonder whether I'm always lapping it perfectly flat across the entire surface, which can be an issue when doing wider blades.
The
Shapton Lapping Plate is almost offensively expensive. I'm sure it works, but it's not clear to me why it is better than other, cheaper options. There's also the
DMT Lapping Plate, but I'm concerned that the even surface would clog up when lapping the ceramic of the Shapton stones.
I previously tried the cheap Norton lapping stone, but it cracked on me after only a few uses.
Any other options?
