Author Topic: Detail Hand Sanding  (Read 10626 times)
Offline Peter Halle
Detail Hand Sanding
« on: August 24, 2013, 08:56 AM »
This is Carpentry has posted a new article on Detail Hand Sanding:  http://www.thisiscarpentry.com/2013/08/23/detail-sanding-techniques/
I know that I hate hand sanding and suspect that many others here do too.  In that article there was a product mentioned that I had never paid attention to - Tadpole Sanders.  It took a while to search and find a supplier, but here is a link:  http://www.woodworkingshop.com/search.aspx?q=tadpole
Anyone here use these before?  Are there any other products that you've used that will make sanding profiles easier / more enjoyable?
Offline farms100
    • please visit our woodworking guild
Re: Detail Hand Sanding
« Reply #1 on: August 24, 2013, 09:23 AM »
I have the wood craft version and  have used them from time to time.  I think they work very well and are one of those nice things to have around the shop for those times you need them.
edited to add
I hadn't thought of using the  handle ends to get into narrow spots, thats a great idea.
eastern mass guild of woodworkers. http://www.emgw.org
Offline rnt80
    • Agape Wood Design
« Reply #2 on: August 24, 2013, 10:03 AM »
I've had the Rockler version for years and use them on every project.  It's not like they make sanding more enjoyable but the results are certainly more consistent.  I've found that it's important to not press to hard or your paper loads up pretty quickly.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #3 on: August 24, 2013, 01:00 PM »
I have used the same set of Detail sanders but got mine at Lee Valley.
They work well, and as the author stated they don't always fit standard profiles, so some "creative" adjustment is required. I wish the made these profiles to match popular molding profiles. It would save a lot of time.
If I can use a customized scraper to smooth a profile I will make one from a regular scraper using a jigsaw and Dremel to mill the metal to the right shape.
Tim
Offline Alex
« Reply #4 on: August 24, 2013, 01:22 PM »
What works best for me with profiles is the good old sanding sponge.
They adapt to any profile. And are comfortably to hold in your hand.
Offline John Bates
« Reply #5 on: August 24, 2013, 02:27 PM »
I act for Flexifoam over here, their sanding blocks come in various profiles and they do some great flexible pads but I like the look of those detail sanders
Manufacturer's agent and importer, representing or importing, Flexifoam, Fastcap, Armor Tool Co, Cable Clamps, Bruns Tool holders, Rolgear screwdrivers, RevMark Markers, Occidental Leather and Martinez Hammers.
Offline SRSemenza
« Reply #6 on: August 24, 2013, 04:27 PM »
Those sure look handy for $20.
If you need a harder block in a detail profile the LS130  blocks/profiles  are useful  to use by hand as well.
Offline Scott Burt
  • Magazine/Blog Author
  • painter/writer/educator
    • Prep to Finish
« Reply #7 on: August 24, 2013, 04:31 PM »
I just read that. It looks like it is a rebroadcast of something that had been written previously on one of their affiliate sites. Those are old school techniques for sure. As a painter, thats a lot of time to put into one joint. We see more of the reinforced butt joint with profiles like that than scarf joint. The best power sanding alternative is the LS130, and not with the custom molds. There are 3-4 stock profiles that blow through those details in minutes. It takes a little bit of practice to become that delicate with the linear sander, but it is by far a better solution, especially for those who deal with lots of joints in production prep.
Offline NERemodeling
    • New England Remodeling, LLC
« Reply #8 on: August 24, 2013, 04:45 PM »
Peter.  I've got the complete set from your link..  most of them have never even come out of the package.   The rectangular pads are nice.   The several profiles that I have used worked well and i was glad i had them when I needed them
John
CT26  -  (2) Midi  - Planex - Kapex -  Domino 500  -  Carvex  -  TS55EQ -  Rails; 800, 1080, 1400(holy rail), 1900, 3000 -  OF1400 - OF1010  - LR 32 - RO 150 - RO90 - RAS115 - ETS125 - DTS400 - LS130 -  EHL65 - HL850 -  MFT1080 - (2) MFT800
Offline Motown
« Reply #9 on: August 24, 2013, 06:12 PM »
I use the Rockler version with my CT to help with dust collection.....it works really well.
Offline GregB
« Reply #10 on: August 24, 2013, 06:16 PM »
Collins Tool makes Bunny Planes, which speed up the process of tuning a scarf joint. Still a bit of sanding required in most cases, but the bulk of the work can be done quicker & with less dust by using the planes... http://www.collinstool.com/base.php?page=bunny_planes.htm
Offline PaulMarcel
    • VoilĂ , my blog
« Reply #11 on: August 24, 2013, 06:54 PM »
I don't use a lot of moldings on my projects, but those that had moldings all used those tadpole sanders; very very useful.  Sometimes for small radius coves (e.g., part of an ogee) I've used a drill bit of the same diameter wrapped in sandpaper.  Coves aren't a circle projection, but getting the closest radius and moving it around works in a pinch.  Foam sanding sheets work similarly to the pads Alex mentioned, like the Granat hand sheets.
Offline majohnson
« Reply #12 on: August 26, 2013, 11:05 PM »
As a box maker, I used them often. The drawback is sanding a radius across grain, they will leave sanding marks if your not careful.
