Author Topic: Pure Fun  (Read 1449 times)
Offline Birdhunter
Pure Fun
« on: November 15, 2019, 05:20 AM »
I’m building a large complex reception desk using 3/4” Baltic birch with 1/4” thick oak edge trim. The trim is slightly wider than the plywood (by plan) and has to be pared down flush.
I didn’t want to use a router due to possible blowout.  I tried sanding and that was too slow.
I ended up using a very sharp Lie Nielsen block plane. It’s a lovely fun feeling to see paper thin shavings boil out of that plane. I can get close enough with the plane that a quick sanding with 180 grit finishes the job.
I also bought a bunch of edge clamps from Rockler that have made the trim job far easier. The clamps act like a large clothes pin with a rubber band stretched between the jaws. They work far faster than the blue tape method I was using.
Birdhunter
Offline mike_aa
Re: Pure Fun
« Reply #1 on: November 15, 2019, 09:43 AM »
@Birdhunter  If you need more of those edge banding clamps, here's a way to get more cheap.
Hope this helps!
Mike A.
Offline gunnyr
    • Compass Custom Creations
Re: Pure Fun
« Reply #2 on: November 17, 2019, 03:41 PM »
I recently started carrying a block plane in my tool bag.  It is indeed VERY satisfying to see those wispy thin shavings curl out of the plane!
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
Offline Rob Z
Re: Pure Fun
« Reply #3 on: November 20, 2019, 03:06 AM »
Birdhunter
I am working on refining hand tool skills as often as possible, and continue to be amazed at the results  with something like a basic block plane. I use the LN low angle block plane in the same way you are and it's possible to trim the edging so flush that there is just a "fuzz" taken off the surface of the plywood. As you say, just a quick pass with a sander or sanding block finishes the job.
Offline Birdhunter
Re: Pure Fun
« Reply #4 on: November 20, 2019, 11:03 AM »
I had to learn how to sharpen plane irons and chisels before hand tool became truly enjoyable.
Birdhunter
